1. Store your setup to a bankstick.
OR
2. Make a SysEx dump and store the dump via MidiOX. After codechange just do a sysEx upload again.
so when i change the debounce counter value it won´t be overwritten from the new syx upload?
Look at the MB Sysexloader (http://www.ucapps.de/howto_tools_syxloader_18f.html). If you choose as filetype MB64EPatch, only the patch will be overwritten and not the program memory.
But I would prefer the Bankstick solution. It's really cool if you can switch several configurations via the LCD menue.
When i store a sysex-dump with vmidibox, change the code and upload it, and then upload the sysex stored before, will this overwrite the changed debounce settings?
No, the debounce setting is hardcoded and won't be overwritten by reloading your dump.
Raphael
yes.  ;D  8)
last weekend i did a jam session with my friend. The performance with this midibox is fine.
Here is an additional picture of the inside of my midibox:
Indeed there are more cables i expected. But i just managed it that there is no wasted space inside  ;)
Greettz, LIDE
  • 2 weeks later...
I did the case-design my own. The frontpanel (where the knobs/faders/buttons are mounted) and the backpanel (where the pcbs are mounted) i designed with frontplattendesigner and ordered from schaeffer-ag.
The sidepanels are milled out of standard alumina-profiles such as sold by maytec or bosch rexroth.
The panels are mounted together with brackets i made myself (simply alumina plates which are bent). You can see them mounted to the side-panel in the picture above.
This work is well done with a AutoCAD Mechanical Desktop, which I use at work for constructions.  8)
  • 2 weeks later...
Thanks for that.
In the meantime I had my first live-gig with this box and it worked fine!
;D ;D ;D ;D
hope this box works a long time... cannot imagine working without it on ableton live anymore.
  • 5 years later...
