kokoon Posted September 3, 2005 Report Posted September 3, 2005 i put flooded in quotes because i don't think it's really a flood.if i twiddle a knob on a midi controller too furiously i get the whole thing to stop responding. last note plays on and nothing changes. have to turn it off and back on.since it's not like 10000000 midi CC messages per second i'm assuming something is wrong.now my question would be - is this supposed behaviour? will it be the same with the cs?thanks guys, i just built a mbsid and i LOVE it. but this really bothers me.
pwx Posted September 3, 2005 Report Posted September 3, 2005 hi!I´ve got a MBSID with minimal CS,.... and I have this problem only a few times... if I´m carefull and send only the MIDI-Data SID really needs, there´s no problem....Perhaps it´s normal to have a MIDI-hang (sorry, don´t know the right word in English) sometimes..... I think it´s the same with some analog-synths,... sometimes..... Please tell me if I´m wrong!!!hope this helps,..pwx :)
TK. Posted September 3, 2005 Report Posted September 3, 2005 I don't know this effect, maybe because I'm working with a much more advanced firmware since some months?Are you using the most recent version of MIOS and MBSID?-> http://www.ucapps.de/mios/mios_v1_8.zip-> http://www.ucapps.de/mios/midibox_sid_v1_7_303beta9.zipBest Regards, Thorsten.
pwx Posted September 3, 2005 Report Posted September 3, 2005 Hi Thorsten!I´m using MIOS 1.7,..... :) but it´s really no problem,... I´ve got the same with my Fricke mfb synth 2 ..... one or two times in a whole year,.... and the same with MBSID,... so this should be a `normal` Hardware Problem,... ;DI don´t care about it....... , every hardware Synth has it´s own personallity :oBut I´ll try MIOS v1.8 next week.....greets,pwx
TK. Posted September 3, 2005 Report Posted September 3, 2005 The difference between MIOS V1.8 and V1.7 isn't so big, so this is not the reason. There was a problem with MIOS V1.6, which is fixed in both versions.Testing the updated MBSID application makes more sense. I always take care that such MIDI overruns never happen, if you've found a way to hang up the MIDI engine, then please send me the appr. patch (but please: try it out with the most recent firmware first)Best Regards, Thorsten.
kokoon Posted September 3, 2005 Author Report Posted September 3, 2005 i'm running MIOS 1.8 and SID 1.7a.i'll try with the new SID app.but - in short - what happened:i have this M-AUDIO radium49 and it has a terribly slow pot readout refresh rate - if i turn a pot quickly i only get 5 or so values. even only 1 if i try really hard. so i made a patch in pd which interpolates incomming midi controller values so i can use my radium. the patch works fine. i thought until now :)
kokoon Posted September 5, 2005 Author Report Posted September 5, 2005 okay i tested this with MIOS 1.8 and SID 1.7 303beta9it's still happening but only with 8580. the second core+sid 6581 is okay. hmm if you want i can send you a screenshot of midiox out-monitor. but it's really not that interesting - just a few CC sends for filter cutoff...
kokoon Posted September 7, 2005 Author Report Posted September 7, 2005 any ideas TK? i found out that i have to re-upload SID application everytime it freezes... and it also happens with pitchshifts (if there are many)... will this happen with the control surface too?
TK. Posted September 7, 2005 Report Posted September 7, 2005 I wasn't able to reproduce the error yet, maybe it only happens at certain patches? Which patch are you using exactly?Best Regards, Thorsten.
kokoon Posted September 7, 2005 Author Report Posted September 7, 2005 just anything really. i uploaded mios, then uploaded sid (latest version) and i just press a key on my keyboard and send a stream of CCs... and i'm there.is it possible that the sid chip is faulty? cause as it is now it really isn't very usable via midi. strange thing though - the jsynth tweaking is smooth enough and it never freezes. maybe jsynth works with sysex?
TK. Posted September 7, 2005 Report Posted September 7, 2005 Yes, JSynthLib works with SysEx... the SID chip shouldn't cause such a problem, because there is no feedback to the core. Means: regardless if a SID is connected or not, the application should never freeze.I've really no idea what should cause such a scenario, just let me some days, maybe I will be able to reproduce this sooner or later... if anybody else but kokoon and pwx is able to stimulate the hang-up, please let me know.Best Regards, Thorsten.
tarzan boy Posted September 7, 2005 Report Posted September 7, 2005 i just got my first 6581R2 running this morning and I have a similar problem I thought i would contribute to maybe help solve a potential problem. I'm using mios 1.8 and sid1.7a as well, and using Jsynthlib (the only way i have right now of changing the sounds predictably) if I make some drastic changes in envelope, modulation matrix, or oscillation settings (transpose, etc) my sid starts to whine a high pitch in between every note. when i stop sending any midi data the high pitch just stays there. I have to use jsynthlib to reload a patch in order for the high pitch to stop.
kokoon Posted September 8, 2005 Author Report Posted September 8, 2005 i don't think that's the same problem tarzan boy... mine freezes completely at the note it was playing and i have to turn it off and back on.TK: if there's no feedback from the SID chip to core then is it maybe possible that the SID itself freezes? well it doesn't freeze completely since the osc's are still running... let me know what to prepare (sound sample of the freeze, screenshot of midiox output, ...) and i'll make it and send it to you (or post it here)
TK. Posted September 11, 2005 Report Posted September 11, 2005 my sid starts to whine a high pitch in between every note. when i stop sending any midi data the high pitch just stays there.thats a 6581 typical problem, see also http://www.midibox.org/forum/index.php?topic=5373.0So, it seems that Kokoon is currently the only one who notice such problems... TK: if there's no feedback from the SID chip to core then is it maybe possible that the SID itself freezes? well it doesn't freeze completely since the osc's are still running...There is only one scenario where the SID oscillator can lock up, and this happens when noise is selected together with another waveforms. But this illegal mode is prevented by the MBSID firmware, and I'm very very sure that it cannot happen (I'm doing SID sound design very often, I should notify such errors...)let me know what to prepare (sound sample of the freeze, screenshot of midiox output, ...) and i'll make it and send it to you (or post it here)A sound sample and the MIDI input trace (via MIDI-Ox) could be interesting. Are you able to reproduce this problem with one of the default patches, or did you create a special patch?Best Regards, Thorsten.P.S.: I will be quite busy in the next weeks, therefore please forgive the high delays between the answers...
