tom303 Posted April 26, 2004 Report Posted April 26, 2004 I want to connect two 24LC256 for my Sequencer V2.0. I connected the two Eeproms like described in the circuid diagramm (Schematic for multiple bankstick setup):http://www.ucapps.de/mbhp_bankstick.htmlEeprom1 is A0 Eeprom2 is A1Then I modified the 'main.asm':#define DEFAULT_BANKSTICK_PATTERN_CS 0#define DEFAULT_BANKSTICK_SONG_CS 1Pattern save is working, Song is still NOT working...Are there other files or definitions to change?Thanks for any help... Quote
TK. Posted April 26, 2004 Report Posted April 26, 2004 To which of your two equal postings should I answer?Best Regards, Thorsten. Quote
tom303 Posted April 27, 2004 Author Report Posted April 27, 2004 This one ;)Sorry, thought no one is reading the other. Thats why I wrote the it more specific. May you can delete the other post. - Thanks. Quote
pay_c Posted April 27, 2004 Report Posted April 27, 2004 The reason was more like that nobody knew what to do.I really guessed that this prob was done with changing the main.asm.As you wrote it´s not... I hadn´t any more ideas what to do.Anyhow: Greets! Quote
TK. Posted April 28, 2004 Report Posted April 28, 2004 I guess that you are using the vintage setup, so possibly setup_mbseq_vintage.syx?This would mean that you have to change setup_mbseq_vintage.asm, and you have to assemble this file instead of main.asmBest Regards, Thorsten. Quote
tom303 Posted April 28, 2004 Author Report Posted April 28, 2004 No, I made the new V2 (with Alps encoders etc.) like you did. So I use the main.asm.Greetings,Thomas Quote
TK. Posted April 28, 2004 Report Posted April 28, 2004 How does MBSEQ behave with:#define DEFAULT_BANKSTICK_PATTERN_CS 1#define DEFAULT_BANKSTICK_SONG_CS 0?Best Regards, Thorsten. Quote
tom303 Posted April 29, 2004 Author Report Posted April 29, 2004 After rebooting und formatting , the same. - No bankstick for song.Best regards,Thomas Quote
TK. Posted April 29, 2004 Report Posted April 29, 2004 Ok, I found the error: it doesn't work with two 32k BankSticks since there is a test which ensures that a 64k BankStick is connected before formating the song partition. This function should not be called on two different 32k BankSticks of course.I tested it with two 24LC512 - and this test passed, therefore I didn't know about this issue.However, you will find a patch under http://www.ucapps.de/tmp/mbseq_v2_0_bs_fix.zip - it will be part of the next release.Best Regards, Thorsten. Quote
tom303 Posted April 30, 2004 Author Report Posted April 30, 2004 Thank you Thorsten, Songmode is working now!!!I send you pictures as soon as I get my frontplate. For now I have just a prov. wood front. Best regards,Thomas Quote
