Help for initial setup (Dark Display, but responses to SysEx) - two displays
Hi all,
i try to study as much of the information here as possible, however i need help:
a) i connected 3 BankSticks as in the Diagram on a seperate Board.
b) this is connected to CORE
c) ONE LCD (4x20) is connected to the CORE as well.
d) When in debug mode i use "LCD_init" i can see the display working (also with display).
what i need help with:
1) how to connect the second 4x20 display
2) is the PIC programmed right ? mine was programmed by mike with zero values ????
3) i am seeing the SysEX Request, but loading either main, mios or setup_seq does not yield in any results except
  "some" blocks got confirmed.
4) the display just stays dark after the update
please help !!!
--jan
http://www.ucapps.de/mbhp/mbhp_2xclcd.pdf
But this is only supported by MB LC nad SEQ (You didn't say what app you're using)
Should be OK.
What midi interface are you using? What program are you using for upload?
Have you tried MIOSStudio for upload: http://miosstudio.midibox.org/
Afer a successful MIOS upload you should get a "READY" from your display.
What are you loading? First load MIOS, then the application.
well. i am building the SEQ one :-)
en detail that means, i have to run the complete BUS to BOTH LED's ?
hum, have to see how i can do this the easy way...
i am using the one on the CORE, but will try the LTC (maybe Optocoupler Failure on CORE).
i tried both tools, also i got the message (when uploading) "CRC ...OK" so it looks normal, but just the display
display nothing ...
i try to upload 1.8 MIOS (hex file).
not to forget to add: the 2 x 40 Display is from Mike and the Model Descriptions are:
DisplayTech LCD Module 402A BC BC
I did further testing:
- +5V testing : all ok
- ground testing : all ok
- Optocoupler Test: all o.k.
- MIDI in /out test o.k.
- midi in  polarity o.k.
trying to upload the code yield in no positive results ..
any hints ?
ah yes: i am seeing the requests from the Box , and code uploads he ACKS.
--jan
the output i get from midi studio when try to flash the MIOS is the following:
timestamp 1479352000 us: Sysex message: F0 00 00 7E 40 00 0F 32 F7
timestamp 1481186000 us: Sysex message: F0 00 00 7E 40 00 0F 19 F7
timestamp 1482098000 us: Sysex message: F0 00 00 7E 40 00 0F 5F F7
timestamp 1487563000 us: Sysex message: F0 00 00 7E 40 00 0F 1E F7
timestamp 1490329000 us: Sysex message: F0 00 00 7E 40 00 0F 61 F7
timestamp 1493070000 us: Sysex message: F0 00 00 7E 40 00 0F 1D F7
timestamp 1504817000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 1508416000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 1512016000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 1515616000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 1519215000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 1522814000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 1526415000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 1530016000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 1537263000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 1540174000 us: Sysex message: F0 00 00 7E 40 00 0F 0B F7
timestamp 1546557000 us: Sysex message: F0 00 00 7E 40 00 0F 40 F7
timestamp 1559336000 us: Sysex message: F0 00 00 7E 40 00 0F 38 F7
timestamp 1564820000 us: Sysex message: F0 00 00 7E 40 00 0F 5E F7
timestamp 1568460000 us: Sysex message: F0 00 00 7E 40 00 0F 0A F7
timestamp 1586599000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 1590197000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 1593798000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 1597398000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 1617655000 us: Sysex message: F0 00 00 7E 40 00 0F 22 F7
timestamp 1620407000 us: Sysex message: F0 00 00 7E 40 00 0F 5A F7
timestamp 1632264000 us: Sysex message: F0 00 00 7E 40 00 0F 31 F7
timestamp 1634089000 us: Sysex message: F0 00 00 7E 40 00 0F 07 F7
timestamp 1641402000 us: Sysex message: F0 00 00 7E 40 00 0F 43 F7
timestamp 1645960000 us: Sysex message: F0 00 00 7E 40 00 0F 5D F7
timestamp 1653277000 us: Sysex message: F0 00 00 7E 40 00 0F 64 F7
timestamp 1654189000 us: Sysex message: F0 00 00 7E 40 00 0F 35 F7
timestamp 1656016000 us: Sysex message: F0 00 00 7E 40 00 0F 4F F7
timestamp 1657838000 us: Sysex message: F0 00 00 7E 40 00 0F 3A F7
timestamp 1658756000 us: Sysex message: F0 00 00 7E 40 00 0F 76 F7
timestamp 1664228000 us: Sysex message: F0 00 00 7E 40 00 0F 2C F7
timestamp 1670501000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 1674101000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 1677700000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 1681299000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 1684899000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 1688498000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 1692097000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 1736091000 us: [F8] Timing clock
timestamp 1736095000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 1749124000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 1752723000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 1756324000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 1759922000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 1763523000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 1767122000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 1770723000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 1774323000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 1777923000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 1786353000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 1787444000 us: Sysex message: F0 00 00 7E 40 00 0F 5A F7