kokoon Posted September 12, 2005 Author Report Posted September 12, 2005 i don't deal with "patches" (or at least i think i don't) - i can load the MBSID application and just run the sequencer and the freeze occurs. (as i just found out) - samples coming right now.
kokoon Posted September 12, 2005 Author Report Posted September 12, 2005 okay this is what's happening:i re-loaded the MBSID freshly. then i started the audio recording and cleared midi (output) monitor. then i played some random notes (TS 28712 - TS 34853) then i pressed "back" in midi sequencer (to reset to position zero - and apparently set all controlers to zero), pressed+released another note, and then started the sequencer. (TS 39775). it played almost a whole loop but then froze @ TS 40663 (bold). the "okay" notes are light color, the critical note is bolded black, the ignored are normal black.here's an mp3 audio of this phenomenon.http://s4.yousendit.com/d.aspx?id=0NZUVDCO85YMZ0R80LP6KZRPZVand this is the midi-ox dump of the output monitor (color-coded by hand):[tt] TIMESTAMP IN PORT STATUS DATA1 DATA2 CHAN NOTE EVENT 28577 2 14 144 47 127 1 B 2 Note On 28712 2 14 144 47 0 1 B 2 Note Off 29397 2 14 144 45 127 1 A 2 Note On 29519 2 14 144 45 0 1 A 2 Note Off 30220 2 14 144 55 127 1 G 3 Note On 30271 2 14 144 55 0 1 G 3 Note Off 30617 2 14 144 49 127 1 C# 3 Note On 30714 2 14 144 49 0 1 C# 3 Note Off 31400 2 14 144 45 127 1 A 2 Note On 31591 2 14 144 57 127 1 A 3 Note On 31852 2 14 144 57 0 1 A 3 Note Off 31943 2 14 144 45 0 1 A 2 Note Off 32491 2 14 144 45 127 1 A 2 Note On 32688 2 14 144 57 127 1 A 3 Note On 32897 2 14 144 57 0 1 A 3 Note Off 33078 2 14 144 45 0 1 A 2 Note Off 33536 2 14 144 45 127 1 A 2 Note On 33902 2 14 144 57 127 1 A 3 Note On 34145 2 14 144 57 0 1 A 3 Note Off 34286 2 14 144 45 0 1 A 2 Note Off 34607 2 14 144 45 127 1 A 2 Note On 34706 2 14 144 57 127 1 A 3 Note On 34841 2 14 144 57 0 1 A 3 Note Off 34853 2 14 144 45 0 1 A 2 Note Off 37195 2 14 176 123 0 1 --- CC: All Notes Off 38323 2 14 144 45 127 1 A 2 Note On 38440 2 14 144 45 0 1 A 2 Note Off 39775 2 14 176 123 0 1 --- CC: All Notes Off 39787 2 14 144 36 127 1 C 2 Note On 39910 2 14 128 36 0 1 C 2 Note Off 39910 2 14 144 36 127 1 C 2 Note On 40037 2 14 128 36 0 1 C 2 Note Off 40038 2 14 144 42 127 1 F# 2 Note On 40158 2 14 144 36 127 1 C 2 Note On 40192 2 14 128 42 0 1 F# 2 Note Off 40286 2 14 128 36 0 1 C 2 Note Off 40286 2 14 144 36 127 1 C 2 Note On 40413 2 14 128 36 0 1 C 2 Note Off 40413 2 14 144 30 127 1 F# 1 Note On 40537 2 14 144 36 127 1 C 2 Note On 40562 2 14 128 30 0 1 F# 1 Note Off 40663 2 14 128 36 0 1 C 2 Note Off 40663 2 14 144 36 127 1 C 2 Note On 40785 2 14 144 54 127 1 F# 3 Note On 40821 2 14 128 36 0 1 C 2 Note Off 41032 2 14 128 54 0 1 F# 3 Note Off 41033 2 14 144 42 127 1 F# 2 Note On 41164 2 14 128 42 0 1 F# 2 Note Off 41164 2 14 144 36 127 1 C 2 Note On 41284 2 14 128 36 0 1 C 2 Note Off 41284 2 14 144 39 127 1 Eb 2 Note On 41412 2 14 144 36 127 1 C 2 Note On 41441 2 14 128 39 0 1 Eb 2 Note Off 41534 2 14 128 36 0 1 C 2 Note Off 41534 2 14 144 36 127 1 C 2 Note On 41659 2 14 128 36 0 1 C 2 Note Off 41659 2 14 144 36 127 1 C 2 Note On 41691 2 14 128 36 0 1 C 2 Note Off 41691 2 14 176 123 0 1 --- CC: All Notes Off 41785 2 14 144 36 127 1 C 2 Note On 41911 2 14 128 36 0 1 C 2 Note Off 41911 2 14 144 36 127 1 C 2 Note On 42032 2 14 128 36 0 1 C 2 Note Off 42032 2 14 144 42 127 1 F# 2 Note On 42161 2 14 144 36 127 1 C 2 Note On 42191 2 14 128 42 0 1 F# 2 Note Off 42286 2 14 128 36 0 1 C 2 Note Off 42286 2 14 144 36 127 1 C 2 Note On 42412 2 14 128 36 0 1 C 2 Note Off 42412 2 14 144 30 127 1 F# 1 Note On 42538 2 14 144 36 127 1 C 2 Note On 42567 2 14 128 30 0 1 F# 1 Note Off 42659 2 14 128 36 0 1 C 2 Note Off 42659 2 14 144 36 127 1 C 2 Note On 42752 2 14 128 36 0 1 C 2 Note Off 42752 2 14 176 123 0 1 --- CC: All Notes Off [/tt]
TK. Posted September 12, 2005 Report Posted September 12, 2005 Thats a very uncritical timing, I've still no explanation. Even if your MIDI interface sends an invalid MIDI frame (e.g. due to a slightly different baudrate, or spikes on the transmission line), the PIC should regognize this, it should set an error flag, which thereafter should lead to a MIDI timeout in MIOS.Could you please try to reproduce this again? Thereafter use the RAM Readout function of MIOS Studio to dump out the RAM content from 0x000-0x600. Please also post the MIDI-Ox Logfile again. This should give me an overview of the system state, when this happensBest Regards, Thorsten.P.S.: your sequencer sends an "all notes off" (CC#123) when you stop it - thats bad for the MBSID, since CC#123 controls Parameter#3 of the wavetable sequencer. However, this is not the problem here... but maybe it's better to turn off (or filter out) this option to avoid interferences with the sound patch
