well, i've finally got round to the actual fabrication of the mbhp modules (only after a 100 odd posts :P)...
on the first run, i made the a couple mirrored, so in order to save them i just soldered in eveything mirrored - should everything be okay? is it okay to run the IC's upside down (as it's mirrrored) i just bent the pins a full 90 degress so it all matched right...
now to make more boards - this time the right way round ;)
actually, the voltages are not okay...
using a 9v 500mA to test the core with. on input measure is 11.7V and at the points where it should be 5V it still measures 11.7...:(
Hi Dan,
with the mirrored board it will be really difficult to prevent soldering errors - but it's possible. Be careful!
