I made a pair of sysex archives to work with Reason 2.0 (Propeller Heads) and midibox 64, one to control all parameters of Subtractor and an other one to control the mixer, but my midibox don't load this archives, the virtual midibox yes do it. The midibox stop the load about 235 bites loaded, I probe to slow the time but don't work, the version of firmware it's 1.00 and the virtualbox its 1.00f.
I need send this archives to anyone for try it.
Thanks to all.
Hi Amando,
which operating system are you using?
Could you please try the download with MIDI-Ox? (see HOWTOs->HowTo SysEx)
OK!, must be the problem the name for the Bankstick?
first I name it "subtrac 2" and don't work, I change the name to "subtrac" and all fine. well too reenter the data for the last 16 pots.
Thorsen, the LCD shows v1.00 and the core it's the "compatible".
Now the sysex it's tested an run's fine, Subtractor i'ts a BEAST, nest target NN-XT.
Could you send me the .ini and .syx file to my email address, I will check it.
I have been running my midibox plus with Reason 2.0. for awhile, I haven't had any problems yet with it. I just basically set each knob with a different controller number and channel with a different synth or program, and use the midi learn of Reason. Works great.
-Sephult
  • 3 weeks later...
I just get Reason 2 ... and i found something weird ...
I want to play a Reason synth on my keyboard (MIDI CH1) thru my midibox16 and controlling the pot i assigned .. some other pots move and i can't put "not mapped" on this pots...
What do i do wrong ?
Gilles
Guest rebelrob
Hey dude, I'm having the same problem, read my post just bellow this one 'Strange Reason problem'...
or set it to a ctrl on a channel other than 1 and use midi-learn.
I cannot change the pot assigment ... i think it's Reason 2 original patch and can be changed...
any other idea ?
