number of buttions for menu navigation
hello midi-boxers
i have small question
planning to build midibox mixer  and i wonder how many buttions in minimum requered for the menu navigation???
10x in advance
the minimum is 4 buttons, otherwise you could replace 2 buttons with a single encoder to provide datawheel (more comfortable in my opinion) but you can add "shortcut" special buttons to provide quicker access to pages. But remember: not more than 128 digital inputs x core!
10x alot
128 is far more than i need :)
problem was that i saw at most midibox in galery about 8 buttions arround the screen
and i already sent my panel desing to CNC cutng and set only 4 push buttions and 1 up/down switch
but now im calm :)
10x again
  • 3 weeks later...
to clarify: would that be just 2 buttons and an encoder?
thanks!
damn, I wish this system had 128+4 dins.  :'(
Uhm, newb q here, but if I did a two-core system would I be able to program both units from one display+buttons? Specifically a Midibox 64e and a MIDIO128. I'm a bit hesitant to do a system where part of it can only be programmed from a computer.
