Julian Posted February 14, 2005 Report Posted February 14, 2005 hi,I'm abou to order my SID frontpanel from Schaeffer...to make it rack compatible, I'd like to put all the jacks on the frontpanel.so i just wanted to aks if I've forgotten something before ordering ;)1 x MIDI In1 x MIDI Out4 x Audio In4 x Audio Out4 x SUB D / Bankstickso long,julian
TL Posted February 14, 2005 Report Posted February 14, 2005 maybe you want a MIDI Thru, too? And you need only one Sub-D, since Banksticks are only connected to the first (master) PIC.
Julian Posted February 14, 2005 Author Report Posted February 14, 2005 yeah, but you can also connect multiple bank stiks.if i'm not wrong you can connect up to 8 banksticks at the same time...midi thru is a good idea ;)so long, julian
Jorge Posted February 14, 2005 Report Posted February 14, 2005 I decided not to use the bank stick design and went for the 8 eeprom setup as an internal memory board.If i understood the design correctly that gives me 1056 internal patches, my old yamaha FX500 has only 30 user memory slots for patches which is very poor for a commercial product , even when it was produced..Jorge... :)
TK. Posted February 15, 2005 Report Posted February 15, 2005 Yes, I would also suggest 8 internal banksticks.The 4 Audio INs are "nice to have" for some experiements, but no must. You could also place them at the backside.I'm missing the AOUT port! :-)Sidenote: in the meantime my MIDIboxe SID/FM and SEQ are stuffed with a special DIN socket for the AOUT, so that I can use it as "breakout" box. I've used a 6-pin socket, the remaining pin will be used later for a serial connection to a (planned) 8 x gate extension (it's just a 74HC595). Reichelt Part # for the socket: MAB6(the picture shows the 5 pin type, I mean the shading at the right upper edge)Reichelt Part # for the plug: MAS 60Best Regards, Thorsten.
