flyweight Posted October 9, 2023 Posted October 9, 2023 (edited) Hi it's been a while, From this project I learned so much. And I finally finished and fixed my midibox. I checked the documentation but it's not clear to me if and how its possible to use multiple Aout-ng's with midibox v4. Can I use multiple Aout-ng's? How would I connect them? Can I still use the line driver? There is J2 and the documentation is stating no app makes use of this but it is meant for connecting multiple boards. Also in the config I can select up to 32 for the cv channel. Thanks a lot, Cheers T Edited October 9, 2023 by flyweight Line driver
TK. Posted October 10, 2023 Posted October 10, 2023 Hi, yes, meanwhile up to 4 AOUT or AOUT_NG modules can be chained. Module 2..4 can be accessed via MIDI Port 2..4, and each MIDI channel gives you control over 8 CV outputs and 8 gates (-> makes up to 32 CV channels and gates) Only the first AOUT_NG module should be connected to a line driver. Best Regards, Thorsten.
flyweight Posted October 10, 2023 Author Posted October 10, 2023 Hi Thorsten, Thanks for the swift reply and this amazing machine. That is great news that that is possible. 32cv's is insanely a lot. I think with sweet 16 i would be happy enough :) But probably i will get greedy. The most important i learned is not to buy 595-TLV5630IDW from evil bay as that did not work out the first time :) Ah not sure why but googling aou-ng j2 gave me a good post:
flyweight Posted October 10, 2023 Author Posted October 10, 2023 26 minutes ago, flyweight said: But probably i will get greedy. Ohh yes I did, I order 3 pcb's :-)
