MidiboxLC Won't Display Host Messages
xile
I've been working on this for a couple of weeks, but I've tried everything I can think of for now.
I'm using the MidiboxLC application with 2 2x40 CLCD displays.  Host program is Sonar, but I had the same result with a friend's PC using Cubase.
Also, I'm using the Sonar patch to the lc_mproc.inc file referenced in the topic "Midibox LC and Sonar Question".
I have tested the 2 LCDs and they appear to be working correctly.  I've tried the sysex commands that allow writes to the screen and they work.
I've also tried version commands:
f0 00 00 66 14 13 f7
... and I get the proper response.
I've even written gibberish to the LCD using the MTC Write command:
f0 00 00 66 14 10 ..... f7
However, from what I can tell, the midibox is not responding to the Write_LCD command:
f0 00 00 66 14 12 .... f7
There are definately changes in the Sonar mod file, lc_mproc.inc, that appear to relate to this command that are not in the file in 1.4 MidiboxLC distribution.  Unfortunately, when I modify the Sonar mod file to match the original except for the MC Query addition, the file won't compile properly.
Also, I tried the GPC mode and MF Cali mode and the display seemed to work fine.
Also, I had another problem early on that related to the lc_init.inc file.  I believe the line:
#if LCD_USE_SECOND
... should read:
#if LCD_USE_SECOND == 1
... in order to get the 2 LCDs to display properly.  How do I get this suggestion checked out and the file changed if necessary?
Thanks.
xile
the result of
#if LCD_USE_SECOND
and
is the same, so this cannot be the reason.
The only changes of the modified lc_mproc.inc and the original lc_mproc.inc of v1.4 are:
[avatar@britannia mblc_sonar_mod]$ diff -c /mnt/data/mios_apps/release/midibox_lc_v1_4/lc_mproc.inc lc_mproc.inc
*** /mnt/data/mios_apps/release/midibox_lc_v1_4/lc_mproc.inc  2003-09-29 14:22:28.000000000 +0200
--- lc_mproc.inc        2004-03-29 01:43:07.000000000 +0200
*** 360,365 ****
--- 360,369 ----
        bz      LC_MPROC_Action_Query
        movf    LC_MPROC_ACTION, W
+       xorlw   0x1a
+       bz      LC_MPROC_Action_MCQuery
+       movf    LC_MPROC_ACTION, W
        xorlw   0x02
        bz      LC_MPROC_Action_HostReply
*** 373,379 ****
        xorlw   0x12
!       bz      LC_MPROC_Action_WriteLCD
        xorlw   0x13
--- 377,384 ----
        xorlw   0x12
!       skpnz
!       rgoto   LC_MPROC_Action_WriteLCD
        xorlw   0x13
*** 427,432 ****
--- 432,463 ----
        rgoto   LC_MPROC_ActionFinished
+ ;;  MIDI Action: MC Query (undocumented)
+ LC_MPROC_Action_MCQuery
+       ;; wait until sysex footer (F7) has been received
+       movlw   0xf7
+       IFNEQ   LC_MPROC_IN, ACCESS, rgoto LC_MPROC_SysExCheck_End
+       ;; send SysEx header
+       call    LC_MPROC_Send_SysExHeader
+       ;; send reply
+       movlw   0x1b
+       call    MIOS_MIDI_TxBufferPut
+       ;; send dummy byte (seems to work)
+       movlw   0x42
+       ;; send of SysEx footer
+       movlw   0x01            ; (independend from merger state)
+       call    LC_MPROC_Send_SysExFooter
+       ;; finish Action
+       rgoto   LC_MPROC_ActionFinished
  ;;  MIDI Action: LC Host Reply
so: the new LC_MPROC_Action_MCQuery
and a change for the LC_MPROC_Action_WriteLCD branch (distance between the "bz" and the function was > 128 bytes, therefore a rgoto has to be used).
It should work if you just overwrite the old lc_mproc.inc with the modified one. Maybe you've modified the source code in a way which prevents the LC_MPROC_Action_WriteLCD function from being called...
So, to make one of these work with Sonar, theres a recompile involved?
Any chance of updating the code that needs to be flashed (or downloaded) that's available directly from the site?
I haven't gotten familiar enough with the code yet to tackle a re-compile!
Well, the host messages are now displaying properly.  I started over with a clean build, but that wasn't the problem.  It turns out that that combination of MidiOx and my USB midi interface seem to be the problem.  When I bypassed MidiOx, the USB interface would work, even though it wasn't perfect all the time.
I have another midi interface and it's working properly, even with MidiOx.
xile
