6040 Posted August 4, 2021 Report Posted August 4, 2021 Hi all, I finally got my hands on some working sids for my MB-6582 and have been playing around with it. I gave up on hunting down ebay chips as most of them are not working. I got two already that half work for lead sounds but the rest does not work. Anyway here is what I have so far: Sid1 Swinsid x 2 Sid2 8580 x 2 Sid3 Swinsid x 2 Sid4 6581 x 2. Unfortunately the Swinsids are not as loud as the real chips but they sound ok. Is it normal that on the 6581 each time you select a different sound that it plays it in very low volume. I cannot hear this on any of the other chips? What should happen if you select L/R or both chips on one sid? I was expecting to only hear the left or the right or both channels but nothing changes, I always hear both channels without any difference. Cheers 60/40
6040 Posted August 18, 2021 Author Report Posted August 18, 2021 Hi all I am surely no expert in soldering and I probably did something wrong. If someone could tell me what happens on your midibox if you select the sid channels (L/R), that would really help. I made a small video of the 6581 issue https://streamable.com/nbp45w There is no midi connection I am just flicking through the presets of the bank A. The sound stays on until I select another preset and it is especially noticeable on the Zelda Sounds. This only happens on the 6581, not on the Swinsid, neither the 8580. I moved the 6581 around to a different pic and the problem stays with it. Any thoughts? Thanks 60/40
Noise-Generator Posted August 20, 2021 Report Posted August 20, 2021 1 Suggestion: Dead VCA of the 6581 2: Bad solder points from PIC to SID What happens if you put an 8580 in it's place?
6040 Posted August 21, 2021 Author Report Posted August 21, 2021 Thanks for getting back to me. I tried the three working 6581 chips I have in Sid Socket 1 alone and they all have that issue. If I put the Swinsid or 8580 in that same socket it is gone. I found this on the ucapps site: After a sound has been played, you can sometimes still hear it in the background: thats also an known issue with the VCA of the SID chip. This seems to happen to me but without playing anything just selecting a patch. Is there anything that can be done with settings to get rid of this?
Noise-Generator Posted August 21, 2021 Report Posted August 21, 2021 (edited) Because there is also a 6581 Sustain Bug, use a Noise Gate Edited August 21, 2021 by Noise-Generator
6040 Posted August 23, 2021 Author Report Posted August 23, 2021 Could you explain a bit more how I would add a noise gate? I probably should not have mixed two issues into one thread. What is the purpose of the Sid Ch Select (L/R)? I cannot hear any difference, not even on stereo patches. Thanks 60/40
Noise-Generator Posted August 24, 2021 Report Posted August 24, 2021 23 hours ago, 6040 said: I probably should not have mixed two issues into one thread. What is the purpose of the Sid Ch Select (L/R)? I cannot hear any difference, not even on stereo patches. I wondered about that too but had not invest into answers but this could explain it: http://www.ucapps.de/midibox_sid_manual_l.html SIDn: toggles between LR, L- and -R. Here you can specify, if OSC, FIL and MOD parameter modifications should affect only the left, the right, or both SID channels. The SID number (SID1, SID2, SID3, SID4) has to be selected with the deticated SID buttons.
Noise-Generator Posted August 24, 2021 Report Posted August 24, 2021 A Noise Gate is an Effect which let you choose on which point it should pass the signal. For example if you use an Microphone and it should just react to your speech than you tweak the treshold to the point it shall react. It's an standard effect you probably own as a Software Plugin.
6040 Posted August 26, 2021 Author Report Posted August 26, 2021 Thanks a bunch, got it now. One last question if you do not mind. The feedback pots only work on real chips and not on the swinsids, correct? Or is there a special version of the swinsid that supports this?
Noise-Generator Posted August 30, 2021 Report Posted August 30, 2021 (edited) Feedback is based on SID Audio In and the SwinSID Ultimate is supporting that. It's a good point to mention this here SID Clone List so in future I will care about that. Edited September 2, 2021 by Noise-Generator
6040 Posted September 2, 2021 Author Report Posted September 2, 2021 Thanks is the SwinSID Ultimate the only one to support this? It seems to be unavailable.
Noise-Generator Posted September 2, 2021 Report Posted September 2, 2021 As far as I know just the fpgasid