kokoon Posted September 13, 2005 Author Report Posted September 13, 2005 okay here goes.now i seemed to have no problems with just the previously posted sequence of notes, so i had to add some CCs to the sequence. then it froze.i didn't record it so i can't tell where exactly it happened but i turned the sequence almost immediately after SID froze.midi-ox output dump:[tt] TIMESTAMP IN PORT STATUS DATA1 DATA2 CHAN NOTE EVENT 496105 2 -- 176 123 0 1 --- CC: All Notes Off 496106 2 -- 176 47 50 1 --- Control Change 496106 2 -- 144 36 127 1 C 2 Note On 496107 2 -- 176 47 50 1 --- Control Change 496113 2 -- 176 47 50 1 --- Control Change 496119 2 -- 176 47 50 1 --- Control Change 496125 2 -- 176 47 50 1 --- Control Change 496127 2 -- 176 47 52 1 --- Control Change 496129 2 -- 176 47 53 1 --- Control Change 496130 2 -- 176 47 54 1 --- Control Change 496134 2 -- 176 47 54 1 --- Control Change 496140 2 -- 176 47 55 1 --- Control Change 496140 2 -- 176 47 56 1 --- Control Change 496140 2 -- 176 47 56 1 --- Control Change 496146 2 -- 176 47 56 1 --- Control Change 496151 2 -- 176 47 57 1 --- Control Change 496151 2 -- 176 47 57 1 --- Control Change 496157 2 -- 176 47 57 1 --- Control Change 496157 2 -- 176 47 58 1 --- Control Change 496163 2 -- 176 47 58 1 --- Control Change 496167 2 -- 176 47 58 1 --- Control Change 496169 2 -- 176 47 58 1 --- Control Change 496175 2 -- 176 47 58 1 --- Control Change 496181 2 -- 176 47 58 1 --- Control Change 496181 2 -- 176 47 58 1 --- Control Change 496194 2 -- 176 47 58 1 --- Control Change 496194 2 -- 176 47 55 1 --- Control Change 496200 2 -- 176 47 55 1 --- Control Change 496200 2 -- 176 47 54 1 --- Control Change 496212 2 -- 176 47 53 1 --- Control Change 496212 2 -- 176 47 54 1 --- Control Change 496218 2 -- 128 36 0 1 C 2 Note Off 496218 2 -- 144 36 127 1 C 2 Note On 496218 2 -- 176 47 54 1 --- Control Change 496218 2 -- 176 47 54 1 --- Control Change 496230 2 -- 176 47 54 1 --- Control Change 496230 2 -- 176 47 54 1 --- Control Change 496235 2 -- 176 47 54 1 --- Control Change 496237 2 -- 176 47 54 1 --- Control Change 496242 2 -- 176 47 54 1 --- Control Change 496242 2 -- 176 47 52 1 --- Control Change 496242 2 -- 176 47 51 1 --- Control Change 496242 2 -- 176 47 50 1 --- Control Change 496242 2 -- 176 47 50 1 --- Control Change 496250 2 -- 176 47 50 1 --- Control Change 496256 2 -- 176 47 50 1 --- Control Change 496256 2 -- 176 47 50 1 --- Control Change 496256 2 -- 176 47 50 1 --- Control Change 496262 2 -- 176 47 50 1 --- Control Change 496266 2 -- 176 47 50 1 --- Control Change 496274 2 -- 176 47 50 1 --- Control Change 496279 2 -- 176 47 50 1 --- Control Change 496288 2 -- 176 47 50 1 --- Control Change 496292 2 -- 176 47 50 1 --- Control Change 496294 2 -- 176 47 50 1 --- Control Change 496300 2 -- 176 47 50 1 --- Control Change 496300 2 -- 176 47 50 1 --- Control Change 496312 2 -- 176 47 50 1 --- Control Change 496317 2 -- 176 47 50 1 --- Control Change 496323 2 -- 176 47 50 1 --- Control Change 496329 2 -- 176 47 51 1 --- Control Change 496329 2 -- 176 47 52 1 --- Control Change 496335 2 -- 176 47 52 1 --- Control Change 496335 2 -- 128 36 0 1 C 2 Note Off 496335 2 -- 144 42 127 1 F# 2 Note On 496341 2 -- 176 47 52 1 --- Control Change 496341 2 -- 176 47 52 1 --- Control Change 496355 2 -- 176 47 52 1 --- Control Change 496360 2 -- 176 47 52 1 --- Control Change 496360 2 -- 176 47 52 1 --- Control Change 496366 2 -- 176 47 53 1 --- Control Change 496372 2 -- 176 47 53 1 --- Control Change 496372 2 -- 176 47 53 1 --- Control Change 496378 2 -- 176 47 53 1 --- Control Change 496384 2 -- 176 47 53 1 --- Control Change 496386 2 -- 176 47 53 1 --- Control Change 496390 2 -- 176 47 53 1 --- Control Change 496396 2 -- 176 47 53 1 --- Control Change 496400 2 -- 176 47 54 1 --- Control Change 496400 2 -- 176 47 56 1 --- Control Change 496400 2 -- 176 47 54 1 --- Control Change 496404 2 -- 176 47 55 1 --- Control Change 496410 2 -- 176 47 55 1 --- Control Change 496416 2 -- 176 47 56 1 --- Control Change 496416 2 -- 176 47 57 1 --- Control Change 496422 2 -- 176 47 56 1 --- Control Change 496426 2 -- 176 47 56 1 --- Control