atomsize Posted October 21, 2004 Posted October 21, 2004 Hi everyone!i've just gathered all parts, pcb's and soldered them all...JDM programmer - burn sucefully (thats what it says)Bootloader programmedCore parts soldered in PCBmeasures OK but 7805 gets very hot...needing heatsink, i used a 15-0-15 transformer but using only one live 15-0v 1AmpSID parts amd PCB all soderedDINX1 created in protoboardbuttons and rotary encoder connectedi've uploaded the MIOS and the SID program throu MIDI-OX and it seems to be done sucefully (no errors shown) but the LCD only blink as i turn on the power. no data in display... i'm using a 16x2 LCDfiles uploaded to PIC18F452:- Bootloader - JDM progm- MIOS 1.7 - MIDIOX- MIDIBOX SID 1.6Help please? i cant get it work :(
Sephult Posted October 21, 2004 Posted October 21, 2004 I would suggest double checking your lcd connections.Check your contrast potDo you have a backlight?Will your core respond to midi? There is a sysex string you can send, and the core will send it back to midiox if your core is running properly. I'll look around for it and post if I find it.
atomsize Posted October 21, 2004 Author Posted October 21, 2004 Hithanks for the reply...as i can tell the lcd is well connected... it as a backlight (led backlight) that blinks... but it shows no data...i'll see if i can find that sysex string...i need to get back to that sid+core... no much time as i'm away from home theses days.thank you!:)
Sephult Posted October 22, 2004 Posted October 22, 2004 Heres the string I was talking about... It was moved under the WIKI-----------------------------------------How can I test if MIOS is running?After the startup phase, you can send this message "F0 00 00 7E 40 00 0F F7" to the core, MIOS should reply with the same message immediately. You could also try to upload an application, after every code block a checksum message will be send which acknowledges that the stream has been received correctly.---------------------------------------------I would try this first to see if your MIOS is really running properly, I had problems back on the first releases and this was a lifesaver for troubleshooting ;DHow hot is your regulator? Burning hot?
atomsize Posted October 22, 2004 Author Posted October 22, 2004 i'm going to try that tomorow...i'm at work right now...the regulator is getting very hot... i use a heatsink with about 20cm... and it gets hot!!!
Jurbo Posted October 22, 2004 Posted October 22, 2004 About the display - I don't know if this matters, but the MBSID program uses a 2x20 LCD as default, so now that you use a 2x16, you should change one value in the sid_init.inc file (you will find it, the file is well documented). Somebody correct me if this isn't necessary.
Sephult Posted October 22, 2004 Posted October 22, 2004 I am unsure what configurations you would have to set up, but I am wondering why your regulator is soo hot.What type of transformer are you using?I would suggest unhooking the backlight once, and see if your regulator stays a little cooler.I would check your current too. Might need to use a different regulator. just suggestions, let me know...- ;D-S
atomsize Posted October 22, 2004 Author Posted October 22, 2004 Finally i'm at home...i've setup right the LCD connection (it was reversed) so it stays on...but keeps showing no data... i've tried sending the string of sysex and it comes out right the response... i've changed the PIC and uploaded MIOS, then tested the string it comes ok, then i've changed the LCD inc file for sid to put it on a 16x2 LCD, uploaded the main.inc and the 6581_with_cs as i have 6 buttons 1 encoder and 1 lcd... after that come out sucefully (i think) i disconnected the midi's from the pc and turn off the sid system... turn on and nothing :( just the backlight on...i'm getting suspicious on the conection betwen the sid and the core. need to chek that out. probably is the same thing that happend with the lcd module :|as soon i got news i'll let you all know :)once again, thank you all for the great help :Dthe hot regulator... i think its because of the backlight of the lcd... since its a large character LCD (twice big as standard).
atomsize Posted October 23, 2004 Author Posted October 23, 2004 i've found out that the connection betwen the core and the sid was wrong... now its ok, but still no data showned in lcd...do i have to change anything else in the .inc files to make it work? i'm i doing the correct sequence of upload?Mios - set up lcd.inc from sid to 16x2 - 6581_with_cs.inc - turn off sistem, connect midi keyboard turn on, no data on display :(any hint would be nice :D
goyousalukis Posted October 23, 2004 Posted October 23, 2004 If you can do it easily, disconnect everything from the core except the LCD. Load only MIOS and troubleshoot until you get "READY." on the LCD. That way you know that MIOS is working and so is your LCD. It really seems to me that you have a problem in the LCD wiring. With only the Bootstrap loader, you should see a row of blocks on the top row only. Then after MIOS is loaded you should see "READY." What type of display do you have? Can you post a link to its datasheet? If you disconnect the backlight, you should still see text. The contrast pot should make a big difference - from nothing to very dark.Justin
atomsize Posted October 26, 2004 Author Posted October 26, 2004 well... my looooooong weekend is over...so its time to get to work (double time) and get the sid working... i'm connected one more time after assembled the code (no..i didnt assembled the code with the changes of the lcd etc and so on...) and while uploading the MIOS to a new PIC my sid 2200uF cap blow off... i hope sid is alive... no further work done so far... but i'm going to dissasemble all and start again... i will keep you guys updated :)once again, thankyou!!!!!
