well i'll be, i think it works!
d2k
So after 100+ posts I finally have my 1st mbhp box made - a lil  MBSID before i start on the bigger pies (2xMB64 and a LC)...
Voltages all good throughout, and LCD (backlight aint workin tho - do i need to connect the A and K pins on it to nefin?) reads correct - boots with SID v1.4 then goes to:
P: 1 C: 1 D:1
Internal Patch
However, i cant yet hear the beast in action :( as i dunno how to connect the audio out to a 3 -pole jack socket i have, i've tried various ways but have had no luck... am i right in thiniking 2 of the poles have to be bridged? which ones?
Also,  can i just connect up the MIDI in/out from the core and tinker about straight away - i.e i dont have to load any sysex files etc...?
What do i do? I must hear this thing sooon ;D
Peace...
Dan
Hi
Check that your wires running to the backlight pins are round the right way because the backlighting is normally by LED so the current will only flow one way.
The A & K pins are normally connected to the respective pins from the main connector via conductive tracks on the LCD board; Check them with a meter to confirm this, if they are you do not need to hook them up.
You should have a data sheet with your LCD to confirm this?
'ight?
LO
yeah, lcd2core connection looks okay (displaytech 162). a & k pins have some current going through them...so i guess summin else is a miss...
i am measuring 5v on pins 15/16 ( led + & -) of the lcd, so it should work right? mebbe it's just gone? i dunno, i did mess about with the lcd prior to putting it into this box...
o well, i whiped in an ltc module with sum ultrbright blue leds that make up for it neway ;), still a mystery tho  ???
cheers fellaz...
D
:-[ uh-oh...
So, eveything was runnin smooth, but then after i housed it it in it's new home and turned it out I got nothing but a blank screen...:(
I dismantled it all again, and checked voltages - on the core i'm not gettin the +5 between IC1(1)-(12) nemore, but all other voltage test are okay...
Does anyone know what has happened here...?
ta
Dan
Okay, voltages are all good again...
Still getting a blank screen when i power up (think thats because i may of killed the LCD even tho the backlight lights up). Tried testing with the SID test f/w, and didnt get the choard sound like before...
Checked for track breaks and shorts - all looked okay, even tried swapping the SID, also burnt a new PIC - still no worky tho :(...
Any ideas pls....?
I'm gonna make some new modules, but i'm feelin pretty gutted round about now ... :-/
right, stuffed 2 new sid and core modules with new components, checked voltages - all good, burnt sid test f/w and powered up - choard sound played, great ;). But then after powering down and turning back on - silent once again :(
what is happening here?
I'm using a 15v wallplug for both modules
Hi Dan,
the failures are very strange, it seems that there is a very  dangerous "bug" in your circuit. I hope that you"ve isolated the crystal at the bottom side with a sticky tape? Is there any  physical connection between the voltage domain before and after the 7805? Are the jumpers connected properly?
Maybe you should also test some other firmwares in order to ensure that the PIC is still working.
Are you still using the "mirrored" PCB?
If it makes you feel better, I had the same problems with my core + SID. I ended up with only a bunch of black lines on my LCD and nil from my SID.
I have no suggestions beside that I had the fault once and changed the audio transistor on the SID.
Then it worked for a bit. Then it stopped again.
Actually it seemed to go pearshaped after I added the lcd ???
Not that that makes real sense ???
Still the lcd was wrong even when I stuffed new parts also.
In the end I gave it up for a bad joke :'( :-/ ???
One day I will try again
Ian
I had more success with the earlier firmware.
I tried my lcd with LO's mf core and it would not work there either. So I think i may have fried the LCD driver.
I am using the 1mhz from the core pic.
I have stuffed different SIDS into the thing with the same result
It seems like something gives out after a while.
The first time it happened I replaced the Transistor on the core and the SID and it worked for a while then nothing.
I have reused the PIC on other projects with no trouble.
I am not using the 8580 And  I do not have the same problems with voltage as Dan.
It seems as if something gets tripped then nothing.
I have replaced all the parts including the pic.
Don't be too worried though, I am waiting to build the thing fully as a synth + control surface with the 18F.
Thanks
Ian ;)
Not with tape, but it's def not touching any other tracks...
I'm goin from the dc jack to a switch, then to a fuse (1.0A), then to a  LED/1k resitor (power LED) as described in the MB64 walkthrough...before feediing both the SID and Core modules...voltages all good on both circuits...
Yeah, ok i'll do that - but it seems like the same prob Ian was having - I tried using the same pic/sid from the first ones in the new modules, and it worked first time (sid test f/w), then nothing - like in the 1st box, so it seems somthing on the circuit is blowing - mebbe the transistor like u said Ian...
Nope, these where on brand new brds i etched n stuffed...
Ian/Dan: is your SID clocked with an additional 1 MHz oscillator or with the PIC?
1mhz osc...
Thats the thing, voltages are good now...so it seems we have a same or similar prob...then again, this is electronics - what do i know  :P :-X :-/ :'( :-*
oh well, onwards n upwards...
Thanks guys...
Dan
There is possibly a way to freeze the LCD driver, and thats a floating signal at pin RB7 of the PIC.
Dan: could you please temporary remove the LCD and solder a 1k or 10k resistor from Pin #40 of the PIC to ground?
If this doesn't help, I will provide a very reduced test program for the SID which *must* work.
Another check to determine if the SID can be accessed by the PIC: at power-on, the reset signal of the SID (Pin #5 of the SID chip) is going low for about three seconds, thereafter it goes to +5V. This can be measured
tried 1k and 10k resistor, still nothing... unless u meant this is a check for the LCD and not the SID (i dont have the lcd connected on this core...
So, test pin 5 against what other pin, ne pin goin to ground right? ie pin 14...? I tried, no +5 there either - 0.934 is what it seems to reach...
Ok, so the 74HC595 shift registers are not serviced by the PIC. Now it's important to know if the firmware is running before debugging the SID module.
Here some voltages, which have to be measured against ground:
Pin #1: > 4V
Pin #17: ca. 2 V (must be > 1V and < 4V)
Pin #19: < 1V
Pin #20: > 4V
Pin #21: < 1V
Pin #22: > 4V
Ok, your PIC is still working - perfect. With the test firmware, the voltage level of Pin #22 can be ignored.
Now check the interconnections between Core and SID module (again)
Thereafter measure the voltages on the 74HC595 chips:
Pin #10 and #16 of IC2 and IC3: >4V
Pin #2 of IC2: >4V
