i had the same idea of you. i  originally planned to put the sequencer and 2 sids in the same case, sharing the same control surface and LCD.
then the sids didnt worked, so for now i have only the seq...
my idea was to use a switch with a lot of poles, like to one that was used to switch between to parallel printer (in old computers, usually this "device" was found in some offices).
i would have connected the core LCD and the DIN DOUT pins (named Jx) o the switch and from here to the appropriate pin of its module.
i'm sure it will work, but i didnt tested.
PS: the power from LCD and modules in my project came from a custom "power module" and it wasn't connected to the multipole switch.