Change 496427 2 -- 176 47 57 1 --- Control Change 496433 2 -- 176 47 57 1 --- Control Change 496439 2 -- 176 47 57 1 --- Control Change 496442 2 -- 176 47 57 1 --- Control Change 496442 2 -- 176 47 57 1 --- Control Change 496442 2 -- 176 47 57 1 --- Control Change 496442 2 -- 176 47 57 1 --- Control Change 496444 2 -- 176 47 58 1 --- Control Change 496450 2 -- 176 47 57 1 --- Control Change 496456 2 -- 176 47 58 1 --- Control Change 496456 2 -- 144 36 127 1 C 2 Note On 496462 2 -- 176 47 57 1 --- Control Change 496462 2 -- 176 47 58 1 --- Control Change 496462 2 -- 176 47 58 1 --- Control Change 496468 2 -- 176 47 58 1 --- Control Change 496468 2 -- 176 47 58 1 --- Control Change 496480 2 -- 176 47 58 1 --- Control Change 496480 2 -- 176 47 58 1 --- Control Change 496485 2 -- 176 47 58 1 --- Control Change 496485 2 -- 128 42 0 1 F# 2 Note Off 496485 2 -- 176 47 58 1 --- Control Change 496491 2 -- 176 47 58 1 --- Control Change 496505 2 -- 176 47 58 1 --- Control Change 496511 2 -- 176 47 58 1 --- Control Change 496511 2 -- 176 47 58 1 --- Control Change 496517 2 -- 176 47 58 1 --- Control Change 496517 2 -- 176 47 58 1 --- Control Change 496517 2 -- 176 47 58 1 --- Control Change 496523 2 -- 176 47 58 1 --- Control Change 496525 2 -- 176 47 58 1 --- Control Change 496525 2 -- 176 47 57 1 --- Control Change 496527 2 -- 176 47 57 1 --- Control Change 496533 2 -- 176 47 57 1 --- Control Change 496534 2 -- 176 47 56 1 --- Control Change 496540 2 -- 176 47 56 1 --- Control Change 496547 2 -- 176 47 56 1 --- Control Change 496551 2 -- 176 47 56 1 --- Control Change 496553 2 -- 176 47 56 1 --- Control Change 496553 2 -- 176 47 56 1 --- Control Change 496559 2 -- 176 47 56 1 --- Control Change 496559 2 -- 176 47 55 1 --- Control Change 496566 2 -- 176 47 53 1 --- Control Change 496572 2 -- 176 47 53 1 --- Control Change 496576 2 -- 176 47 53 1 --- Control Change 496582 2 -- 176 47 53 1 --- Control Change 496588 2 -- 128 36 0 1 C 2 Note Off 496588 2 -- 144 36 127 1 C 2 Note On 496588 2 -- 176 47 53 1 --- Control Change 496598 2 -- 176 47 52 1 --- Control Change 496605 2 -- 176 47 52 1 --- Control Change 496617 2 -- 176 47 52 1 --- Control Change 496623 2 -- 176 47 52 1 --- Control Change 496627 2 -- 176 47 52 1 --- Control Change 496639 2 -- 176 47 53 1 --- Control Change 496639 2 -- 176 47 53 1 --- Control Change 496639 2 -- 176 47 53 1 --- Control Change 496647 2 -- 176 47 53 1 --- Control Change 496664 2 -- 176 47 53 1 --- Control Change 496664 2 -- 176 47 53 1 --- Control Change 496670 2 -- 176 47 53 1 --- Control Change 496670 2 -- 176 47 53 1 --- Control Change 496676 2 -- 176 47 53 1 --- Control Change 496682 2 -- 176 47 53 1 --- Control Change 496685 2 -- 176 47 53 1 --- Control Change 496687 2 -- 176 47 53 1 --- Control Change 496687 2 -- 176 47 53 1 --- Control Change 496692 2 -- 176 47 53 1 --- Control Change 496693 2 -- 176 47 53 1 --- Control Change 496699 2 -- 176 47 53 1 --- Control Change 496699 2 -- 176 47 53 1 --- Control Change 496699 2 -- 176 47 53 1 --- Control Change 496707 2 -- 176 47 52 1 --- Control Change 496710 2 -- 176 47 52 1 --- Control Change 496714 2 -- 176 47 52 1 --- Control Change 496716 2 -- 128 36 0 1 C 2 Note Off 496716 2 -- 144 30 127 1 F# 1 Note On 496720 2 -- 176 47 52 1 --- Control Change 496726 2 -- 176 47 52 1 --- Control Change 496726 2 -- 176 47 52 1 --- Control Change 496732 2 -- 176 47 52 1 --- Control Change 496737 2 -- 176 47 51 1 --- Control Change 496743 2 -- 176 47 51 1 --- Control Change 496743 2 -- 176 47 51 1 --- Control Change 496743 2 -- 176 47 51 1 --- Control Change 496749 2 -- 176 47 51 1 --- Control Change 496749 2 -- 176 47 51 1 --- Control Change 496755 2 -- 176 47 51 1 --- Control Change 496759 2 -- 176 47 51 1 --- Control Change 496759 2 -- 176 47 50 1 --- Control Change 496761 2 -- 176 47 50 1 --- Control Change 496761 2 -- 176 47 50 1 --- Control Change 496765 2 -- 176 47 50 1 --- Control Change 496766 2 -- 176 47 50 1 --- Control Change 496772 2 -- 176 47 50 1 --- Control Change 496772 2 -- 176 47 50 1 --- Control Change 496774 2 -- 176 47 50 1 --- Control Change 496776 2 -- 176 47 50 1 --- Control Change 496776 2 -- 176 47 50 1 --- Control Change 496782 2 -- 176 47 50 1 --- Control Change 496782 2 -- 176 47 50 1 --- Control Change 496788 2 -- 176 47 50 1 --- Control Change 496788 2 -- 176 47 49 1 --- Control Change 496794 2 -- 176 47 49 1 --- Control Change 496800 2 -- 176 47 49 1 --- Control Change 496801 2 -- 176 47 49 1 --- Control Change 