timestamp 1800231000 us: Sysex message: F0 00 00 7E 40 00 0F 57 F7
timestamp 1815758000 us: Sysex message: F0 00 00 7E 40 00 0F 37 F7
timestamp 1818491000 us: Sysex message: F0 00 00 7E 40 00 0F 1E F7
timestamp 1823962000 us: Sysex message: F0 00 00 7E 40 00 0F 1D F7
timestamp 1827613000 us: Sysex message: F0 00 00 7E 40 00 0F 31 F7
timestamp 1835709000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 1839308000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 1842907000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 1846508000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 1850107000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 1853706000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 1857306000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 1860905000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 1864505000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 1868104000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 1884695000 us: Sysex message: F0 00 00 7E 40 00 0F 10 F7
timestamp 1885605000 us: Sysex message: F0 00 00 7E 40 00 0F 61 F7
timestamp 1895648000 us: Sysex message: F0 00 00 7E 40 00 0F 33 F7
timestamp 1903864000 us: Sysex message: F0 00 00 7E 40 00 0F 69 F7
timestamp 1906606000 us: Sysex message: F0 00 00 7E 40 00 0F 66 F7
timestamp 1917583000 us: Sysex message: F0 00 00 7E 40 00 0F 02 F7
timestamp 1919408000 us: Sysex message: F0 00 00 7E 40 00 0F 7D F7
timestamp 1926747000 us: Sysex message: F0 00 00 7E 40 00 0F 4F F7
timestamp 1931324000 us: Sysex message: F0 00 00 7E 40 00 0F 24 F7
timestamp 1935912000 us: Sysex message: F0 00 00 7E 40 00 0F 07 F7
timestamp 1941281000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 1944880000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 1948480000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 1952080000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 1955680000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 1959280000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 1962880000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 1966481000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 1970079000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 1973678000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 1977278000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 1980879000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 1984477000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 1988077000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 1991678000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 1995278000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 1998878000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 2002478000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 2006079000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 2009677000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 2013278000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 2016879000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 2020477000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 2024077000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 2027677000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 2031276000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 2034875000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 2038475000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 2042074000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 2045673000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 2049273000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 2052873000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 2056473000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 2060072000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 2063671000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 2067271000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 2070871000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 2074470000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 2078070000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 2081670000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 2085270000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 2088869000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 2092470000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 2096070000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 2099669000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 2103269000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 2106870000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 2110469000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 2114069000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 2117669000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 2121267000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 2124867000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 2128468000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 2132066000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 2135666000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 2139267000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 2142868000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 2146466000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 2150066000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 2153666000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 2157265000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 2160864000 us: Sysex message: F0 00 00 7E 40 00 01 F7
timestamp 2164464000 us: Sysex message: F0 00 00 7E 40 00 01 F7
so anybody has a clue ?
