TK. Posted July 11, 2004 Posted July 11, 2004 Triggered from the midiboxchat today I evalued the SDCC, an open source C compiler which is available under http://sdcc.sourceforge.net.I programmed a so called "wrapper" which maps some of the MIOS functions to the C world, so that they are accessible as common C functions: extern void MIOS_LCD_Clear(void); extern void MIOS_LCD_CursorSet(char pos); extern void MIOS_LCD_PrintChar(char c); extern void MIOS_LCD_PrintString(char *str); extern void MIOS_LCD_PrintPreconfString(char *str); Two MIOS hooks directly branched to the C program: USER_Init extern _CMIOS_Init goto _CMIOS_Init USER_DISPLAY_Init extern _CMIOS_DISPLAY_Init goto _CMIOS_DISPLAY_Init so that following C code was possible: void CMIOS_Init(void) { } void CMIOS_DISPLAY_Init(void) { MIOS_LCD_Clear(); MIOS_LCD_CursorSet(0x00); MIOS_LCD_PrintChar('1'); MIOS_LCD_PrintChar('2'); MIOS_LCD_PrintChar('3'); } This was working and the resulting assembler code looked exactly like I would program it in assembler. Then I tried to output a string: static char[] = {12, 0x00, "Hello World!"} void CMIOS_DISPLAY_Init(void) { MIOS_LCD_Clear(); MIOS_LCD_PrintString(hello_world); } But the static string above produced a table with following entries _hello_world db 0x0c, 0x00, 0xa8 It seems that the compiler feels confused about a mix of constant values and characters Next try: void CMIOS_DISPLAY_Init(void) { MIOS_LCD_Clear(); MIOS_LCD_CursorSet(0x00); MIOS_LCD_PrintPreconfString("Hello World!"); } but no luck: the compiler crashed with a signal error - bad, it seems that the PIC18F module hasn't been programmed properly enough. Last try: void CMIOS_DISPLAY_Init(void) { int i; MIOS_LCD_Clear(); MIOS_LCD_CursorSet(0x00); for(i=0; i<3; ++i) { MIOS_LCD_PrintChar('A' + xx); } } This produced so much assembler code that it was definitely clear to me that SDCC is the wrong way to program a powerfull application: ;#LINE 7; main.c void CMIOS_DISPLAY_Init(void) MOVFF FSR2L, POSTDEC1 MOVFF FSR1L, FSR2L MOVFF r0x10, POSTDEC1 MOVFF r0x11, POSTDEC1 ;#LINE 11; main.c MIOS_LCD_Clear(); CALL _MIOS_LCD_Clear ;#LINE 12; main.c MIOS_LCD_CursorSet(0x00); MOVLW 0x00 CALL _MIOS_LCD_CursorSet ;#LINE 14; main.c for(i=0; i<3; ++i) CLRF r0x10 _00109_DS_: MOVLW 0x03 SUBWF r0x10, W BTFSC STATUS,0 GOTO _00113_DS_ ;#LINE 16; main.c MIOS_LCD_PrintChar('A' + i); MOVLW 0x41 ADDWF r0x10, W MOVWF r0x11 MOVF r0x11, W CALL _MIOS_LCD_PrintChar ;#LINE 14; main.c for(i=0; i<3; ++i) INCF r0x10, F GOTO _00109_DS_ _00113_DS_: MOVFF PREINC1, r0x11 MOVFF PREINC1, r0x10 ;;genEndFunction: _G.nRegsSaved upon exit from function: 0 MOVFF PREINC1, FSR2L RETURN Just to compare it with handwritten assembler code: _CMIOS_DISPLAY_Init: ;; stack handling excluded here call MIOS_LCD_Clear movlw 0x00 call MIOS_LCD_CursorSet clrf r0x10 _CMIOS_DISPLAY_Init_Loop: movlw 0x41 addwf rx010, W call MIOS_LCD_PrintChar incf rx010, F movlw 0x03-1 cpfsgt rx010 bra _CMIOS_DISPLAY_Init_Loop ;; stack handling excluded here return Conclusion: the SDCC crashes sometimes and will therefore be hard to use for people who just want to write some lines of code without knowing about those quirks the code optimization is far from perfection, it seems that the compiler doesn't know about all those nice new PIC18F instructions which help to make the code shorter the compiler produces too much code, therefore the applications cannot include so much features anymore the compiler allocates all three pointers (FSR0-FSR2), therefore some code changes will be required in MIOS which will slow down the system (especially on interrupts) who knows which problems I haven't seen yet...I'm not sure if currently the C approach is worth the effort... Best Regards, Thorsten.