496805 2 -- 176 47 49 1 --- Control Change 496813 2 -- 176 47 48 1 --- Control Change 496813 2 -- 176 47 48 1 --- Control Change 496813 2 -- 176 47 47 1 --- Control Change 496822 2 -- 176 47 47 1 --- Control Change 496822 2 -- 176 47 47 1 --- Control Change 496828 2 -- 176 47 47 1 --- Control Change 496828 2 -- 176 47 47 1 --- Control Change 496834 2 -- 176 47 47 1 --- Control Change 496836 2 -- 176 47 47 1 --- Control Change 496840 2 -- 176 47 47 1 --- Control Change 496840 2 -- 176 47 47 1 --- Control Change 496840 2 -- 176 47 47 1 --- Control Change 496846 2 -- 144 36 127 1 C 2 Note On 496846 2 -- 176 47 47 1 --- Control Change 496846 2 -- 176 47 47 1 --- Control Change 496852 2 -- 176 47 47 1 --- Control Change 496855 2 -- 176 47 47 1 --- Control Change 496855 2 -- 176 47 47 1 --- Control Change 496858 2 -- 176 47 47 1 --- Control Change 496858 2 -- 176 47 47 1 --- Control Change 496864 2 -- 176 47 47 1 --- Control Change 496868 2 -- 176 47 47 1 --- Control Change 496869 2 -- 176 47 47 1 --- Control Change 496869 2 -- 176 47 47 1 --- Control Change 496869 2 -- 176 47 47 1 --- Control Change 496873 2 -- 176 47 47 1 --- Control Change 496873 2 -- 128 30 0 1 F# 1 Note Off 496879 2 -- 176 47 47 1 --- Control Change 496879 2 -- 176 47 47 1 --- Control Change 496879 2 -- 176 47 47 1 --- Control Change 496885 2 -- 176 47 47 1 --- Control Change 496887 2 -- 176 47 47 1 --- Control Change 496891 2 -- 176 47 47 1 --- Control Change 496897 2 -- 176 47 47 1 --- Control Change 496897 2 -- 176 47 47 1 --- Control Change 496902 2 -- 176 47 47 1 --- Control Change 496904 2 -- 176 47 47 1 --- Control Change 496907 2 -- 176 47 47 1 --- Control Change 496912 2 -- 176 47 47 1 --- Control Change 496912 2 -- 176 47 47 1 --- Control Change 496912 2 -- 176 47 47 1 --- Control Change 496912 2 -- 176 47 47 1 --- Control Change 496912 2 -- 176 47 48 1 --- Control Change 496920 2 -- 176 47 48 1 --- Control Change 496926 2 -- 176 47 48 1 --- Control Change 496932 2 -- 176 47 50 1 --- Control Change 496938 2 -- 176 47 51 1 --- Control Change 496943 2 -- 176 47 49 1 --- Control Change 496946 2 -- 176 47 49 1 --- Control Change 496948 2 -- 176 47 52 1 --- Control Change 496948 2 -- 176 47 53 1 --- Control Change 496948 2 -- 176 47 54 1 --- Control Change 496954 2 -- 176 47 55 1 --- Control Change 496955 2 -- 128 36 0 1 C 2 Note Off 496955 2 -- 144 36 127 1 C 2 Note On 496961 2 -- 176 47 56 1 --- Control Change 496964 2 -- 176 47 58 1 --- Control Change 496964 2 -- 176 47 61 1 --- Control Change 496974 2 -- 176 47 61 1 --- Control Change 496974 2 -- 176 47 62 1 --- Control Change 496974 2 -- 176 47 63 1 --- Control Change 496980 2 -- 176 47 64 1 --- Control Change 496981 2 -- 176 47 64 1 --- Control Change 496986 2 -- 176 47 65 1 --- Control Change 496986 2 -- 176 47 65 1 --- Control Change 496992 2 -- 176 47 66 1 --- Control Change 496996 2 -- 176 47 67 1 --- Control Change 496996 2 -- 176 47 68 1 --- Control Change 497002 2 -- 176 47 68 1 --- Control Change 497004 2 -- 176 47 69 1 --- Control Change 497008 2 -- 176 47 70 1 --- Control Change 497014 2 -- 176 47 70 1 --- Control Change 497016 2 -- 176 47 71 1 --- Control Change 497018 2 -- 176 47 71 1 --- Control Change 497021 2 -- 176 47 72 1 --- Control Change 497024 2 -- 176 47 72 1 --- Control Change 497031 2 -- 176 47 72 1 --- Control Change 497037 2 -- 176 47 72 1 --- Control Change 497037 2 -- 176 47 73 1 --- Control Change 497043 2 -- 176 47 73 1 --- Control Change 497047 2 -- 176 47 73 1 --- Control Change 497047 2 -- 176 47 74 1 --- Control Change 497047 2 -- 176 47 74 1 --- Control Change 497053 2 -- 176 47 74 1 --- Control Change 497053 2 -- 176 47 74 1 --- Control Change 497059 2 -- 176 47 74 1 --- Control Change 497059 2 -- 176 47 74 1 --- Control Change 497059 2 -- 176 47 74 1 --- Control Change 497065 2 -- 176 47 74 1 --- Control Change 497068 2 -- 176 47 74 1 --- Control Change 497073 2 -- 176 47 75 1 --- Control Change 497079 2 -- 176 47 75 1 --- Control Change 497081 2 -- 176 47 75 1 --- Control Change 497085 2 -- 144 54 127 1 F# 3 Note On 497085 2 -- 176 47 75 1 --- Control Change 497091 2 -- 176 47 75 1 --- Control Change 497097 2 -- 176 47 75 1 --- Control Change 497103 2 -- 176 47 75 1 --- Control Change 497108 2 -- 176 47 75 1 --- Control Change 497108 2 -- 176 47 75 1 --- Control Change 497114 2 -- 128 36 0 1 C 2 Note Off 497120 2 -- 176 47 75 1 --- Control Change 497120 2 -- 176 47 75 1 --- Control Change 497134 2 -- 176 47 75 1 --- Control Change 497134 