tokyomatik Posted October 31, 2005 Report Posted October 31, 2005 i just started to mound my first sid module and on i have a doubt about the 10 k resistor R1on the schematics found on the ucapps's site, says that is not required anymore, but i have this part in my kit and on the pcb are the last holes availableso what should i do?and if is not required anymore, should i make a bridge?let me know..
raphael Posted November 1, 2005 Report Posted November 1, 2005 and if is not required anymore, should i make a bridge?No, don't make a bridge. Just leave it out like mentioned in the schematics.
tokyomatik Posted November 15, 2005 Author Report Posted November 15, 2005 well, i did the optimized board ,using mios studio, i uploaded the mios1.8 and mbsid 1.7abut no sound comes from the sidfrom the pin 5 of the sid, i left the 10k resistor out, but now in this way i'm not connected toto pin number 5 of IC2i did something wrong?
tokyomatik Posted November 15, 2005 Author Report Posted November 15, 2005 no sound rom my sid:i did the optimized psu board 4xsid, even if at the moment i'm using only 1 sid with minimal configuration, no display or encoder,i'm sending 5vdc to the core moduleand 12vac to the sidpin 5 (res#) of the sid is not connected to the 10 k resistor and to pin o5 of the ic2mios 1.8 is already uploaded("upload process complete")and the main.hex and sertup_6581_without_cs.hex fof the mbsid 1.7a tooor i think soi used mios studioi also tryed the interconnection testbut the only message that i get is "upload process completehow can i fix this problem?
tokyomatik Posted November 15, 2005 Author Report Posted November 15, 2005 HI! i'm no able to get any sound from the sid and i don't understand if everything i did was righthow the interconnection test works?i mean, if i use mios studiowich files i have to upload?how can i understand if the mios 1.8 and the mbsid 1.7a are already uploaded in my modules?why i'm so dumb?
offe Posted November 15, 2005 Report Posted November 15, 2005 No. Just leave R1 out as raphael said./offe
raphael Posted November 15, 2005 Report Posted November 15, 2005 well, i did the optimized board ,What is the optimized board? Your own design?from the pin 5 of the sid, i left the 10k resistor out, but now in this way i'm not connected toto pin number 5 of IC2Ehmm..., the connection from IC1:Pin5 to IC2:Pin5 should still be there. The resistor just connected these pins to +5V (Pullup) and can be left out. So just connect the two pins 5 and everything should be fineRaphael
raphael Posted November 15, 2005 Report Posted November 15, 2005 pin 5 (res#) of the sid is not connected to the 10 k resistor and to pin o5 of the ic2Why a second thread?As I told you in the other thread, the connection between IC1:5 and IC2:5 must remain.Raphael
raphael Posted November 15, 2005 Report Posted November 15, 2005 Your asking:why i'm so dumb?I don`t know. ;) But posting the same problem in 3 threads isn`t clever. That's for shure.See your other threads:http://www.midibox.org/forum/index.php?topic=5640.0http://www.midibox.org/forum/index.php?topic=5710.0
moebius Posted November 15, 2005 Report Posted November 15, 2005 Thanks, raphael!You made a GOOD point there. Even beginners or people "almost there" should understand, forum is being watched by various people.Even if Your question isn't answered right away, don't start new topic because of it (and if you feel neglected and your question is not answered, just post a follow up to remind us). Once you get an answer, you can be sure that topic is being watched - and even if you have a new nearly related problem, post it there.Bye, Moebius
offe Posted November 15, 2005 Report Posted November 15, 2005 Just to be sure: Did you follow the instructions exactly for connecting the Sid module to the Core module? The reason I'm asking this is that I ignored reading up on the docs and ended up doing 1-1 connection the first time... :)
offe Posted November 15, 2005 Report Posted November 15, 2005 tokyomatik: Can you be a bit more specific? Just saying "WHAT'S WRONG" and "i don't understand if everything i did was right" doesn't give the rest of us a clue. Have you checked http://www.ucapps.de/howto_debug_midi.html? About the interconnection test, read up on main.asm, I think that's where the docs for this app is. I've not used it, but if I were you, I'd start by checking all connections, then the url above. Do you get any feedback from the core (sysex messages)?
tokyomatik Posted November 15, 2005 Author Report Posted November 15, 2005 ehm ...sorry guys, but i stayed all night long testing the connection with the tester and everything looks righti tryed to upload the mios (i'm using mios studio but i also tryed with midi ox)on the pic within 2 seconds but i still receiving back this message on the mios studio in port monitor:F0 00 00 7E 40 00 01 F7that to me, means that only the bootloader is in the picnow i would also try the Serge's SysEx Loader,but i also have another questioni did the optimized psu board x 4but only one sid in my configurationon the schemaics i saw that the 5vdc goes to j2 of the core but also to j2 of the sidi did not this connection because this jumpers are already cooncted to j10 of the coreand testing the pins i get 5vi thought that probably i was supposed to connect the 5vdc to j2(of the sid) only in the 4xsid configuration, but maybe i'm wrong...
