Dangerous to drive the Core directly with 5V from PC-PSU?
As I allready described in another thread I now use an external pc-psu to drive my MBLC.
We all know that those PSU deliver 5V which is to low to put it through the voltage regulator.
That's why I connected it direclty to J2. Everything was fine and I felt safe just until I realized
yesterday that the output voltage is 5,4V. Is this dangerous for the pic? I didn't find information
in the PIC's datasheet. Who has experience with PC-PSUs and the core module? Are there other
dangers when using J2? any precautions?
regards
rambinator
I'm using an external supply on J2 ob my testing setup. It's from a Lacie external HD-drive and it delivers 5.03V while booted. - But I haven't checked all the time, while the box is running... perhaps I would measure sometimes something else... ??? I don't care  ;D
Greets, Roger
If your voltage on the PC-PSU is too high, you should put more dummy load to this line by means of connecting a power resistor, if you run the PSU while not installed in a PC (most PSUs won't run without load anyways).
Another issue from PC PSUs is noisy voltage which might create AIN jitter, be sure to use bypass caps.
hello
all the talk about PC-PSU has triggered a "self-protect" algorythm in me  :P
Be EXTREMLY carefull with PC-PSUs since they work at high frequency high voltage and u wont feel anything until your skin starts burning !!!!!!!! DO NOT OPEN THE CASE !!!!!!!! (even if its turned off, there are 1 or 2 massive caps inside)
I speak of personal encouner, luckily it wasnt a bad 1, all the tissue recovered  :P
Yarek T
I read the same thing recently while troubleshooting a dead one. I think it went even further to say that you could actually hurt them by running with no load. People are known to run a light bulb in series while testing them.
-George
PS- I use a couple AT supplies and a Mac LC supply for 5/12v stuff here with real small loads and haven't killed anything or anybody yet.