2 -- 176 47 75 1 --- Control Change 497146 2 -- 176 47 75 1 --- Control Change 497151 2 -- 176 47 75 1 --- Control Change 497157 2 -- 176 47 75 1 --- Control Change 497163 2 -- 176 47 75 1 --- Control Change 497163 2 -- 176 47 75 1 --- Control Change 497175 2 -- 176 47 75 1 --- Control Change 497179 2 -- 176 47 75 1 --- Control Change 497181 2 -- 176 47 75 1 --- Control Change 497181 2 -- 176 47 75 1 --- Control Change 497185 2 -- 176 47 75 1 --- Control Change 497190 2 -- 176 47 75 1 --- Control Change 497190 2 -- 176 47 75 1 --- Control Change 497196 2 -- 176 47 75 1 --- Control Change 497202 2 -- 176 47 75 1 --- Control Change 497206 2 -- 176 47 75 1 --- Control Change 497206 2 -- 176 47 75 1 --- Control Change 497206 2 -- 176 47 73 1 --- Control Change 497206 2 -- 176 47 73 1 --- Control Change 497214 2 -- 176 47 72 1 --- Control Change 497220 2 -- 176 47 73 1 --- Control Change 497220 2 -- 176 47 73 1 --- Control Change 497227 2 -- 176 47 73 1 --- Control Change 497232 2 -- 176 47 73 1 --- Control Change 497233 2 -- 176 47 73 1 --- Control Change 497239 2 -- 176 47 73 1 --- Control Change 497245 2 -- 176 47 73 1 --- Control Change 497245 2 -- 176 47 74 1 --- Control Change 497251 2 -- 176 47 74 1 --- Control Change 497251 2 -- 176 47 75 1 --- Control Change 497257 2 -- 176 47 75 1 --- Control Change 497257 2 -- 176 47 75 1 --- Control Change 497263 2 -- 176 47 76 1 --- Control Change 497263 2 -- 176 47 76 1 --- Control Change 497269 2 -- 176 47 78 1 --- Control Change 497274 2 -- 176 47 78 1 --- Control Change 497274 2 -- 176 47 79 1 --- Control Change 497280 2 -- 176 47 80 1 --- Control Change 497280 2 -- 176 47 80 1 --- Control Change 497280 2 -- 176 47 81 1 --- Control Change 497294 2 -- 176 47 81 1 --- Control Change 497300 2 -- 176 47 82 1 --- Control Change 497300 2 -- 176 47 83 1 --- Control Change 497300 2 -- 176 47 88 1 --- Control Change 497306 2 -- 176 47 89 1 --- Control Change 497306 2 -- 176 47 90 1 --- Control Change 497312 2 -- 176 47 91 1 --- Control Change 497317 2 -- 176 47 91 1 --- Control Change 497317 2 -- 176 47 92 1 --- Control Change 497323 2 -- 176 47 92 1 --- Control Change 497329 2 -- 176 47 93 1 --- Control Change 497329 2 -- 176 47 94 1 --- Control Change 497335 2 -- 176 47 94 1 --- Control Change 497339 2 -- 176 47 94 1 --- Control Change 497343 2 -- 176 47 96 1 --- Control Change 497343 2 -- 176 47 98 1 --- Control Change 497345 2 -- 176 47 99 1 --- Control Change 497347 2 -- 128 54 0 1 F# 3 Note Off 497347 2 -- 144 42 127 1 F# 2 Note On 497347 2 -- 176 47 99 1 --- Control Change 497351 2 -- 176 47 100 1 --- Control Change 497357 2 -- 176 47 101 1 --- Control Change 497357 2 -- 176 47 101 1 --- Control Change 497363 2 -- 176 47 102 1 --- Control Change 497367 2 -- 176 47 103 1 --- Control Change 497373 2 -- 176 47 103 1 --- Control Change 497375 2 -- 176 47 104 1 --- Control Change 497378 2 -- 176 47 105 1 --- Control Change 497382 2 -- 176 47 105 1 --- Control Change 497382 2 -- 176 47 106 1 --- Control Change 497382 2 -- 176 47 106 1 --- Control Change 497382 2 -- 176 47 107 1 --- Control Change 497383 2 -- 176 47 107 1 --- Control Change 497383 2 -- 176 47 108 1 --- Control Change 497383 2 -- 176 47 108 1 --- Control Change 497389 2 -- 176 47 108 1 --- Control Change 497397 2 -- 176 47 109 1 --- Control Change 497397 2 -- 176 47 109 1 --- Control Change 497402 2 -- 176 47 109 1 --- Control Change 497406 2 -- 176 47 110 1 --- Control Change 497412 2 -- 176 47 110 1 --- Control Change 497412 2 -- 176 47 110 1 --- Control Change 497418 2 -- 176 47 110 1 --- Control Change 497424 2 -- 176 47 110 1 --- Control Change 497430 2 -- 176 47 110 1 --- Control Change 497430 2 -- 176 47 110 1 --- Control Change 497451 2 -- 176 47 110 1 --- Control Change 497451 2 -- 176 47 110 1 --- Control Change 497457 2 -- 176 47 110 1 --- Control Change 497457 2 -- 176 47 110 1 --- Control Change 497463 2 -- 176 47 110 1 --- Control Change 497465 2 -- 128 42 0 1 F# 2 Note Off 497466 2 -- 144 36 127 1 C 2 Note On 497468 2 -- 176 47 110 1 --- Control Change 497474 2 -- 176 47 110 1 --- Control Cha
TK. Posted September 13, 2005 Report Posted September 13, 2005 Again: could you please create a RAM dump? This is a problem which cannot be reproduced on another hardware, therefore the MIDI data alone doesn't help, regardless how long the log file is...-> http://www.midibox.org/mios_studio/mios/gui/help/mios_debug_functions.htmlSRAM Read, Address 0x000, No. Bytes 0x600Best Regards, Thorsten.
