Nu-Audio-Science Posted March 30, 2006 Report Share Posted March 30, 2006 EDIT*This is a revised post with a better layoutOK i have updated my layout to this :)This would be using the MB64e with the experimental support for AINsI think my numbers are right but i could be wrongMB64e Editing1 button1 dial (encoder)1 LCDMixer16 volume faders16 pan pots16 send 1 pots16 send 2 pots16 solo buttons16 mute buttons2 up/down buttonsTransport4 Stop/Start/Record/Rewind to start buttons1 Jog dial (encoder)12 Trigger buttonsVST Editor 112 encoders3 buttons2 up/ down buttonsVST Editor 212 encoders3 buttons2 up/ down buttonsVST FX Editor6 encoders1 button2 up/down buttonsAIN16 faders48 pots = 64 AINsDIN64 buttons32 encoders = 128 DINsPlanned modules4xAINX44xDINX41XCore1XLTC1XUSB (Not sure this is supported yet ?)Haven't decided about the DOUTX4s yet because i haven't decided on an LED setup yet :) Quote Link to comment Share on other sites More sharing options...
stryd_one Posted March 30, 2006 Report Share Posted March 30, 2006 You need to read some more around here :) Not trying to be rude at all, just want you to be well-informed. All the answers you need are around... but anyway:Yes the MB could drive bar meters. Check out the LC, I'm fairly sure that does.The 64 LEDs, you could use for whatever you want. One example of using so many LED's would be 4x 16-steps on a sequencer... But it's up to your imagination. If you can't think of anything but LEDRings, you're obviously not very imaginative! ;) (Crikey I think I was up around the 140's in one of my first designs)There will be a fair amount of customization required, as you have a setup that does not match any existing applications (for eg you have mixed encoders and pots) although you will certainly be able to use something like the MB64 as a starting point, you won't have to build the application from the ground up or anything. It sounds to me like a LC clone and a MB64E combined would be perfect for you. Perhaps you could start by building a stock MB64E and use that as a tutorial?You can edit the MB64 via MIDI if you want, so you don't need buttons at all, but you could also use any other button on the CS. Buttons always go to a DIN*. I only count 36 DIN's there, you wouldn't need to redesign anyway...*DIN = Digital INput. Buttons are ON/OFF, so they are binary. This means they need a digital input. You could use an analog in, and it would be seen like turning a knob from 0 to full, (kinda, this is simplified) but this is not a good way to do it.Hope this helps! Quote Link to comment Share on other sites More sharing options...
Nu-Audio-Science Posted March 30, 2006 Author Report Share Posted March 30, 2006 Thats funny i count 64 DINs including encoders and buttons :-\ Quote Link to comment Share on other sites More sharing options...
drin Posted March 30, 2006 Report Share Posted March 30, 2006 Thats funny i count 64 DINs including encoders and buttons :-\Nope. Each encoder requires two DIN pins, making an encoder two DINs. If you read the site under the DIN link in the left hand menu you'll find http://www.ucapps.de/mbhp/mbhp_dinx4_16enc.pdf, which shows the encoder connections to a DIN board.Given your numbers:Component DIN12 solo buttons 1212 mute buttons 122 up/down buttons 2 4 transport buttons 410 Trigger buttons 101 Jog dial encoder 216 encoders 327 buttons 7Total 81That's if your jog dial encoder is NOT a push switch when depressed. If it is, add one more DIN.I'd second what stryd_one said, and you'll hear it from almost everyone here - read more. Read a LOT more. When you've done that, read some more. When you think you know how everything works read a bit more. :)-drin Quote Link to comment Share on other sites More sharing options...
stryd_one Posted March 30, 2006 Report Share Posted March 30, 2006 I only count 36 DIN's thereWhat the hell was I counting then? :o This is what happens when you try to count while listening to annoying crappy on-hold music. Someone really needs to get that guy a MBFM or something. Quote Link to comment Share on other sites More sharing options...
