ladybug Posted December 13, 2002 Report Posted December 13, 2002 is is possible to use a dial-selector with 16 positions instead of the 4 toggles, in order to select a bank - i think it more convenient using a dial/selector.(talkin bout MidiBox8)
ladybug Posted December 13, 2002 Author Report Posted December 13, 2002 is is possible to use a dial-selector with 16 positions instead of the 4 toggles, in order to select a bank - i think it more convenient using a dial/selector.(talkin bout MidiBox8)
TK. Posted December 14, 2002 Report Posted December 14, 2002 No, but there are special hex-switch-dials available which are working fine. They have 16 positions, 1 input, 4 outputs.Best Regards, Thorsten.
Dimitris_FX_freak Posted December 14, 2002 Report Posted December 14, 2002 Or instead you can use the BB firmware with 2 buttons instead of 4 as Thorsten suggest and get the best compatibillity with logic and cubase. If you search  in the troubleshouting you will find a post from me on that matterMind you that I bought an hex coding dial but the 2 buttons are far better in terms of usabillityhere is the linkhttp://www.midibox.org/cgi-bin/yabb/YaBB.cgi?board=concepts;action=display;num=1036351381
