intosite Posted April 28, 2004 Posted April 28, 2004 Hi,Was searching for nice cheap bts, and came across these. Not sure if the work fine for the DINs as i'm new to electronics. Someone mind having a look at the specs and let me know?Link to their site with a pdf spec.http://www.shanpu.com.tw/02_products/edmview.php?hID=3Their service is great though i have yet to order anything. Replies any queries in a day. Ship to anywhere. Here's what they quoted me. 1&2 , 3&4 are the same except their contacts are gold or silver, just wondering is there a diff in cost. Which is a better choice?[table][tr][td]Item No. [/td][td]Product No. [/td][td]DESCRIPTION [/td][td]U/P Ex-work [/td] [/tr][tr][td]1 [/td][td]SPL12P-4-00-FC-S [/td][td]SPL12P Tact switch, with white cap, non-LED, Flat transparent cover, Silver terminal [/td][td]US$0.41 [/td][/tr][tr][td]2 [/td][td]SPL12P-4-00-FC-G [/td][td]SPL12P Tact switch, with white cap, non-LED, Flat transparent cover, Gold terminal [/td][td]US$0.41 [/td][/tr][tr][td]3 [/td][td]SPL12P-4-04-FC-S [/td][td]SPL12P Tact switch, with white cap, White LED, Flat transparent cover, Silver terminal [/td][td]US$1.57 [/td][/tr][tr][td]4 [/td][td]SPL12P-4-04-FC-G [/td][td]SPL12P Tact switch, with white cap, White LED, Flat transparent cover, Gold terminal [/td][td]US$1.57 [/td][/tr][tr][td]5 [/td][td]SPL12P-x-xx-00-x [/td][td]SPL12P Tact switch, with cap, with LED(standard Red, yellow, Green), non-transparent cover, Gold or Silver terminal [/td][td]US$0.59[/td][/tr] [tr][td]6 [/td][td]SPL12P-0-00-xx-0 [/td][td]Transparent cover for SPL12 Series [/td][td]US$0.10 [/td][/tr][/table]CheersIsaac
intosite Posted May 4, 2004 Author Posted May 4, 2004 The illuminated ones uses surfance mount chip leds. Just wondering are the really small and difficult to solder down?Cause the radioshacks i've been to around my place, the only ones they have are like 2mm by 1mm.Cheers
intosite Posted May 26, 2004 Author Posted May 26, 2004 Just an update...Here are some i got for myself.Cheers :)
neodjandre Posted December 11, 2004 Posted December 11, 2004 introsite would you recommend these buttons for heavy use with dj software Traktor Dj Studio. What's their response and how do they feel like ? I would also like to have two types of buttons, those that "click" when you press them and those which just kick back when you press them. thanx As a last note, those buttons which "click" will have a LED next to them to indicate their "clicked" status. As a result I might buy these buttons with build-in LEDS to avoid having the DOUTX elements.. Again, are there any good for my purposes ?I only found these: comments?http://www.rjs-electronics.co.uk/cms/html/modules.php?set_albumName=album06&id=Fujisoku_TM_TR&op=modload&name=gallery&file=index&include=view_photo.php
Sasha Posted April 19, 2005 Posted April 19, 2005 In description for these buttons they say "Tactile feeling". What does it means? Soft touch, or the way they respond to pressing?Check out these 4 direction buttons.(also Shanpu) Great for menu navigation!
Screaming_Rabbit Posted April 19, 2005 Posted April 19, 2005 In description for these buttons they say "Tactile feeling". What does it means? Soft touch, or the way they respond to pressing?... the way they respond... it's like a "click", when you press them. Means you feal and hear it, when you're actuating them.Greets, Roger
Sasha Posted April 19, 2005 Posted April 19, 2005 Cool! So, you feel it is on with all your sences. ;D Thx for explanetion
