SmashTV SID Module - Leave C7 empty?
th0mas
First of all, thanks everyone for an awesome project, and thanks SmashTV for an awesome service - I love the boards!!!
Onto my question:
I've noticed that:
-I only have 1 capacitor marked 102
- the parts list on SmashTV's website does not include anything identified for C7
Am I to assume the one 102 capacitor is for C3 and leave C7 empty? (despite there being a C7 capacitor in the board livemap on Smash's website)
Also.. how bad is it when a ceramic cap starts to well, seemingly give off a translucent plastic?  Is it fried?  It happened a bit on my core module, and the module appears to work fine (voltages test fine, etc).
Cheers,
Tom
Onto my question:
I've noticed that:
Whoops - seemingly some documentation/ kit error there.. itwill be fixed in the near future :D
Yup, do this - C7 is part of the audio input and if you don't use it, leaving the cap out isn't going to give you problems.
Hmm.. this is something I should see - I'm more convinced it's mechanical stress / heat related effect. Ceramics are hard to destroy and even with some damage in the outer coating it should work and continue to work fine.
Moebius
p.s. Anyone seen "manually tuned" ceramics in RF circuits? Sawed from the middle.. :D
Does it look like caramel or honey?? I'm thinking it could be a bit of stray flux from the solder.
Ceramic caps are virtually indestructable at the temps they're soldered since they're formed under high pressure/heat, so I think you should be ok.
Heh - Good point!! ;)
Moebius
nope, more like white plastic-y.
I'm just about done my power supply, so I'll let ya'll know if I'm getting the right voltages or not.  Thanks for the reassuring words regarding the durability of the caps, makes me feel a bit safer :)
Cheers,
Tom
I've had a few old ceramic caps (brownish colour) lying around, and used them for bypass caps on a DIN module. When heated for the first time all of the disks became a litte wet all by themselves, and on the newspaper I had lying underneath the boards actually was a little wet spot. I don't believe it's broken, I think more of a protective coat or something that got heated away...
Cheers,  Alex.
Well, it appears not to be a problem, because MY SID WORKS!@#!@#! :)
Thanks a lot for the replies.
Now for something to make your blood run cold:
Yesterday, when I was soldering my SID module, I took my SID chip out of it's case to check the version and ensure that it is a 6581.  Being in an uberfocus, I then placed it on the desk and continued working on the SID module until it was done (including posting the messages from above).
This morning, I find my SID chip face down under the chair next to my desk, pin's bent all over the place.  I think I rolled over it with my chair. :o
Yet this is the SID that is powering my synth, so all's well that ends well I suppose :)
:o Good thing you don't weight a bit more eh ;)
I remember the days before PC's had ZIF CPU sockets, we used to see  buggered pins up on so many x86/x87's... Funny, not once did any one of them ever fail to work once the pins were straightened.... Provided none of them snapped off of course :)
Beef stew, however, is absolutely guaranteed to bugger the chip up permanently. The only things that work better are Coca-Cola, or a solid EMP. So, I would like to issue the following warning to all MIDIBoxers:
[glow=red,2,300]Do not eat stews or curries while drinking coca cola and playing with your thermonuclear weapons, while handling your core modules.[/glow]
..oh, and keep a piece of antistatic foam around to sit your chips in  ;D
Cheers,  Alex.
Could that just be condensation forming on the ceramic coating, due to the cap being hotter than the air around it?
Guys... What's the cap worth? What's your health worth?
You have no idea what the stuff is, let alone what it could do to you.
Just throw it away and get a new one. FFS, if it's that big a deal, I will pay for the new cap myself, just to make sure you stay healthy.
