k2z3k0 Posted April 5, 2024 Report Posted April 5, 2024 (edited) when restoring seq_ui_button_state.FAST_ENCODERS from recalled BM lights the led ,but FAST does not work, i tried also to seq_ui_button_state.FAST_ENCODERS = 1; when switching to MIXER page, and FAST led comes up but no effect can some one confirm? any ideas? best regards Edited April 5, 2024 by k2z3k0 dyslexia
TK. Posted April 12, 2024 Report Posted April 12, 2024 How could I reproduce this issue? Could you please give step-by-step instructions? Best Regards, Thorsten.
k2z3k0 Posted April 14, 2024 Author Report Posted April 14, 2024 (edited) On 4/12/2024 at 9:11 PM, TK. said: How could I reproduce this issue? Could you please give step-by-step instructions? Best Regards, Thorsten. hello T ok so i am on http://www.ucapps.de/mios32/midibox_seq_v4_098_pre2.zip fresh new project 1.make GLOBAL BOOKMARK #1 for DIVIDER with FAST ON, 2.FAST is ON and CLOCK GP #2 scrolls fast, 3.switch to EDIT page ,FAST is automatically turned off, 4.recall GLOBAL BOOKMARK #1 ,FAST is ON BUT not working,CLOCK GP #2 scrolls normal 5.switch to EDIT page,turn on FAST,recall BOOKMARK #1 now FAST is ON and working in SEQ_UI.C it says Quote s32 SEQ_UI_Bookmark_Store(u8 bookmark) { if( bookmark >= SEQ_UI_BOOKMARKS_NUM ) return -1; seq_ui_bookmark_t *bm = (seq_ui_bookmark_t *)&seq_ui_bookmarks[bookmark]; // note: name, enable flags and flags.LOCKED not overwritten! //bm->flags.SOLO = seq_ui_button_state.SOLO; bm->flags.CHANGE_ALL_STEPS = seq_ui_button_state.CHANGE_ALL_STEPS; bm->flags.FAST = seq_ui_button_state.FAST_ENCODERS; and to restore Quote s32 SEQ_UI_Bookmark_Restore(u8 bookmark) { if( bookmark >= SEQ_UI_BOOKMARKS_NUM ) return -1; seq_ui_bookmark_t *bm = (seq_ui_bookmark_t *)&seq_ui_bookmarks[bookmark]; // should be atomic portENTER_CRITICAL(); //if( bm->enable.SOLO ) seq_ui_button_state.SOLO = bm->flags.SOLO; if( bm->enable.CHANGE_ALL_STEPS ) seq_ui_button_state.CHANGE_ALL_STEPS = bm->flags.CHANGE_ALL_STEPS; if( bm->enable.FAST ) seq_ui_button_state.FAST_ENCODERS = bm->flags.FAST; i think there might be a bug somewhere,something missing it seems seq_ui_button_state.FAST_ENCODERS = 1 is turning FAST button LED on but not the FAST function when recalled from BOOKMARKS i also tried to use seq_ui_button_state.FAST_ENCODERS = 1 for example when switching to MIXER page so my encoders work fast in MIXER page,but same effect p.s. while i have your attention , in HUMANIZER there is 2nd option VEL/CC ,should that humanize VELOCITY and MIDI CC messages from PARAMETER LAYERS of the track? cause when i set track with one CC param HUMANIZER does not humanize that CC layer thank you for your time best regards Kazik Edited April 14, 2024 by k2z3k0
TK. Posted May 8, 2024 Report Posted May 8, 2024 Hi Kazik, 1) FAST button control with Bookmarks: this can only work if you disable the "ENC_AUTO_FAST" feature in your MBSEQ_HW.V4 file, which overrules interactive FAST button changes Background: with ENC_AUTO_FAST, FAST mode will be auto-selected depending on the selected parameter layer, and can be temporary (!) overruled by pressing the FAST button. Without this feature, FAST button has full control over the encoder behaviour 2) HUMANIZER changing CC values: works at my side, would need more input to give you guidance, please use the appr. thread to discuss at the right place Best Regards, Thorsten.