moebius Posted July 12, 2004 Posted July 12, 2004 So,I can't code,so I rather do it in C.. or someone will.. ;) T. Have you consulted those ppl, makeing SDCC? Last time I googled for "free PIC c compiler", SDCC didn't support anything but 16(F/C)**sorry, Moebius
TK. Posted July 13, 2004 Author Posted July 13, 2004 Hi,SDCC has a special "pic16" module, and pic16 means "16 bit architecture" here - thats the PIC18F familyHowever, rumors told me that there will be some improvements in the future which will allow to interact with MIOS without big performance loss.Best Regards, Thorsten.
TK. Posted July 14, 2004 Author Posted July 14, 2004 Good news: I'm in contact with Vangelis, the developer of the PIC16 SDCC module. Maybe we will find a good solution to improve the interaction with MIOS, and to optimize the assembler output :)Best Regards, Thorsten.
pilo Posted July 15, 2004 Posted July 15, 2004 hehe!!! that's a great news!!!! ;DI can't wait!!!!!!!!!!
moebius Posted July 15, 2004 Posted July 15, 2004 Good news: I'm in contact with Vangelis..That must be good news for anyone liking electronic music or PIC....(did YOU know he's that multitalented :) )Bye, Moebius
TK. Posted July 18, 2004 Author Posted July 18, 2004 Here a first insight into a C programming example: #include "cmios.h" //#include <pic18f452.h> ///////////////////////////////////////////////////////////////////////////// // This function is called by MIOS after startup to initialize the // application ///////////////////////////////////////////////////////////////////////////// void Init(void) { // define number of shift registers MIOS_SRIO_NumberSet(16); // update frequency of SRIO chain MIOS_SRIO_UpdateFrqSet(1); // ms } ///////////////////////////////////////////////////////////////////////////// // This function is called by MIOS in the mainloop when nothing else is to do ///////////////////////////////////////////////////////////////////////////// void Tick(void) { } ///////////////////////////////////////////////////////////////////////////// // This function is called by MIOS when the display content should be // initialized. Thats the case during startup and after a temporary message // has been printed on the screen ///////////////////////////////////////////////////////////////////////////// void DISPLAY_Init(void) { // clear screen MIOS_LCD_Clear(); // print message MIOS_LCD_CursorSet(0x00); MIOS_LCD_PrintCString("Press Button"); } ///////////////////////////////////////////////////////////////////////////// // This function is called in the mainloop when no temporary message is shown // on screen. Print the realtime messages here ///////////////////////////////////////////////////////////////////////////// void DISPLAY_Tick(void) { } ///////////////////////////////////////////////////////////////////////////// // This function is called by MIOS when a complete MIDI event has been received ///////////////////////////////////////////////////////////////////////////// void MPROC_NotifyReceivedEvnt(unsigned char evnt0, unsigned char evnt1, unsigned char evnt2) { // print received MIDI event MIOS_LCD_Clear(); MIOS_LCD_PrintCString("Received:"); MIOS_LCD_CursorSet(0x40); MIOS_LCD_PrintHex2(evnt0); MIOS_LCD_PrintHex2(evnt1); MIOS_LCD_PrintHex2(evnt2); } ///////////////////////////////////////////////////////////////////////////// // This function is called by MIOS when a MIDI event has been received // which has been specified in the MIOS_MPROC_EVENT_TABLE ///////////////////////////////////////////////////////////////////////////// void MPROC_NotifyFoundEvent(unsigned entry, unsigned char evnt0, unsigned char evnt1, unsigned char envt2) { } ///////////////////////////////////////////////////////////////////////////// // This function is called by MIOS when a MIDI event has not been completly // received within 2 seconds ///////////////////////////////////////////////////////////////////////////// void MPROC_NotifyTimeout(void) { } ///////////////////////////////////////////////////////////////////////////// // This function is called by MIOS when a MIDI byte has been received ///////////////////////////////////////////////////////////////////////////// void MPROC_NotifyReceivedByte(unsigned char byte) { } ///////////////////////////////////////////////////////////////////////////// // This function is called by MIOS when an button has been toggled // pin_value is 1 when button released, and 0 when button pressed ///////////////////////////////////////////////////////////////////////////// void DIN_NotifyToggle(unsigned char pin, unsigned char pin_value) { MIOS_LCD_Clear(); MIOS_LCD_PrintCString("DIN #"); MIOS_LCD_PrintBCD3(pin); MIOS_LCD_PrintCString(pin_value ? " off" : " on"); MIOS_LCD_CursorSet(0x40); switch( pin ) { case 0: MIOS_LCD_PrintCString("Sending a Note"); MIOS_MIDI_TxBufferPut(0x90); MIOS_MIDI_TxBufferPut(pin); MIOS_MIDI_TxBufferPut(pin_value ? 