Digital Audio Processor - PIC Processing Overhead Question...
I am looking into the possability of making a PIC powered SPDIF Signal 'processor'. The idea of this device; is to allow the adjustment of the signal sample frequency & bit depth in real time to give a sound to the processed signal much like early samplers.
Regarding the PIC18F452 - would it have sufficient data transfer rate to Receive a 16bit 44/48khz stereo SPDIF signal & then relay it on again ?
I could probably figure this if i did the math - though someone here may well know the answer to this already.
Further on this point, assuming that the pic can handle realying this information - i'd assume that it was within it's capability to then pull appart this data & then do a simple bit of math to then allow downsampling the frequency sample rate ?
If this is looks feasable (even if it means using a more powerful pic) i'll have a go at this sometime - should be a good way to get to grips with pic programming from scratch. Also - got afew more ideas on how to process the signal; so this could be a really fun project to toy with ! :)
Hi Artesia,
this is perverse, isn't it? Reducing the bitrate on a interface which was invented for best digital quality? ;-)
(btw.: I would use a VST for such a simple job)
The datarate of SPDIF at 48kHz is 3.072  Mbit/s, this means that you have only 3 PIC instructions per bit - doesn't look feasible.
More infos here http://www.epanorama.net/documents/audio/spdif.html
All this squeaky clean sound conversion is great for transporting those sounds to and from the analog & digital domains. however it does little to add character to the sound ;) The essance of such a project would be  to encapsulate the elements of sound distortion + artifacts  inherent to varying imperfect transitions between these domains. The General problem with downsamplng ins software is that it tends to smooth the signal by applying a 'low pass' filter - rather than spitting it out raw. + other things like lower  bit  jitter sound interesting (think Casio CZ series).
Would be nice to have this as a stand alone widget  + ;)
With the versitility of simple manipulations the streams directly - i would assume that effects could be acheived which; somthing like Reaktor could not be hacked to do.
Anyway, as TK notes - not likely to be able to do anything useful with the standard MIOS pic.  Will Read up some more on this - maybe somthing could be done with another chip.
The resampling could at a guess be acheived by having enough memory to load a whole 'sample frame' into memory at once & then ignoring 'x' number of frames (in relation to the given sample freq) + giving the last read frame as the current frameset until this table is updated with the next frame that is read.
...hmm might need afew more mhz - but with a frame worth of memory this might work (?) :)
Thanks for the feedback - will ponder this...
Update #1:
With the information provided on TK's link (Ta !)  - the ammount of actual audio sample data in the various packets & sub packets brakes down like so:
[    SubFrame ]        16 bit SubFrame            = 16  bits            - (per SubFrame)
[          Frame ]        16 bits x 2 SubFrames  = 32  bits            - (per Frame)
[            Block ]     32 bits x 192 Frames      = 6,144 bits   - (Per Block)
A subframe is the smallest  packet of data 32 bits (16 bits 'reserved'  for the audio samples), which represents one sample frame for one audio channel. a bit flag is also assigned to say weather this frame belongs to the left or right channel; presumably the two 'Frame'  'SubFrames'  are the left & right channels.
[ 18F452 RAM ] 1536 Bytes  x 8  =  12,288 Bits
So,  when stripping the data down - There is  enough space in 18F452 RAM (1536 Byte) to store exactly 2 Blocks worth of data. Whilst ignoring the other (allbeit important) other non audio bits.
[    AllData OneBlock ]    32bit x 2 x 192 = 12,288 bits - (All Data Total Per a Block)
Now assuming that 3 instructions can be carried out during the period of one Bit of a SPDIF DataBlock arriving - then at 12,288 bits per a DataBlock  - this would leave the oppertunity to execute 36,684 instructions in this timeframe ! + theres enough ram to do some juggling with..
The real problem arrives when it comes to simaltainiously sending & Receiving that data - maybe two pics could resolve this by one dealing with stripping the data appart, whilst the other picks & repeats the raw data packets to create the desired result.
With the ammount of ram available on the 18f452 - this would allow for a 1 Block  lag - with higher memory capacity pics from this family; maybe upto 3-6 Block  lag could be used to borrow back time to do more instructions.
- Any Further  Thoughts on this matter anyone ? :)
fair  comment :)
Looking into that - however the website is under too high a load this afternoon to churn out the downloadable bits :/
Been thinking some more about how this might be implimentable - and it occured that if  a datatable containing say 192 slots for subframes). Then a quite flexable stucture for manipulating the packet order in any way desired - could be acheived by having a outgoing 'subframe address read table'  with 192 freely editable address slots.