Nu-Audio-Science Posted March 30, 2006 Author Report Share Posted March 30, 2006 OK cheers drinI have been here for years and have read pretty much everything except that doc you just showed, Thats why i didn't know encoders where 2 DINs each.I must have got confused because i read Steve Thomas TB3030 site and he said you could have 96 rotaries, For some reason i assumed that was with another 32 switches on top, I went back and reread it and it just says 96 rotaries DOH.For the record i already built a MBSid but without interface so didn't know anything about setting up the controls, I thought a MB64 would be better to build than jumping straight into my quad SID with full CS :)So am i right in thinking pots encoders and switchs can all be used at the same time, As long as the numbers are right for the DINs and AINs available ?Also could someone be a little clearer about how many buttons and encoders i need to edit he MB64 via it's LCD, Again i'm probably being blind and missing a link telling you, I know how many you need for the SID CS but i'm struggling to find the answer for MB64.I'm sorry for asking these questions on the forum by the way, I thought that was what it was for, Sorry about that :-[Is there an IRC channel or something where i can ask questions without annoying people ? Quote Link to comment Share on other sites More sharing options...
moebius Posted March 30, 2006 Report Share Posted March 30, 2006 I'm sorry for asking these questions on the forum by the way, I thought that was what it was for, Sorry about that :-[Is there an IRC channel or something where i can ask questions without annoying people ?IRC: midibox@EFnet,http://www.midibox.org/forum/index.php?topic=5868.msg36138#msg36138The Forum IS just the place to ask questions.. but not before You have read the www.uCApps.de and the http://Wiki.midibox.org ;) And we at the chan really enjoy our stay (?!) and like to keep it that way.. soo, people are welcome to /join, but please don't mess our precious idling and random babbling with too much midibox context ;DMoebius Quote Link to comment Share on other sites More sharing options...
Nu-Audio-Science Posted March 30, 2006 Author Report Share Posted March 30, 2006 OK Mobeius cleared everything up on IRC, I had read something wrong, Once he pointed it out i had no questions left really DOHBasically i need to build an MB64e and edit the main.asm in the source allowing me to either use some pots via J5 or use AINs for 64 pots which are mapped to the upper MIDI parameters (65-127)This still leaves 128 DINs for switchs and encoders and also 128 DOUTs i believe for LEDs.I still cant honestly see a point to all those LEDs though unless you have rings, Then again if you can load the MB Seq software in it may be useful i suppose (I think this is possible, I think i read it at Ucapps but it may be the other way round LOL)I need to replan my design and if anybody else was blind enough not to see this, You will want 8 buttons to navigate the menus and special functions ;) (Leaving 120 DINs) Quote Link to comment Share on other sites More sharing options...
Nu-Audio-Science Posted March 30, 2006 Author Report Share Posted March 30, 2006 OK i have updated my layout to this :)This would be using the MB64e with the experimental support for AINsI think my numbers are right but i could be wrongMB64e Editing1 button1 dial (encoder)1 LCDMixer16 volume faders16 pan pots16 send 1 pots16 send 2 pots16 solo buttons16 mute buttons2 up/down buttonsTransport4 Stop/Start/Record/Rewind to start buttons1 Jog dial (encoder)12 Trigger buttonsVST Editor 112 encoders3 buttons2 up/ down buttonsVST Editor 212 encoders3 buttons2 up/ down buttonsVST FX Editor6 encoders1 buttons2 up/down buttonsAIN16 faders48 pots = 64 AINsDIN64 buttons32 encoders = 128 DINsPlanned modules4xAINX44xDINX41XCore1XLTC1XUSB (Not sure this is supported yet ?)Haven't decided about the DOUTX4s yet because i haven't decided on an LED setup yet :)I'm not entirely sure MB64e supports that layout as standard but hopefully it won't need too much coding ;)The main thing i'm worried about is the up/down buttons for the individual sections, Will i be able to add in up/down buttons so that i can go through encoders or pot banks to extend the ammount of available controls, Or is this done via the LCD and interface controls ?Also can it be done seperately so that i could for instance go up and down extra mixer channels or up and down through extra encoder banks ?I think i read it involves using banks sticks but i plan to fully load it anyway so thats no probs.Anyway i thought i would ask while i was updating the thread, I'm gonna go and look in the forum for the answer now anyway ;) Quote Link to comment Share on other sites More sharing options...
