Twin-X Posted June 4, 2004 Posted June 4, 2004 If i have completed my quad sid how can i or must i :A: update the mios or sid software? Do they go all at once? Or must i flash them seperatly (stuff unstuff).B: change midi chanel for each sid (or do i have only 1 midichannel?) trough control surface.Thx in advance
TK. Posted June 4, 2004 Posted June 4, 2004 Hi Twin-X,there is a new description which describes the required steps:http://www.ucapps.de/midibox_sid_csB.html(search for "Preparation of PIC18F cores")Once this has been done, you can change the MIDIchannel of each SID (seperately of course...) in the CFG menuBest Regards, Thorsten.
Twin-X Posted June 5, 2004 Author Posted June 5, 2004 Preparation of PIC18F coresStep by step:I read this over and over and over :DDo i stuff all cores at once. Power the unit.Use the link cable of JDM to prepare the master and finish it all. After testing sid 1 i connect this cable to slaves 1 by 1? And repeat the procedure (according to the steps in the step by step guide)Sorry if i sound confusingp.s. the cores j10 only have 4 wires connected right?
TK. Posted June 5, 2004 Posted June 5, 2004 Hi,are these questions or conclusions? ;-) Of course, if you haven't programmed the bootloader into the slaves, it's time to do it now. And please don't forget to set the ID of the slaves to 1, 2 and 3!J10 has 4 connections if the ground is already connected from the power supply unit to the SID module --- compare the wiring with http://www.ucapps.de/mbhp/mbhp_4xsid_c64_psu_optimized.pdfBest Regards, Thorsten.
