Has anyone added a balanced audio output??
Anyone modded it for standard +4 balanced operation? Me thinks it would be as simple as adding an inverting NE5532 dual opamp circuit on the output...
nothing too flash... but handy for patching into most studio gear, and for long cable runs.
the opamp should be able to do it - but then you are going to either need a dual supply - as in +/- n-18V or whatever the opamp takes - or something fancy to run the opamp off of a single supply.
Or you can always use a nice output transformer :P
Could someone explain what a transformer is, what it does
wikipedia.org/wiki/Transformer (Isn't the internet great ;D)
What Milkmansound and Ziggy are speaking of are output transformenrs like these:
http://www.jensen-transformers.com/ln_out.html (Making a balanced signal)
Look at the prices ;)   What I wanna say: If you don't know what a output (or MIC input) transformer does, you won't need one.
Thanx  for the reply.
I know what balanced inputs/outputs are and what could be the benefits of them.
But I didn't know of transformers. Or maybe is it because of the 'language barrier'.
well come on man, of course the Jensen trannies are going to be that expensive. You can use a triad audio transformer - they are really nice military spec quality - and small, and will most likely handle what the SID has to offer. But you will use the super low frequencies - an opamp based balancing circuit like this for example:
might be better for the project. Check this page out for even more info:
http://www.dself.dsl.pipex.com/ampins/balanced/balanced.htm
good luck!
I think thats the point.
Is the SID sound quality (in technical meaning) worth balanced outputs? Only if you use really long wires...
Concerning the opamp solution: If you are speaking of adding warmth then you'll have to use a transformer.
Just my 2ct.
Raphael
really, there is no reason to add a balanced output at all other than to interface with already balanced gear. Most modern gear will handle a non-balanced signal though, so there is not a huge demand for an XLR output. I think every synth I own has 1/4" unbalanced outputs - having one with an XLR balanced output would actually be an inconvenience  ;)
I'd double-check if I were you - many synths (and most synths produced in the 90s) were actually produced with balanced 1/4" TRS.
ok, maybe balanced TRS - but certainly not balanced XLR
some of the old Moog synths had XLR outs, and I also recall seeing some modern "workstation" type synths with XLR - but generally, synths are not operating at mic levels and impedances - 1/4" is usually the standard. 1/4" balanced is a luxury  ;)
...Roland Jupiter 8, some Akai samplers, Studio grade fx.. XLR indicates that connections are balanced, but it doesn't indicate the signal levels.
Bye, Moebius
