Antichambre Posted September 27, 2021 Posted September 27, 2021 Hi all, I place this project here baecause it's more than a simple midification of a vintage synth. Here is the only existing post which talk about this subject here It already exists a few retro kit for the Korg Poly-61, but i wanted to fully upgrade my old Poly-61. It's a synth I owned for free, it was found at the back of a concert hall, in the trash. I fixed and renovate it. Symptoms were the common ones, battery leakage on the porgrammer board, wood parts and some keys were destroyed. Once it was fixed I got a lot of fun with it, it sounds typically 80s with a fat analog vibe and i love that. but using MIDI for pretty everything I was very frustrated by the lack of midi control and it's limited control panel. So I started to study something better. I replaced all the digital part of the synth by a MIDIbox based one, I kept all the signal path like it is. I also reuse the existing control panel I recreate the exact behavior of the original one in MIOS32, named LEGACY mode, the original factory presets were implemented too. The useless TAPE ENABLE switch at the back is now a switch between the LEGACY mode and the EXTENDED mode, it enhances the parameters ranges and adds some new parameters. Finally I designed a dedicated Control surface which can be directly connected and powered to/by the Poly using USB. The Poly has an USB device port to connect to a daw and an Host port to connect a MIDI controller. Voilà! Best Regards Bruno
njosnari Posted August 29, 2023 Posted August 29, 2023 Yo, this is absolutely amazing! How did you manage this??