0x00 : 0x7f); break; case 1: MIOS_LCD_PrintCString("Sending a CC"); MIOS_MIDI_TxBufferPut(0xb0); MIOS_MIDI_TxBufferPut(pin); MIOS_MIDI_TxBufferPut(pin_value ? 0x00 : 0x7f); break; case 2: MIOS_LCD_PrintCString("Sending SysEx"); MIOS_MIDI_TxBufferPut(0xf0); MIOS_MIDI_TxBufferPut(0x11); MIOS_MIDI_TxBufferPut(0x22); MIOS_MIDI_TxBufferPut(0x33); MIOS_MIDI_TxBufferPut(0x44); MIOS_MIDI_TxBufferPut(pin); MIOS_MIDI_TxBufferPut(pin_value ? 0x00 : 0x7f); MIOS_MIDI_TxBufferPut(0xf7); break; default: MIOS_LCD_PrintCString("No action"); } } ///////////////////////////////////////////////////////////////////////////// // This function is called by MIOS when an encoder has been moved // incrementer is positive when encoder has been turned clockwise, else // it is negative ///////////////////////////////////////////////////////////////////////////// void ENC_NotifyChange(unsigned char encoder, unsigned char incrementer) { } ///////////////////////////////////////////////////////////////////////////// // This function is called by MIOS when a pot has been moved ///////////////////////////////////////////////////////////////////////////// void AIN_NotifyChange(unsigned char pin, unsigned int pin_value) { } all MIOS functions are now accessible from CI've written a small script which builds workarounds into the generated assembler code. Some of them will be part of the next SDCC release.If anybody wants to beta-test the MIOS wrapper, just write me an email.Best Regards, Thorsten.
pilo Posted July 20, 2004 Posted July 20, 2004 I've got one question about this C stuff, is it possible to make big apps like the LC one?I wish to make a midibox like the digidesign ProControl to use with ardour (I don't know yet how ardour will works with control surface, as it's not fully working by now), and if can do this in C.... could be great as many switch can be used for more than one function (I think about making a finish state machine).
pilo Posted August 13, 2004 Posted August 13, 2004 here's the makefile for the mios C wrapper (using sdcc and gputils) : project.hex:    main.c    gpasm -c mios_wrapper/mios_wrapper.asm -I mios_wrapper -o mios_wrapper.o    sdcc -S -V -mpic16 -p18F452 --pomit-config-words --pomit-ivt -pleave-reset-vector main.c    perl tools/fixasm.pl main.asm    gpasm -c main.asm    gplink main.o mios_wrapper.o -s project.lkr -o project.hex    perl tools/hex2syx.pl project.hex gputils can be found here (open source pic asm compiler) :http://gputils.sourceforge.net/
Guest nomadicWhale Posted August 29, 2004 Posted August 29, 2004 2 things?1. How can I use global varaibles in a cmios application?Can I just define them as I would define them in a regular c program? will the linker know what addresses to assign to them so that they will not override mios reserved memory locations?Maybe someone have an example...2. Just to be safe, the project.syx produced by the make.bat file is the file I need to upload to my MB?ThanksnW
Guest nomadicWhale Posted September 1, 2004 Posted September 1, 2004 some updates...1. global varaibles can be defined as you ususal, out of the scope of any method.2. I'm currently having problems defining automatic varaibles (varaibles inside methods)... any help/example would be great.3. and obviously enough the project.sysx is the one to upload to mios....nW
Guest nomadicWhale Posted September 1, 2004 Posted September 1, 2004 why does the c package contains a mios_1_8 sysex file? is this mios needed for c mios?nW
TK. Posted September 2, 2004 Author Posted September 2, 2004 Thanks for the input, Pilo! :-)nW: yes, you can use global variables. Just look into the generated assembler file to see what SDCC is doing with these variables.Yes, you need the preliminary release of MIOS V1.8, otherwise your program will crash due to overwritten FSR2[LH]More infos can be found at the MIOS C introduction page:http://www.ucapps.de/mios_c.htmlBest Regards, Thorsten.
pilo Posted September 13, 2004 Posted September 13, 2004 I think there's a problem with MIOS_MF_FaderMove function, .MIOS_MF_FaderMove code _MIOS_MF_FaderMove global _MIOS_MF_FaderMove movwf MIOS_PARAMETER1 movff FSR0L, FSR2L movff PREINC2, MIOS_PARAMETER2 movff PREINC2, MIOS_PARAMETER1 goto MIOS_MF_FaderMove I put this instead of this : .MIOS_MF_FaderMove code _MIOS_MF_FaderMove global _MIOS_MF_FaderMove movwf MIOS_PARAMETER1 movff FSR0L, FSR2L movff PREINC2, MIOS_PARAMETER2 movf PREINC2, W goto MIOS_MF_FaderMoveAnd now it seems to work well.
