ksir Posted October 25, 2023 Posted October 25, 2023 Hello, I have a tw56640320b03 screen, is it possible to make it work with midibox ng? THANKS https://s.alicdn.com/@sc01/kf/HTB19t6LcXkoBKNjSZFkq6z4tFXa3/232025343/HTB19t6LcXkoBKNjSZFkq6z4tFXa3.jpg
TK. Posted October 26, 2023 Posted October 26, 2023 Yes, this one should work Here the interconnections: http://www.midibox.org/dokuwiki/lib/exe/fetch.php?media=neonking:ssd1322-pinout.jpg In order to select the display in MIOS32, upload the Bootloader Update Application and enter: set lcd_type GLCD_SSD1322 set lcd_num_x 1 set lcd_num_y 1 set lcd_width 256 set lcd_height 64 store Thereafter upload the MIDIbox NG application again -> display should show some meaningful messages Best Regards, Thorsten.
ksir Posted October 28, 2023 Author Posted October 28, 2023 (edited) THANKS . I don't understand the interconnection diagram clearly. My screen has 16 pins not 20 pins and the name of the pins on the seller's diagram does not correspond. hence my confusion ( https://fr.aliexpress.com/item/32414142892.html?gatewayAdapt=glo2fra ) I just tried to match : it's ok ? i can't fide GLCD_SSD1322 Edited October 28, 2023 by ksir
TK. Posted October 28, 2023 Posted October 28, 2023 Ok, I've to admit that I haven't checked the current state of the driver before my reply Unfortunately it isn't available - last posting about this activity was more than 10 years ago: I fear that nobody can help you to get it running :-( Best Regards, Thorsten.
