Evening all, I do hope this is the right place to post this
I have a Denon MCX8000 and the crossfader needs replacing, however I'd like to do away with it altogether and replace it with buttons that mute momentarily when pressed
Trouble is I have no idea how to achieve this and thus i'm looking for advice/help. I did take the fader out to inspect it and noticed it only has three wires attached so in theory it'd be a ground and A and B?
Closing the ground to either A or B would work? or would I need a resistor too? or am I completely wrong?
Thank you for reading
Best
Tony
Hi Tony,
Not exactly the right place, here we talk about DIY MIDI Devices :shock:
There's no service manual/schematics available for this product, but.
https://www.planetdj.com/media/catalog/product/cache/1/image/9df78eab33525d08d6e5fb8d27136e95/7/0/704-mc4k-b173-1.jpgDenon DJ Replacement Crossfader for MCX8000/MC4000
As you can see, pinout of the connector  CN1 is GND, ADC, VCC.
Means that pot drives an ADC(Analog to Digital Converter) with a ADC value range of GND to VCC
then ADC pin value range is ADC=GND (only channel A) to ADC=VCC (only channel B),
where center value is ADC=VDD/2 (both channels A and B mixed equally).
Both channels muted at the same time is not possible, using this ADC input.
Still possible to replace the fader, it's cheap ;)
Best regards
  • 4 weeks later...
Hey Antichambre, thank you for the reply
I'd really like to replace the fader for buttons if possible. From what you have sais there if i was to connect a momentary on switch to ADC and GND pressing that would mute channel B ?
Regards and apologies for posting in the wrong place