kokoon Posted September 13, 2005 Author Report Posted September 13, 2005 hmm apparently the forum cutt off that part of my post, i posted both ram dump and midiox dump.[tt]0000: 00 04 00 40 1F 01 06 05 F8 00 02 50 00 00 40 FF0010: 08 00 00 04 00 00 00 00 40 00 00 00 00 00 00 000020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 000030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 000040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 000050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 000060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0F 000070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 000080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 000090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0000A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0000B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0000C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0000D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0000E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0000F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 000100: 07 03 00 08 21 00 F0 07 03 00 08 00 00 F0 27 080110: 00 08 00 00 F0 03 06 61 1F 0A 00 BC 9D 00 01 020120: 07 03 00 08 21 00 F0 07 03 00 08 00 00 F0 27 080130: 00 08 00 00 F0 03 06 61 1F 02 00 00 00 00 00 000140: 00 00 00 1E A1 07 03 00 40 40 0C 14 40 00 00 000150: 00 00 00 00 00 00 00 00 1E 00 00 00 1E 00 00 000160: 00 00 00 1E A3 07 03 00 40 40 02 00 40 00 00 000170: 00 00 00 00 00 00 00 00 1E 00 00 00 1E 00 00 000180: 00 00 00 1E A3 27 08 00 00 42 02 00 40 00 00 000190: 00 00 00 00 00 00 00 00 1E 00 00 00 1E 00 00 0001A0: 87 10 0A 3F 7F 59 A6 87 20 06 11 00 84 7B 01 3001B0: 01 04 7F 7E 81 01 40 01 85 00 11 EE 01 50 03 4401C0: 7F 53 AC 81 60 00 18 00 84 7D 07 00 00 00 64 0001D0: 00 42 64 00 00 00 00 00 60 60 20 40 00 00 FF FF01E0: 00 00 7F 7F 00 00 7F 00 00 00 7F 00 20 10 00 0001F0: 57 FF 40 03 01 00 40 00 DE F3 08 00 F0 9E 07 000200: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 000210: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 000220: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 000230: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 000240: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 000250: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 000260: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 000270: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 000280: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 000290: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0002A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0002B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0002C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0002D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0002E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0002F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 000300: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 000310: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 000320: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 000330: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 000340: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 000350: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 000360: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 000370: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 000380: 03 03 03 03 00 FD 00 00 00 00 00 00 00 00 00 000390: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0003A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0003B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0003C0: 81 82 82 82 81 82 00 00 00 00 00 00 00 00 00 0003D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0003E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0003F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 000400: 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 000410: 03 00 03 00 03 00 03 00 03 00 00 00 00 00 03 000420: 03 00 00 00 03 00 03 00 03 00 03 00 03 00 03 000430: 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 000440: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 000450: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 000460: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 000470: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 000480: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 000490: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0004A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0004B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0004C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0004D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0004E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0004F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 000500: 00 00 7E 40 00 0D 02 00 00 00 00 06 00 00 00 000510: 00 00 F7 2F 35 B0 2F 35 B0 2F 35 B0 2F 35 B0 2F0520: 35 B0 2F 35 B0 2F 35 B0 2F 34 B0 2F 34 B0 2F 340530: 80 24 00 90 1E 7F B0 2F 34 B0 2F 34 B0 2F 34 F00540: 0B 00 02 0F 03 04 0F 00 00 0B 00 00 00 02 00 0F0550: 00 03 00 04 00 0F 00 00 00 00 00 0B 00 00 00 000560: 00 00 00 02 00 00 00 0F 00 00 00 00 00 00 00 000570: 00 00 00 00 00 00 00 00 37 24 40 00 00 06 01 000580: 06 00 29 00 00 00 37 07 00 00 40 14 54 40 FF 000590: 00 0F 0F F7 12 12 00 67 68 00 F7 00 06 00 F6 0005A0: F7 B0 2F 34 30 CD 08 00 09 01 01 00 00 00 00 0005B0: 03 06 00 04 05 00 35 00 00 49 05 00 00 FF 40 1F05C0: 01 FF 00 FF 00 01 E0 00 00 00 00 00 00 00 00 0005D0: 00 00 00 00 00 00 00 00 04 00 00 00 00 00 00 0005E0: FF FF FF FF FF FF FF FF FF 00 00 00 00 00 00 0005F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00Done[/tt]
