Hi everybody, I have a keyboard and I want to drive some features of it with midibox64, but I have 2 questions  ??? ???:
- Can I sent for example this message using a pot:
  BnH 62H 20H 63H 01H 06H mmH 26H
With n the MIDI channel number and mm between 00 and 7F?
or only 1 status byte and 2 data bytes?
The other question is: Can I sent specific range of values like these?:
  00H 40H <---> 7FH 00H
        00H  <---> 0FH
Thank.
yes, both is possible without problems. In order to send a sequence of bytes, you need to use "meta events", a description with some examples can be found in mb64_meta.inc
All pots provide "min" and "max" values, you can use them to reduce the value range - see midibox64.ini, which is part of the "mk_syx" package.
Thanks, but the range of values I need are very specific and special :o  ???, is to change de fine tuning of my keyboard:
40 00 40 20 40 40 40 60
40 01 40 21 40 41 40 61
00 02 00 22 00 42 00 62
40 02 40 22 40 42 40 62
40 03 40 23 40 43 40 63
00 04 00 24 00 44 00 64
40 04 40 24 40 44 40 64
00 05 00 25 00 45 00 65
00 06 00 26 00 46 00 66
40 06 40 26 40 46 40 66
00 07 00 27 00 47 00 67
40 07 40 27 40 47 40 67
40 08 40 28 40 48 40 68
00 09 00 29 00 49 00 69
40 09 40 29 40 49 40 69
40 0A 40 2A 40 4A 40 6A
00 0B 00 2B 00 4B 00 6B
40 0B 40 2B 40 4B 40 6B
00 0C 00 2C 00 4C 00 6C
00 0D 00 2D 00 4D 00 6D
40 0D 40 2D 40 4D 40 6D
00 0E 00 2E 00 4E 00 6E
00 0F 00 2F 00 4F 00 6F
40 0F 40 2F 40 4F 40 6F
00 10 00 30 00 50 00 70
40 10 40 30 40 50 40 70
40 11 40 31 40 51 40 71
00 12 00 32 00 52 00 72
40 12 40 32 40 52 40 72
40 13 40 33 40 53 40 73
00 14 00 34 00 54 00 74
40 14 40 34 40 54 40 74
00 15 00 35 00 55 00 75
00 16 00 36 00 56 00 76
40 16 40 36 40 56 40 76
00 17 00 37 00 57 00 77
40 17 40 37 40 57 40 77
40 18 40 38 40 58 40 78
00 19 00 39 00 59 00 79
40 19 40 39 40 59 40 79
40 1A 40 3A 40 5A 40 7A
00 1B 00 3B 00 5B 00 7B
40 1B 40 3B 40 5B 40 7B
00 1C 00 3C 00 5C 00 7C
00 1D 00 3D 00 5D 00 7D
40 1D 40 3D 40 5D 40 7D
00 1E 00 3E 00 5E 00 7E
00 1F 00 3F 00 5F 40 7E
40 1F 40 3F 40 5F 00 7F
00 20 00 40 00 60
these are interpreted by the keyboard as -99 to 99
Thanks for your attention.
