Jidis Posted November 25, 2005 Posted November 25, 2005 Are there LCD's where the core's luminance control doesn't have a very noticeable effect on anything? I'm running a backlit 2x16 here and can't really tell the difference.-Thanks!
SMIDIRIN Posted November 26, 2005 Posted November 26, 2005 check on the datasheet that it is 10k thats needed ?yeah very little change on one of mine i remember. i used a jumper wire instead (which maybe should've been a low Ohm resistor?)my contrast pot only really works at the end of its range..no problem though.S