Sephult Posted October 26, 2004 Posted October 26, 2004 I agree with goyou...Check the testing/troubleshooting forum for a post named testing strategies....This should give you a basis to test your hardware before you burn anything up ;D
atomsize Posted October 29, 2004 Author Posted October 29, 2004 If you can do it easily, disconnect everything from the core except the LCD. Load only MIOS and troubleshoot until you get "READY." on the LCD. That way you know that MIOS is working and so is your LCD. It really seems to me that you have a problem in the LCD wiring. With only the Bootstrap loader, you should see a row of blocks on the top row only. Then after MIOS is loaded you should see "READY." What type of display do you have? Can you post a link to its datasheet? If you disconnect the backlight, you should still see text. The contrast pot should make a big difference - from nothing to very dark.JustinOk, i've disconnected everything except the core, burn a new PIC with bootloader, and turn on the core... no row of blocks shown :( , uploaded the MIOS and no "READY" message shown :( ... i'm getting desperated! i've checked and rechecked avery solder joint wire connection etc etc... and the LCD connection was reversed but now i can regulate the backlight bright with the trimpots of the core...HEEEEEEEEELP!!!!!!!!!! lolthank you all guys!!! you are beeing very patient with this noob.
Sephult Posted October 29, 2004 Posted October 29, 2004 Did you send MIOS within the 2 seconds of the bootloader boot string?Do you get correct checksums (OKs)?If you did:Do the test string I gave you if no reply from the PC, check your midi connections. Also check your MIDI-OX settings, and watch the verification when you upload. This is where I would check first. I think there is a logfile in MIDI-OX, if you want to have somepeople check out what your seeing go ahead and paste it up...it might helpWhen you had the LCD reversed what was reversed? If mios seems to give you the correct reply string when you ping it, I would think maybe your LCD fried, or you still have bad connections (which you said you fixed).I had an anomoly problem once on the earlier version of mios. I kept having problems getting it to work. It kept on rebooting, or freezing... weird stuff.This was a prototype done on a breadboard.Thorsten suggested wiring the crystal to the PIC, maybe because of stray capacitance. But no luck.Come to find out, I popped a resistor in in the lcd somewhere (Cant remember) and it worked. I have also heard of problems similar when there was a problem with midi connections.Hope this helps out!!!
smashtv Posted October 29, 2004 Posted October 29, 2004 i've setup right the LCD connection (it was reversed) so it stays on...but keeps showing no data... i've tried sending the string of sysex and it comes out right the response... i've changed the PIC and uploaded MIOS, then tested the string it comes ok,It sounds like your CORE is working, but just without display. I'm assuming here that you are talking about having the backlight polarity reversed then corrected in your previous posts.Please read my "Character LCD problems?" postBest!Smash
atomsize Posted October 29, 2004 Author Posted October 29, 2004 MIDI-OX STARTED: TIMESTAMP IN PORT STATUS DATA1 DATA2 CHAN NOTE EVENT Opened MIDI Input Opened MIDI Output DEVICE INFORMATION IN: 1) ADSP24 MIDI1 Device OUT: 2) ADSP24 MIDI1 Device In: MIDI-OX Events Details/Chan: 1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,CM,RT,SxMIDIBOX CORE TURN ON: TIMESTAMP IN PORT STATUS DATA1 DATA2 CHAN NOTE EVENT 00021961 1 -- F0 Buffer: 8 Bytes System Exclusive SYSX: F0 00 00 7E 40 00 01 F7 000220C7 1 -- F0 Buffer: 8 Bytes System Exclusive SYSX: F0 00 00 7E 40 00 01 