An example of how this might work with 16 slots for some examples:
(some of these examples would require streching over subframes to work  as intended)
(SubFrames stored as - F01 to F16 )
(F00 = Blank SubFrame)
Un-modifyed 'playback':
Read Line:  'play' Subframe no:
001              F01
002              F02
003              F03
004              F04
005              F05
006              F06
007              F07
008              F08
009              F09
010              F10
011              F11
012              F12
013              F13
014              F14
015              F15
016              F16
an example of what a downsamplng might look like with a 16 subframe table:
001              F01
002              F01
003              F01
004              F01
005              F05
006              F05
007              F05
008              F05
009              F09
010              F09
011              F09
012              F09
013              F13
014              F13
015              F13
016              F13
Then onto some other uses...
Playing time interval sections backwards:
001              F16
002              F15
003              F14
004              F13
005              F12
006              F11
007              F10
008              F09
009              F08
010              F07
011              F06
012              F05
013              F04
014              F03
015              F02
016              F01
'random' garbling :
(This implimentation would probably give a DAC a heart attack  ;)
001              F08
002              F11
003              F02
004              F15
005              F14
006              F10
007              F01
008              F06
009              F09
010              F03
011              F05
012              F12
013              F04
014              F16
015              F13
016              F07
Gapper effect :
001              F01
002              F02
003              F03
004              F04
005              F00
006              F00
007              F00
008              F00
009              F09
010              F10
011              F11
012              F12
013              F00
014              F00
015              F00
016              F00
Seudo Jitter :
001              F01
002              F02
003              F03
004              F04
005              F01
006              F02
007              F07
008              F08
009              F09
010              F10
011              F07
012              F08
013              F13
014              F14
015              F15
016              F16
Seudo Stutter :
001              F01
002              F02
003              F03
004              F04
005              F01
006              F02
007              F03
008              F04
009              F09
010              F10
011              F11
012              F12
013              F09
014              F10
015              F11
016              F12
Playing a time interval section in a 'cyclic' loop :
001              F01
002              F02
003              F03
004              F04
005              F05
006              F06
007              F07
008              F08
009              F08
010              F07
011              F06
012              F05
013              F04
014              F03
015              F02
016              F01
Playing time interval sections in a 'cyclic' loop :
001              F01
002              F03
003              F06
004              F08
005              F10
006              F12
007              F14
008              F16
009              F16
010              F14
011              F12
012              F10
013              F08
014              F06
015              F03
016              F01
Shuffle':
001              F01
002              F02
003              F13
004              F14
005              F05
006              F06
007              F09
008              F10
009              F07
010              F08
011              F11
012              F12
013              F03
014              F04
015              F15
016              F16
hmm - crazy im sure ...But playing with editable lookup tables could provide a whole lot of fun methinks :)
even without  modifying the packet contents :]
You know what the word "evaluation" means? ;-)
Sooner or later I will try out the SPDIF modules on my FPGA board, maybe I can tell you thereafter if using a PIC for processing is feasible or not
hihi
interesting topic :D
I'd love to play with FPGA, but don't have money and time now....
for that kind of stuff you can also use the small DSP from wavefront semi (old alesis semi), the al1301 (used in Mrs Parker), I think ;)
Oh boy! you guys are way beyond the technical depth of dsp and programming that I can understand! (chuckle) I am so surprised that someone wants to go to the trouble to get that 80's sampler sound!
'Task for a dsp pic...' No and possibly yes...
The idea of this is to take truely base level approach to manipulating the audiostream itself. Which isn't something that the run of the mill dsp chip would automatically lend itself to (?). Idea being, to see what wonderful & awful things can be done by mashing up the order of the actual audio packets in realtime (like 'shuffling a pack of cards') - something which i don't think anyone has tried yet...
maybe a dsp pic could lend itself to this; But given they seem to be for just running algorythms in a somewhat more restricted framework - maybe not.
Thornsten's suggestion for a suitable platform is probably the best line to start trying this one out i guess :)
It definitely is - just to give you an impression: I've synthesized the spdif_tx unit with some additional circuirity which intitializes the SFRs. The logfile says that ca. 10% of the FPGA is allocated, and that it runs with up to 180 MHz. However, in pratice you've to take care for the tx clock frequency, because it must be divitable by the bitrate, thats currently my blocking point (have to wait for the next Reichelt order to get some parts for a PLL)
  • 3 weeks later...
