Guest echelon Posted March 3, 2004 Report Posted March 3, 2004 Hello,Can someone help me with solving the following problem when pogramming my midibox?I've managed to upload the bootstrap and the MIOS-OS. No complaints @ all. Now I'm trying get upload my application to test if all of my 16 endless rotary encoders are working.I've made the following changes in the mios.tables.inc ;; encoder entry structureENC_ENTRY MACRO sr, din_0, mode dw (mode << 8) | (din_0 + 8*(sr-1)) ENDM ENC_EOT MACRO dw 0xffff ENDMMIOS_ENC_PIN_TABLE ;; encoders 1-16 ;; SR Pin Mode ENC_ENTRY 1, 0, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 1 ENC_ENTRY 1, 2, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 2 ENC_ENTRY 1, 4, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 3 ENC_ENTRY 1, 6, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 4 ENC_ENTRY 2, 0 MIOS_ENC_MODE_NON_DETENTED ; V-Pot 5 ENC_ENTRY 2, 2, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 6 ENC_ENTRY 2, 4, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 7 ENC_ENTRY 2, 6, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 8 ENC_ENTRY 3, 0, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 9 ENC_ENTRY 3, 2, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 10 ENC_ENTRY 3, 4, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 11 ENC_ENTRY 3, 6, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 12 ENC_ENTRY 4, 0, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 13 ENC_ENTRY 4, 2, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 14 ENC_ENTRY 4, 4, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 15 ENC_ENTRY 4, 6, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 16 ;; encoders 17-32 ENC_EOT ENC_EOTNow only the first encoder gives a signal in MIOS but the other 15 don't. I've got a DIN module right @ the CORE @ pin 9 with 16 ALPS encoder to it.I think my code isn't ok but I can't find the problem.My final design contains 96 buttons, 16 encoders, 17 sliders and 38 leds. Which example from the ucapps-site should I use to re-write. Is somebody help me programming this thingie?thanxechelon
TK. Posted March 3, 2004 Report Posted March 3, 2004 Did you try the ENC example 1?Then you should continue with ENC example 2 which handles more than 1 encoder... (it always makes sense to read the comments in main.asm ;-))Best Regards, Thorsten.
Guest echelon Posted March 4, 2004 Report Posted March 4, 2004 Thanx Thorsten,I just re-edited the 'mios_tables.inc' from the encoder1 example but didn't read the info in the 'main.asm.'I'll have a look @ it and will try it again... :D
intosite Posted April 17, 2004 Report Posted April 17, 2004 Hi,WHere can i get more infomation for editing the mios_tables.inc file?With trial and error i only concluded thatMT_ENTRY 0x90, 0x00 - is a note &MT_ENTRY 0xb0, 0x00 - is a controller.Is there some where that lists out what the rest like 0x00,0x01... are used to patch to?Cheers. :)
raphael Posted April 19, 2004 Report Posted April 19, 2004 Hi,Just fire up Google and search for "midi specification"...What you are looking for:8 = Note Off9 = Note OnA = AfterTouch (ie, key pressure)B = Control ChangeC = Program (patch) changeD = Channel PressureE = Pitch WheelThe lower Nibble (4 Bits) is the MIDI-Chanel:0x92 means Note On, Channel 2 0x8F means Note Off, Channel 16 Hope this helpsRaphael
intosite Posted April 19, 2004 Report Posted April 19, 2004 Thanks for the list.I've getting some problems. I connected 8 pots to a AIN4X. I'm using the MIOS AIN64 DIN128 DIO128 app.In the mios_table, i put "MT_EOT" for the pots section. THen for the first eight i placed :MT_ENTRY 0xb0, 0x10-18. The problem is, when i open one of 2 certain pots, i get lots of random data. When all closed, i can only work 4 pots. But each of this pot sends 2 sets of sysex eg B0-14 and B0-15 or B0-13 and B0-17 for another pot. What's went wrong?
Guest Romanoff Posted April 19, 2004 Report Posted April 19, 2004 Hey intosite,you have to connect the unused J's of your AIN4 to groundGreetings, Romanoff
intosite Posted April 19, 2004 Report Posted April 19, 2004 Do i still have to do that after i do the MT_EOT in the mios-table.ini file?
