amando Posted January 24, 2003 Report Share Posted January 24, 2003 I made a pair of sysex archives to work with Reason 2.0 (Propeller Heads) and midibox 64, one to control all parameters of Subtractor and an other one to control the mixer, but my midibox don't load this archives, the virtual midibox yes do it. The midibox stop the load about 235 bites loaded, I probe to slow the time but don't work, the version of firmware it's 1.00 and the virtualbox its 1.00f. I need send this archives to anyone for try it.Thanks to all. Quote Link to comment Share on other sites More sharing options...
Jack Posted January 24, 2003 Report Share Posted January 24, 2003 Hi Amando!Try update your Reason to 2.01 and after update use your midi learn with the right button. mfgJack Quote Link to comment Share on other sites More sharing options...
TK. Posted January 24, 2003 Report Share Posted January 24, 2003 Hi Amando,which operating system are you using?Could you please try the download with MIDI-Ox? (see HOWTOs->HowTo SysEx)Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
amando Posted January 24, 2003 Author Report Share Posted January 24, 2003 OK!, must be the problem the name for the Bankstick? first I name it "subtrac 2" and don't work, I change the name to "subtrac" and all fine. well too reenter the data for the last 16 pots.Thorsen, the LCD shows v1.00 and the core it's the "compatible".Now the sysex it's tested an run's fine, Subtractor i'ts a BEAST, nest target NN-XT. Quote Link to comment Share on other sites More sharing options...
TK. Posted January 24, 2003 Report Share Posted January 24, 2003 Could you send me the .ini and .syx file to my email address, I will check it.Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
Sephult Posted February 7, 2003 Report Share Posted February 7, 2003 I have been running my midibox plus with Reason 2.0. for awhile, I haven't had any problems yet with it. I just basically set each knob with a different controller number and channel with a different synth or program, and use the midi learn of Reason. Works great. -Sephult Quote Link to comment Share on other sites More sharing options...
gillesdeshays Posted February 27, 2003 Report Share Posted February 27, 2003 I just get Reason 2 ... and i found something weird ...I want to play a Reason synth on my keyboard (MIDI CH1) thru my midibox16 and controlling the pot i assigned .. some other pots move and i can't put "not mapped" on this pots...What do i do wrong ?Gilles Quote Link to comment Share on other sites More sharing options...
Guest rebelrob Posted February 27, 2003 Report Share Posted February 27, 2003 Hey dude, I'm having the same problem, read my post just bellow this one 'Strange Reason problem'... ??? :-/ :'( Quote Link to comment Share on other sites More sharing options...
Captain_Hastings Posted February 27, 2003 Report Share Posted February 27, 2003 Check the Reason MIDI-implementation chart. Try either assigning the appropriate control id to the pot on your midibox, or set it to a ctrl on a channel other than 1 and use midi-learn.Hope that helps! Quote Link to comment Share on other sites More sharing options...
amando Posted February 27, 2003 Author Report Share Posted February 27, 2003 http://users.pandora.be/sdrsite/sites/serge/vmidibox/dev/presets/ReasonMidibox64AmandoSysex.zipThis is the Serges site, you can download this archives for try it, are implemented for midibox 64, I don't know if it's work's with the midibox 16, you can edite it with the virtual midibox for change the midi chanel. Quote Link to comment Share on other sites More sharing options...
gillesdeshays Posted February 27, 2003 Report Share Posted February 27, 2003 or set it to a ctrl on a channel other than 1 and use midi-learn.I cannot change the pot assigment ... i think it's Reason 2 original patch and can be changed...any other idea ? Quote Link to comment Share on other sites More sharing options...