TK. Posted September 13, 2004 Author Posted September 13, 2004 Hi Pilo,thanks for the input. I cannot explain while your variant should work better (since MIOS_PARAMETER1 is overwritten), but I will try this out with my MBLC hardware and bring the fixed code into the first official release.Best Regards, Thorsten.
pilo Posted September 13, 2004 Posted September 13, 2004 I cannot explain while your variant should work better I can't too... :-[Actually the problem was that pin and pin_value was inverted in C wrapper... so I try to put that in the right way. And I couldn't wait to test some C code ;) That's why I made this changed, without really knowing why it works (I try to put the right value in mios_parameter1 instead of W).By the way making apps with C and MIOS is real fun... ;D
TK. Posted September 13, 2004 Author Posted September 13, 2004 By the way making apps with C and MIOS is real fun... I hope so! :-)I must admit that I haven't worked on the C wrapper anymore after the night I wrote it ;-)So your error reports are really welcome :)Currently I'm working on vmidibox64 and vmidibox64e (C++ fun under windows), hope that I will find some time thereafter to finalize the wrapperBestRegards, Thorsten.
pilo Posted September 14, 2004 Posted September 14, 2004 hehe ;)I'm currently soldering the din and dout for the matrix stuff, then test it with C wrapper (I will include the matrix stuff in mios_wrapper.asm). Then I can start to ake more stuff :)As soon as I have a working setup(switch and encoder), I will make basics C tutorials (or maybe somebody else start this?), to show how it's easy now to make MIOS apps ;) I need to clean up and even rewrite the make file, the rules are wrong (I use rules for project.hex but the makefile convert it to syx, and I don't put rules for mios_wrapper.o).
grahamg Posted November 30, 2004 Posted November 30, 2004 I'm getting some stange LCD behavior with the wrapper: calls to MIOS_LCD_PrintCString result in black spaces between each character in the string. For example, "dog" prints as "d_o_g" where "_" represents a solid black block. If I use MIOS_LCD_PrintChar, everything works fine. Any ideas??!-Graham
TK. Posted December 3, 2004 Author Posted December 3, 2004 Hi Graham,it seems that the current sdcc snapshot doesn't work properly. :-/I've uploaded an older version and a new beta release of the C wrapper to the MIDIbox server - see next posting.Best Regards, Thorsten.
Wise Posted January 9, 2005 Posted January 9, 2005 How is "mode and period" defined in MIOS_TIMER_Init ?extern void MIOS_TIMER_Init(unsigned char mode, unsigned int period); Is the mode the prescaler and period in ms for: void Timer(void) to trigger ?Happy new year !/Wise
TK. Posted January 10, 2005 Author Posted January 10, 2005 Hi Wise,"unsigned int period" is not the period in milliseconds, but the number of clocks (with mode as prescaler) to trigger USER_Tick. An calculation example can be found in the MIOS documentation (http://www.ucapps.de/mios_fun.html#MIOS_TIMER_Init)Best Regards, Thorsten.
Wise Posted January 15, 2005 Posted January 15, 2005 Thanks TK !The timer is up and running as a swiss clock now :)Now I have some other problems, but I don't think this is the right thread to ask them in. So how about a new topic under "MIOS programming", "C programming" or something like that ? Just to separate "MIOS asm" and "MIOS C"./Wise
TK. Posted January 15, 2005 Author Posted January 15, 2005 Hi Wise,I will open a new section once the C wrapper is officially released. In the meantime you can ask in a seperate thread.Btw. - the current status: in the last weeks some changes were included into SDCC which makes it incompatible to the wrapper. In the meantime I was able to adapt it to the changes, but there are still some open issues which have to be solved. Issues means here: bugs in the compiler. From time to time I'm submitting bug reports to the SDCC bug database, they were always fixed immediately. So, there is hope that we get the things sorted in 2-3 weeks.Best Regards, Thorsten.