F7and keeps on going like this until i upload MIOS 1.7Upload of MIOS 1.7 :INPUT: SYSX: F0 00 00 7E 40 00 0F 0E F7 0003539A 1 -- F0 Buffer: 9 Bytes System Exclusive SYSX: F0 00 00 7E 40 00 0F 34 F7 00035688 1 -- F0 Buffer: 9 Bytes System Exclusive SYSX: F0 00 00 7E 40 00 0F 3A F7 00035978 1 -- F0 Buffer: 9 Bytes System Exclusive SYSX: F0 00 00 7E 40 00 0F 3F F7 00035C67 1 -- F0 Buffer: 9 Bytes System Exclusive SYSX: F0 00 00 7E 40 00 0F 5D F7 00035F58 1 -- F0 Buffer: 9 Bytes System Exclusive SYSX: F0 00 00 7E 40 00 0F 20 F7 00036246 1 -- F0 Buffer: 9 Bytes System Exclusive SYSX: F0 00 00 7E 40 00 0F 42 F7 00036535 1 -- F0 Buffer: 9 Bytes System Exclusive SYSX: F0 00 00 7E 40 00 0F 28 F7 00036826 1 -- F0 Buffer: 9 Bytes System Exclusive SYSX: F0 00 00 7E 40 00 0F 59 F7 00036B14 1 -- F0 Buffer: 9 Bytes System Exclusive SYSX: F0 00 00 7E 40 00 0F 0C F7 00036E05 1 -- F0 Buffer: 9 Bytes System Exclusive SYSX: F0 00 00 7E 40 00 0F 7C F7 000370F4 1 -- F0 Buffer: 9 Bytes System Exclusive SYSX: F0 00 00 7E 40 00 0F 10 F7 000373E3 1 -- F0 Buffer: 9 Bytes System Exclusive SYSX: F0 00 00 7E 40 00 0F 53 F7OUTPUT : 00034E24 MOX 2 F0 Buffer: 1184 Bytes System Exclusive SYSX: F0 00 00 7E 40 00 02 00 00 01 00 40 3B 62 3F 04 03 5E SYSX: 13 78 27 56 03 46 42 3D 3A 42 34 14 1B 13 1B 21 1D 54 SYSX: 00 5A 09 75 61 67 50 79 2D 04 3D 00 44 01 61 67 6E 1E SYSX: 5E 16 3E 73 75 7B 33 77 2F 2F 5F 1F 3B 7A 7D 39 7B 67 SYSX: 54 07 40 5E 7D 20 4C 05 7B 6A 05 60 2F 7E 51 10 02 71 (...) SYSX: 40 05 36 16 44 00 39 00 0A 4A 18 60 0E F7 00035114 MOX 2 F0 Buffer: 1184 Bytes System Exclusive SYSX: F0 00 00 7E 40 00 02 01 00 01 00 00 74 02 20 04 55 5E(...) 00035402 MOX 2 F0 Buffer: 1184 Bytes System Exclusive SYSX: F0 00 00 7E 40 00 02 02 00 01 00 7D 75 73 1D 3E 4B 2C SYSX: 01 07 25 7B 1C 7E 5A 63 59 05 03 52 3D 4E 2F 2C 01 77(...) 000356F1 MOX 2 F0 Buffer: 1184 Bytes System Exclusive SYSX: F0 00 00 7E 40 00 02 03 00 01 00 01 42 60 61 07 1F 43 SYSX: 11 28 41 61 20 37 03 31 10 47 4D 72 12 7F 73 2F 0F 28(...) 000359E1 MOX 2 F0 Buffer: 1184 Bytes System Exclusive SYSX: F0 00 00 7E 40 00 02 04 00 01 00 09 36 1D 7B 10 4F 31 SYSX: 6F 5A 05 1B 0E 7D 58 2B 58 77 6E 02 6D 47 3E 74 17 6C(...) 00035CD1 MOX 2 F0 Buffer: 1184 Bytes System Exclusive SYSX: F0 00 00 7E 40 00 02 05 00 01 00 45 65 12 15 08 00 1E SYSX: 1F 05 69 0B 5D 45 02 17 14 45 60 51 39 14 4E 77 0B 42(...) 00035FC0 MOX 2 F0 Buffer: 1184 Bytes System Exclusive SYSX: F0 00 00 7E 40 00 02 06 00 01 00 19 03 5E 76 70 0D 54 SYSX: 09 00 3D 25 00 27 00 12 00 01 4A 40 3A 67 67 2E 03 28(...) 000362AF MOX 2 F0 Buffer: 1184 Bytes System Exclusive SYSX: F0 00 00 7E 40 00 02 07 00 01 00 00 28 1F 7E 78 43 60 SYSX: 24 77 46 1E 00 28 06 09 3F 09 00 00 0B 20 23 20 00 59(...) 0003659E MOX 2 F0 Buffer: 1184 Bytes System Exclusive SYSX: F0 00 00 7E 40 00 02 08 00 01 00 74 0E 5D 03 01 60 16 SYSX: 40 04 53 1B 70 28 06 0A 6B 04 40 1E 55 01 6B 3F 05 15(...) 0003688E MOX 2 F0 Buffer: 1184 Bytes System Exclusive SYSX: F0 00 00 7E 40 00 02 09 00 01 00 02 01 58 00 70 0C 2D SYSX: 0F 35 44 3B 00 15 00 15 50 02 5B 51 75 0F 0D 20 05 0C(...) 00036B7F MOX 2 F0 Buffer: 1184 Bytes System Exclusive SYSX: F0 00 00 7E 40 00 02 0A 00 01 00 19 0C 06 03 21 01 28 SYSX: 2E 25 5B 0D 77 1B 17 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F SYSX: 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F(...) 00036E6E MOX 2 F0 Buffer: 1184 Bytes System Exclusive SYSX: F0 00 00 7E 40 00 02 0B 00 01 00 6E 3B 60 1F 05 73 5E SYSX: 01 78 32 3D 70 0F 42 71 6F 00 7C 1C 2E 78 07 61 06 77(...) 