Core - Midi Out Problem
Julian
hi =)
my MIDISid is working fine so far, but the midi out isn't working.
whenever i plu both midi cables (in and out from my computer) there is a strange noise on the audio out. sounds like some kind of midi data because when i start the "get" function in jsynthlib (start a sysex dump) i hear rapid changings in the noise but the dump isns working :(
and this high noise appearing when i plug the midi out to my computer is really loud/annoying, too.
best,
julian
Link to comment
Share on other sites
...hard  to give an exact advise then.
Sounds like a kind of ground loop/problem.
- Are the connections from the core to midi rather short?
- Did you connect ground from the core to your midi-port (disconnect this!) ?
- Do you use a shielded cable from Core to Midi-plugs ?
 (if you do: Please pay attention, that the shield of the cable is only connected to the core. The other side should not be connected)
- Do you have multiple Cores interconnected ? - if so, check twice your connection. You can also use  shielded cable for interconnection
Did you connect the audio out of your SID to the PC audio In ? - If so: Just try this connection without the shield of your SID Audio Out. Still noisy ?
greets
Doc
Link to comment
hehe, at the moment a rather long cable
>- Did you connect ground from the core to your midi-port (disconnect >this!) ?
nope
no, just one so far
>Did you connect the audio out of your SID to the PC audio In ? - If >so: Just try this connection without the shield of your SID Audio Out. >Still noisy ?
the midi signals come from my PC
the audio outs from the SID are connected with a small Mixer and another computers audio in. so there should be no interferences...
I think i'll just try to remove the ground... I'll post if it helps
greetings,
jul
Link to comment
Not really right. You still could get interferences via your ground connection (earth of the pc's).
Can you try it with a short shielded Midi-cable (no ground connected) and perhaps a headphone plugged in the SID Audio Out ? - Just to ensure....
Of course your Audio signal will be very low. But do you still have a noise, when you plug the midi OUT in ?
If you have a little high noise (like arumblack said) - there is nothing you can do against it - thats analog audio !
But if you have a impendance problem or a ground loop it should disapear if you connect a headphone to the Audio out of the sid.
When no midi cable is connected you have no noise, right ? - If so, it couldn't be the normal sid noise!
If all this doesn't help twice check the audio part of the sid (transistor in the right direction ? - caps poled right? - all ground pins connected ? Audio IN must be grounded/shorted! and so on)
greets
Doc
Link to comment
Guest
Reply to this topic...