Nu-Audio-Science Posted March 30, 2006 Author Report Share Posted March 30, 2006 Oh PS ;DMobeius pointed out something that made everything easier, I was only reading the main info at the Ucapps site, WRONGIf your a newb then read the chagelog and have a look at the source code too, Nearly all of my questions have been answered there since Mobeius pointed it out (Cheers dude)EDIT* Looking at the source again i think it may be harder than i thought to have banks of mixer faders and banks of encoders, There is a bank or patch mode and i think the patch mode would be most suited but i'm not entirely sure.I have been reading about meta events at Ucapps and it may even be group switching that i want ?Hopefully it is just group switching and it can be done and have LEDs to show which group is being edited. Quote Link to comment Share on other sites More sharing options...
moebius Posted April 3, 2006 Report Share Posted April 3, 2006 Hi,This shouldn't be that hard at all. You'll want standard bank mode as there you can define different controllers/events per bank. You can also use leds to show the status and use for example 2 buttons to increment/decrement banks.See about the possibilities by downloading vMIDIbox64E from http://miostools.midibox.org/ which can be used to create a configuration file for the box.Moebius Quote Link to comment Share on other sites More sharing options...
Nu-Audio-Science Posted April 3, 2006 Author Report Share Posted April 3, 2006 Cheers MobeiusI'm actually buzzin right now, I got the Soldering kit out the cupboard because i just bought a new Antex 18w to replace the rubbish i was using and i found an unopened core kit and DIN kit from Smash :)How cool is that i forgot all about em, I bought em towards the build of my quad SID and forgot all about em once i had done my basic SID.The only thing i need to check is if the info that is on the PIC is the right info for the MB64e, I think i read that it was the same and it was just so you could load the particular app but i need to recheck (Terrible memory)Only other problem is i only have two encoders here and one of them i took apart and messed with to get rid of the indents, It works OK but i'm not sure i trust it :)Oh i think i might need to order some caps too because its an R3 core and i dont think it has the bypass's.I'm gonna check that link now cheers dude :) Quote Link to comment Share on other sites More sharing options...
Nu-Audio-Science Posted April 3, 2006 Author Report Share Posted April 3, 2006 Yep that is one cool as hell app, I think that pretty much answers all my questions on the layout, It also poses a few questions too though hahahahaI'm starting to think now that i have found this extra old core kit i might seperate the VST editor into it's own case and do the mix controller seperate.This would be easy to carry around and would also let me start building the VST editor without having to wait for XT2 (My host updated in a few weeks) to see if it has any new MIDI control stuff implemented.It also means that my mix controller can have extra faders. Quote Link to comment Share on other sites More sharing options...
Nu-Audio-Science Posted April 4, 2006 Author Report Share Posted April 4, 2006 Hey my luck is clean at the minute :)I just found a DIN kit in my old modelling tool box ;)I soldered the old core i found last night and all the voltages where fine, I'm gonna do the DIN tonite ;)I still don't know what i'm gonna do with this core yet but it seems now i have found this DIN kit too i may aswell just try and get hold of some cheap encoders and make a small MB64e ;)I may have a line on some cheap backlit hd44780s for people in the UK too, I'll get back about that though if he still has bulk ;)I'm just waiting for mine to arrive so i can test to see if there OK.Wont be anything to do with me though you can just go direct, I got one for £5 brand new including P+P. Quote Link to comment Share on other sites More sharing options...
Therezin Posted April 5, 2006 Report Share Posted April 5, 2006 A fiver? got any more info on these displays? Size, backlight etc? Quote Link to comment Share on other sites More sharing options...
Nu-Audio-Science Posted April 5, 2006 Author Report Share Posted April 5, 2006 2x20 backlitMade by Hitachi i thinkI will have more info in about a week, But i think he only has a few leftHowever there is a japanese source that does nice ones for about £9 or something Quote Link to comment Share on other sites More sharing options...