TK. Posted September 13, 2005 Report Posted September 13, 2005 Ok, what I've seen so far: the note stack for osc1is located at 0x15c-0x15f:0150: 00 00 00 00 00 00 00 00 1E 00 00 00 1E 00 00 00The first position of the stack contains "1E", which means,that note 1E = C-2 is playedUnfortunately the logfile doesn't show a Note Off... ok,so let's assume that at this time the MIDI transferwas already stucked. Let's search for more informations...The MIDI In Buffer is located at 0x500-0x53f0500: 00 00 7E 40 00 0D 02 00 00 00 00 06 00 00 00 000510: 00 00 F7 2F 35 B0 2F 35 B0 2F 35 B0 2F 35 B0 2F0520: 35 B0 2F 35 B0 2F 35 B0 2F 34 B0 2F 34 B0 2F 340530: 80 24 00 90 1E 7F B0 2F 34 B0 2F 34 B0 2F 34 F0The last received events before the SysEx Request (whichbegins at 0x53f) are: 80 24 00 90 1E 7F B0 2F 34 B0 2F 34 B0 2F 3480 24 00: thats a note-off message for F#290 1E 7F: thats a note-on message for C-2B0 2F 34: thats CC#47, Dec-Value 52B0 2F 34: thats CC#47, Dec-Value 52B0 2F 34: thats CC#47, Dec-Value 52F0 ...: SysEx message (RAM read) begins hereCC#47 (Resonance parameter) is a 4bit SID register,it's located at 0x117, bit 4-7:0110: 00 08 00 00 F0 03 06 61 1F 0A 00 BC 9D 00 01 02bit 4-7 of 0x117 is: 6The 4-bit value of the received CC#52 is: 52 >> 3 = 6In other words: the last MIDI events which were received by the MBSID are stored correctly. There isan active C-2 note, can you confirm this?Ok, lets search for the logfile entry where F#2/C-2 wassent, and thereafter 3 times a CC#47 with value 52:Hm... and here I have a problem: the last combinationI found was: 497465 2 -- 128 42 0 1 F# 2 Note Off 497466 2 -- 144 36 127 1 C 2 Note On 497468 2 -- 176 47 110 1 --- Control Change 497474 2 -- 176 47 110 1 --- Control ChaCC#47 is 110, and not 52So, I'm missing something in the logfile. Maybe this wasalso lost... (there is a character limit in the forum)but now you should know, which informations are interesting for me: the events at exactly the point where the note gets stuckedHowever, another point: During the analysis I remembered that a friend has a similar problem with his M-Audio Delta1010Soundcard/MIDI Interface. Once a lot of MIDI traffic is sentout, the interface stucks and he had to reboot his PC.I don't want to say that you've exactly the same problem(because of two things: you don't need to reboot your PC,and you are still able to send SysEx data)... but driver bugsare things which have to be considered.Therefore not only an updated logfile (which shows the interesting moment) could be useful, but also the resultsof a loopback test. You can do this in the following way: after the SID stucked,enable the MIDI merger via MIOS-Studio (select theMIOS_MIDI_MergerSet command and send WREG=0x01". Thereaftersend some notes to the core module and check if they arereceived back. Do the same test after power-on of themodule (doublechecking)If you don't receive any MIDI data back from the coremodule when MIDI merger is enabled, you know that yourMIDI interface doesn't send any CC/Note values anymoreAnother point: it could be, that sending a SysEx message"resets" your MIDI interface. In this case followingadditional tests would be interesting:- enable MIDI merger via MIOS-Studio, thereafter try toget the MBSID stucking again, thereafter check if MBSID still returns the sent events (if not, you arevery sure that Notes/CCs are not sent by the MIDI interface anymore)- once MBSID doesn't react anymore, send a SysEx message(e.g. MIDI Merger enable, or RAM read), and thereaftersend a Note-Off event of the note which got stuck. Ifthis works, then you know that a SysEx message resetsyour MIDI interface... in this case I would say, that itis definitely a bug in the driver of your interfaceAny new inputs?Best Regards, Thorsten.
kokoon Posted September 13, 2005 Author Report Posted September 13, 2005 hmm thanks alot for the in-depth comment and analysis. i'll try some more stuff tomorrow.another thing that got lost 2 posts ago (got cut off) - is it possible that lack of midi-in gnd connection is the fault for all this?is it possible that a hardware fault (a bad solder joint?) is causing such an error?okay on to the point. there really isn't a F#2off C-2on and three times CC#47 value 52 in the stream, i've checked both output dump of midiox and input dump and there simply isn't such combo. i guess it's safe to assume that the core got something else than i was trying to send it (correct me if i'm wrong)though there's a 496335 2 -- 128 36 0 1 C 2 Note Off 496335 2 -- 144 42 127 1 F# 2 Note On 496341 2 -- 176 47 52 1 --- Control Change 496341 2 -- 176 47 52 1 --- Control Change 496355 2 -- 176 47 52 1 --- Control Change but from the looks of "80 24 00" and "90 1E 7F" i assume the last byte of each is velocity (first one is off and the second one is on-127) so i guess there's no mistake on your analysis :).about the note C-2 being stuck - i'm really not sure... i remember it was something not too high and not too low so i guess it's pretty possible it was C-2. but not for sure. i'll record it all for the next test and i'll choose the test notes and controller values more carefully.also - i'll try another midi interface i have (an M-AUDIO radium) and maybe i'll find out that one's okay... hmmm why the hell haven't i thought about that before?! actually it's quite possible that the ancient roland midi adapter i'm using mixes some stuff up!i'll check it out in the morning and report back. i hope it wasn't such a stupid mistake :-[ :-[ :-[