0003715D MOX 2 F0 Buffer: 1184 Bytes System Exclusive SYSX: F0 00 00 7E 40 00 02 0C 00 01 00 09 00 00 00 00 48 00 SYSX: 00 00 04 40 00 00 00 24 00 00 00 10 4E 78 67 60 12 00(...)to see the full report go here :http://ignatz.alojamentos7.com/midibox/report.txtThen i turn off the CORE and connected the LCD to COre... power on...NO DATA on lcd...input of midi-ox gives this string : 00061A75 1 -- F0 Buffer: 8 Bytes System Exclusive SYSX: F0 00 00 7E 40 00 01 F7LCD backlight is on, i send the string F0 00 00 7E 40 00 0F F7 to see the response of MIOS...response on input of MIDI-OX 0009CD96 1 -- F0 Buffer: 9 Bytes System Exclusive SYSX: F0 00 00 7E 40 00 0F 00 F7Response on output of MIDI-OX 0009CD92 MOX 2 F0 Buffer: 8 Bytes System Exclusive SYSX: F0 00 00 7E 40 00 0F F7i'm going to check the smashTV post about LCD troubleshoot and get back to you :)
atomsize Posted October 30, 2004 Author Posted October 30, 2004 It sounds like your CORE is working, but just without display. Â I'm assuming here that you are talking about having the backlight polarity reversed then corrected in your previous posts.Please read my "Character LCD problems?" postBest!Smashi've checked the LCD and tested it on my computer, wich shows the characters correctly without using any negative voltage. i'm going to doublecheck the core pcb for bad solder joints...thank you :)
jdutcher Posted October 30, 2004 Posted October 30, 2004 what brand/model lcd are you using? i'm having the same problem as you, but i think mine is related to the negative voltage thing mentioned in smash's post.
atomsize Posted October 30, 2004 Author Posted October 30, 2004 The LCD i'm using is this one:Optrex DMC16230NY-LY-B 16x2 LCD display with yellow/green LED backlight.Datasheet for it :http://www.optrex.com/SiteImages/PartList/SPEC/16230cge.pdfi've connected a parallel cable to it and a pot to adjust the backlight and connect it to parallel port of my pc, running lcd smartie and it shows the info whitout having a negative voltage for contrast.still, no data is beeing show when connected to the core.thank you all :)
atomsize Posted November 1, 2004 Author Posted November 1, 2004 :D :D :DWellAfter a long night troubleshooting, i found out that there was a wire dead in the LCD connection... replaced and...VOILá!!!!! CORE working and getting the READY message. application SID uploaded and working, all controls working, now its time to get some sound out of it...bbl :)thank you all for helping :D
atomsize Posted November 1, 2004 Author Posted November 1, 2004 :(well... no sound out...the only sound i got is an annoying FIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIII coming out of the speakers... i'm using some computer amplified speakers... i'm affraid i've burn the SID chip with the first stage of assembling :(now i need to get my hands on another sid chip...the core and program are working great, i can navigate all the things, and change everything. everything was already double checked.as soon as i have news... i'll post them :)
seppoman Posted November 2, 2004 Posted November 2, 2004 Hi atomsize,don´t throw away the SID yet. If the FIIIIII [...] is not very loud: The SID chip makes this noise as long as it is not initialized. Perhaps you´ve got another connection problem - check the connection between core and sid module. Is the cable built like in the new docs? for MIOS 1.7 some pins are connected differently than for older MIOSses.Seppoman
atomsize Posted November 3, 2004 Author Posted November 3, 2004 Hi!i've build a new connection cable for using with core and sid... i got the voltages right (5v on logic ic's and SID), but still no sound out. the FIIIIIIIII is not loud... i can ear it because i have the speakers on full power...lolon a scope theres a small noise but is very small. i've used the conection diagram thats showned in the sid page... but i'll check it one more time (only 3 days from now cause i'm out of home).Once again thank you :)