tokyomatik Posted November 15, 2005 Author Report Posted November 15, 2005 well if i have to connect ic1:5 to ic2:5 leaving out the resistor, to me sound like a bridgeand raphael told me :No, don't make a bridge. Just leave it out like mentioned in the schematics.maybe i was not clear enough to explain but if i don't put the resistor i still remain a couple of holes on the pcband to connect them i have to make a kind of bridge if i'm not wrong...sorry but sometimes my english is so so
tokyomatik Posted November 15, 2005 Author Report Posted November 15, 2005 anyway thanx a lot guysi will let you know in a while...
tokyomatik Posted November 15, 2005 Author Report Posted November 15, 2005 last question about ic1:5 and ic2:5, are these pins, supposed to receive 5v anyway??
raphael Posted November 15, 2005 Report Posted November 15, 2005 last question about ic1:5 and ic2:5, are these pins, supposed to receive 5v anyway??No. Once again: There is no connection to 5V. There is only a connection between theese two pins.
tokyomatik Posted November 15, 2005 Author Report Posted November 15, 2005 OK...thanks a lot again,i will test everything again...
raphael Posted November 15, 2005 Report Posted November 15, 2005 but i also have another questioni did the optimized psu board x 4but only one sid in my configurationon the schemaics i saw that the 5vdc goes to j2 of the core but also to j2 of the sidi did not this connection because this jumpers are already cooncted to j10 of the coreand testing the pins i get 5vi thought that probably i was supposed to connect the 5vdc to j2(of the sid) only in the 4xsid configuration, but maybe i'm wrong...Thats OK. One 5V connection is enough.
offe Posted November 15, 2005 Report Posted November 15, 2005 last question about ic1:5 and ic2:5, are these pins, supposed to receive 5v anyway??Wait a second... As far as I can tell from the SID module schematic, IC1:PIN5 connects to IC2:PIN2. In that case, you SHOULD leave R1 out. Otherwise you have to clarify, 'cus I'm not following you.../offe
tokyomatik Posted November 15, 2005 Author Report Posted November 15, 2005 there is a way to test to verify if the sid is working?i found a lot of troubleshootings for the core and midiand they are fine, but nothing about the sid moduleanyway, even if the sid is not working, i should be able to upload the mios to the core(?)right now i also have a doubt about the j2(sid) and j10(core) connectionsi'm supposed to use all the pins of the cable?i did like this:j2:so - j10:soj2: md - j10:mdj2:rc - j10:rcj2:mu - j10:muj2:sc - j10:scand so on...i was supposed to leave some pins out?
offe Posted November 15, 2005 Report Posted November 15, 2005 there is a way to test to verify if the sid is working?i found a lot of troubleshootings for the core and midiand they are fine, but nothing about the sid moduleIf the is module is working, you should get som sound out of it... ;) anyway, even if the sid is not working, i should be able to upload the mios to the core(?)YESright now i also have a doubt about the j2(sid) and j10(core) connectionsi'm supposed to use all the pins of the cable?i did like this:j2:so - j10:soj2: md - j10:mdj2:rc - j10:rcj2:mu - j10:muj2:sc - j10:scand so on...i was supposed to leave some pins out?That was exactly was I was asking you earlier! Did you check http://www.ucapps.de/mbhp/mbhp_4xsid_c64_psu_optimized.pdf for the correct connections between the SID module and the Core module? Connections should be like:j2:so - j10:soj2:sc - j10:mdj2:rc - j10:rcj2:mu - j10:mu/offe
raphael Posted November 15, 2005 Report Posted November 15, 2005 EDIT: offe was faster ;DBut anyway:anyway, even if the sid is not working, i should be able to upload the mios to the core(?)Yes, this should work anyway.right now i also have a doubt about the j2(sid) and j10(core) connectionsi'm supposed to use all the pins of the cable?i did like this:j2:so - j10:soj2: md - j10:mdj2:rc - j10:rcj2:mu - j10:muj2:sc - j10:scand so on...No, it`s no one-to-one wiring!Please take a closer look: http://www.ucapps.de/mbhp/mbhp_4xsid_c64_psu_optimized.pdfAfter MIOS is loaded, try the interconnection test (follow instructions in main.asm) BEFORE plugging in the SID.
tokyomatik Posted November 15, 2005 Author Report Posted November 15, 2005 so i'm a bit fucked up...and i also fucked up the j2/j10 connections, ok , i'm fixing it...could be that, the reason why i'm not able to upload the mios?
offe Posted November 15, 2005 Report Posted November 15, 2005 so i'm a bit fucked up...and i also fucked up the j2/j10 connections, ok , i'm fixing it...could be that, the reason why i'm not able to upload the mios?Probably no. Actually, this is no rocket science, just read the documentation and use the search function in this forum. If you are using MIOS studio you should get something like "upload completed" or something like that. You should them be able to verify by sending and recieving sysex messages in the midi monitors in MIOS studio./offe
