adamwg Posted December 3, 2005 Posted December 3, 2005 does any one know if ableton sends out midi messages to turn leds on/off? i can't find a way of assigning any output within ableton only inputs via the midi map mode.
Screaming_Rabbit Posted December 3, 2005 Posted December 3, 2005 Did you check, what happens on the host Midi-Out (with MidiOX), when you activate a function? Normally you don't have to map those functions but they're fix assigned.Greets, Roger
SounDuke Posted December 3, 2005 Posted December 3, 2005 This feature is on only with the mackie protocol in Live 5 by my experience, so if you're not using MBLC probably you need to configure live as mackie control and map the messages sent by Live
