Phatline Posted November 30, 2022 Posted November 30, 2022 hei i am currently working on a BLM16x16+X. based on the improvements released here: blm16x16_build_guide Orginal-Circuit: Improved Circuit: The Kicad-Files for it: BLM-Scalar-einfach.zip All shematic Symbols have SMD-Parts (with 3D bodys) assigned, also MouserPart Numbers are assigned ---but: its not routed - since i will integrate this circuit (like LatigidON did) on the BLM-PCB itself. - I have no interest to Route the Scalar PCB itself - but its a good starting point - if somebody want to make a own PCB. based on that, i am currently working on a BLM16x16+X: I hope i made no mistakes in the shematic...
forestcaver Posted December 4, 2022 Posted December 4, 2022 Nice! What are you planning on using for buttons/pads?
Phatline Posted December 4, 2022 Author Posted December 4, 2022 8 hours ago, forestcaver said: Nice! What are you planning on using for buttons/pads? adafruit rubber button 4x4 1
forestcaver Posted December 5, 2022 Posted December 5, 2022 Nice (I’ve used them for a couple of projects in the neotrellis) - it’ll be really nice and compact - I’d be really keen to build one when you finish it :-)
Phatline Posted December 5, 2022 Author Posted December 5, 2022 this will take a while - look into the forum in 5 weeks or so. i need the PCB to make a new version off Triggermatrix (http://wiki.midibox.org/doku.php?id=triggermatrix4) the Frontpanel is not a generic MatrixController thing - it has 17 Displays, 8 Faders, some rotarys and buttons, the Software for this is not a normal Midicontroller-code (aka Midibox NG) - its my own creation a sequencer based on MIOS. - but if i not make a shematic mistake, the pcb should be usable like the orginal BLM16*16+X in other Midibox Projects. 1
Phatline Posted February 9, 2023 Author Posted February 9, 2023 looking good... have not tested all buttons (since i am waiting for Silicon-Pads, and 1N4148) - but i guess everthing is ok...
