hi there!
after solving my problems with my pots i'm having new troubles
my buttons don't want to work except one of the menu buttons ... don't know what it is because i haven't got a lcd on my box but i think its the exec... i see a lot of note of events in midiox but when i press one of the other buttons nothing happens. what could it be? have i shot the ic's with the earlier troubleshooting?
thx
greez
it seems that either the SCLK or the RCLK line isn't connected properly or has a short. So, just check these signals visually (measuring the voltages is useless here) from the core module (PIC Pin #21 and #22) to the DINX4 modules (pin #1 and #2 of each 74HC165).
It occurred to me while reading this thread (and many others here) that many MIDIBox builders could benefit from having a logic probe to perform troubleshooting on their projects. Most builders here cannot afford or justify the purchase of an oscilloscope. A logic probe is an inexpensive yet powerful tool for troubleshooting digital circuitry. Here is a link to one example of such a probe.
http://kitsrus.com/projects/k24.pdf
A search on the Internet for “DIY Logic Probe†reveals many other such cheap to build logic probes Although I am fortunate enough to own an oscilloscope I use my logic probe regularly when troubleshooting digital circuitry.
Hope this info is useful.  :)
thx man ....  i'll try this. and also thorstens hint. even the logic probe isn't usefull it's almost better than nothing ;o) and good to know about something also for other projects
but for now i got kicked back to the roots and have to debug my midi in again bcause the pic doesn't recieve midi in anymore :o((( yesterday it worked but now it doesn't want to anymore. also replaced the optocoupler already but didn't help...
ok...i'm a stupid nerd... had swapped the cables from the midi in somehow as i replaced the cable but buttons don't work but i haven't really began debugging
can it be that all of them don't work if one of them is faulty?
greez
No,
if one button is pressed steady (thats the only way a button can become faulty) all others should work !
Doc
ok thx
i figured out that i have a connection between Vs and SC on the din ... this souldn't be... should it? so i have to look for a short i think
pinning of the connection is ok
no connection between Gnd and SC....
I also think it's a short....
Please measure it without the ic's stuffed. Look espec. for solder bridges.
Doc
already had measured it without them
yes was a really tricky short at the bridges at the ic sockets. i sticked the cable through the hole and it got short at the top-side at the ic sockets gnd pin....
but noooow ..... it wooooooooorks ;o)
in midiox the events when a pot is moved are always reverb depth ... should be ok?!
thx men for your assistance :o)
greez
