I´m in the process of (finally) updating my "Der Brat 1000" to 1.7303b10 and want to put more memory into the box. Now I have the following problems:
1. when I put a 24LC512 EEPROM in the socket, there´s still only one bank. I was under the impression that MIOS can make use of double-size EEPROMS?
2. I have two 24LC256 chips that were formatted on the MB FM. When I put one into the MBSID, the box starts formatting it until patch 13 is reached, then hangs, resets and starts the formatting again. Is there a way to get these chips working with the MBSID again?
Thanks,
Seppoman
From the bankstick site (bottom):
Note that the 24LC256 can also be replaced by a 24LC512. Although no application supports this 64k EEPROM yet, MIOS is able to access the full 16-bit address space. By stacking 8 * 24LC512, up to 512k are available.
(This is not the full truth as MBSEQ supports one 24LC512)
2. qestion: I have no MBFM so perhaps anyone else knows...
Raphael
For a 24LC512 you only need to do some small changes in mbsid_bank.inc - search for "SID_BANK_SetBankStickAddress, and replace this function by
movff EEADR, MIOS_PARAMETER1 ; copy address to low-byte
movff SID_PATCH, MIOS_PARAMETER2 ; copy patch to high-byte
bcf MIOS_PARAMETER2, 7
btfsc SID_BANK, 0
bsf MIOS_PARAMETER2, 7
clrc
rrf SID_BANK, W
andlw 0x07
iorlw 0x80 ; (disable verify for faster write accesses)
goto MIOS_BANKSTICK_CtrlSet
[/code]
(I never tried this out...)
To the MBFM BankStick effect: this is really strange, I don't know how this can happen.
A quick & dirty solution: insert a "return" below the SID_BANK_FormatStick function to prevent this action. Thereafter upload a complete sound bank, thereafter remove the return, so that the BankStick will be formated again, but this time with proper background data
  • 2 weeks later...
Hi Thorsten,
thanks for your response :) Today I found the time to try this out:
Inserting your code doesn´t help with the 512s yet. The box doesn´t recognize or format the second bank and I can´t save to it. Your other trick did work, all EEPROMs good as new now :)
Kind regards,
Seppoman
Hi Seppoman,
Somewhere below "SID_BANK_SetBankStickAddress" is a routine which checks if a BankStick is connected or not - this routine also needs to be adapted (currently I don't have the sources right here...)
