Is it okay to tie all the DIN ground connections together?  Is it okay to do the same with the DOUTs?  Is it okay to connect DIN grounds to DOUT grounds?
  • 2 months later...
Why [tha hell] do we need all that ground pins & wires?!
We can just ground the ground from the core to the casing and do the same with dout/din/ain/lcd/etc...
no one keeps you from doing that, but if you ever got a problem inside a small box, you'd know that it's sometimes better to have some unpluggable and removeable single items in it.
next point is, that not everyone is using a metal case...
