julien carayon Posted July 25, 2005 Report Posted July 25, 2005 Hello to all midiboxer! :)I'm going to build my own midi controller to...well...control my sequencer..I have Cubase VST 5 (ok I'm aware it's not up to date - please don't laugh :-[ ;D ;) )will a timecode display work with my sequencer? Can anyone give info about making a timecode display (parts, connections,...)Thank you so much :) ;) :DUP MIDBOX !!!!JCwww.juliencarayon.com
Screaming_Rabbit Posted July 25, 2005 Report Posted July 25, 2005 ... it's all on ucapps.de... http://www.ucapps.de/midimon.html... I have no idea about timecode midi signal-stream from cubase (not a cubase user)Greets, Roger
raphael Posted July 25, 2005 Report Posted July 25, 2005 have Cubase VST 5 (ok I'm aware it's not up to date - please don't laugh    )will a timecode display work with my sequencer? I don't use Cubase, but most sequencers can send MTC.Can anyone give info about making a timecode display (parts, connections,...)http://www.ucapps.de/midimon.htmlwith MTC optionhttp://www.ucapps.de/midimon/mtc_extension.pdfhttp://www.ucapps.de/mbhp/mbhp_doutx4_mtc.pdfIf you only need timecode, you can omit the LCD display.Raphael
julien carayon Posted July 26, 2005 Author Report Posted July 26, 2005 Hello!Thank you for helping.Cubase can actually send MTCWhich led digits to use ? (specifications,...)However I'm wondering what the "status displays" is for. I haven't found any detalied info about it ???Again thank you ;) :)JCwww.juliencarayon.com
Screaming_Rabbit Posted July 26, 2005 Report Posted July 26, 2005 Which led digits to use ? (specifications,...)... it's written on http://www.ucapps.de/midimon/mtc_extension.pdf, which raphael posted for you: "common anode"for example: http://www.voti.nl/shop/p/DISP-5.htmlHowever I'm wondering what the "status displays" is for. I haven't found any detalied info about it... this is for the LC applicationGreets, Roger
julien carayon Posted July 26, 2005 Author Report Posted July 26, 2005 Hi screaming rabbit! :)... this is for the LC applicationOk I see nowthank you ;)JCwww.juliencarayon.com
Jidis Posted July 27, 2005 Report Posted July 27, 2005 Julien,I've used the "LCD-less" MIDIMon for that from Nuendo. It will also detect and display regular beat clock, if that appears in the stream. You can check or uncheck them in the Cubase sync panel to turn them off.TK- If you should see this-- I don't think it does non-4/4 time signatures in beat clock mode. It's not supposed to is it?PS- Check the actual pinning of the segment modules you use. I've got two different dual digit display parts here with different pinouts.
