68 -
About machinate
- Birthday 01/01/1
Gender
Not Telling
machinate's Achievements
I may be a super-noob in these areas, but why does the connection between c3 and c4 run between the legs of the chip? That seems like some auto-routing gone bad! And if you take the "trace" from pin 6 of the chip underneath the chip instead you can do without the wire bridge by bringing pin 5 around the audio output?
Do you have a link for this? Searching Conrad is a pain and doesn't come up with anything for Anreihtaster.cheers. Andreas
attila, you might want to read the text in the link - as far as I can tell you set the pitches with 10 pots, nothing else - it's a lot simpler, and probably a better solution than all those switches...
Word. You're our golden goose, Thorsten, we want you to liiiiive! :D
http://www.geocities.com/thetonegod/vanpoint2/van_point2.html
very cool project - I worked with similar stuff a long time ago when I was into circuit-bending - the "light-theremin" style circuitbends are all about the 555 - they often pop up on ebay. Get Lofi have a write-up on the 555 as well: http://www.uoguelph.ca/%7Eantoon/gadgets/555/555.html btw, for anyone even slightly interested in lofi gadgetry the GetLofi site is very nice:) http://www.getlofi.com/
MIDIbox of the Week (MB64E based Traktor Controller made by PayC)
machinate replied to TK.'s topic in MIDIbox of the Week
check out the changelog: http://ucapps.de/midibox64e_changelog.html -since 2.1: "experimental" support for ain and mf modules -
yeah man, good luck - we should get together and share parts ;) hehe. Any idea on how to case it yet?
did you make the transparent buttons yourself? Could you give a quick run-down of the process? Thanks. -
perhaps midi clock sync? I'd love that.
yes, these should be wired to the dinx4 just like an ordinary button, if memory serves. a.
hey Artesia, that design looks awesome. One question though: Won't the handles get in the way when operating the sequencer?
yes. However, by using two different din registers (as in an 8x16 matrix) you would get this effect - and also very neat connections to and from the keypad - at least that's what I'm hoping for: Each keypad takes one of the douts on the common pin and distributes to all 16 dins
these buttons really are cool as f**k! Tiny tiny assembly. The feel of the button is weird, kind of like firm Gameboy buttons. I like it, although they may be a bit too firm for a high-end performance controller. Dunno, they'll definitely be wired up asap for testing. I do have a question about these buttons though. They're arranged in a 16pin+1pin configuration, as opposed to keypads with 2 dedicated pins per button. Could that be a problem when used with the scan matrix? I've got other, bigger buttons lined up if it doesn't work.
