vix Posted April 24, 2006 Report Share Posted April 24, 2006 Hii'v finished a Midibox CV box (with 1 AOUT_LC) and i can't access to menus : the 4 buttons don't seem to respond as wished, i can exit from idle mode, but then i can't modify parameters and navigate... i changed the Din reg, checked everything..i think i have a problem with my PIC (because i made a voltage mistake once, and i think a part of it is out of order)is it possible that the main part of my Pic works but not all the Pic ? (digital inputs can be destroyed ? ) i'v ordered a new pic, but i can't stay without trying... ;D Quote Link to comment Share on other sites More sharing options...
illogik Posted April 24, 2006 Report Share Posted April 24, 2006 is it possible that the main part of my Pic works but not all the Pic ? (digital inputs can be destroyed ? ) i'v ordered a new pic, but i can't stay without trying... Grinpossible, yes, i think with ic's in general it's more common to have a "half working" chip then a completely non working one, especially with somthing like a PIC which has a lot of sections.BUT!!i have found PIC's to be very vandal proof if you know what i mean, i have had shorts and other mistakes but i never destroyed a PICand since you say that exit button is working (you can exit and again enter idle mode?) i think you have a problem on your din board; (faulty 74HC165, shorts/opens, wireing, bad buttons) it is a serial connection so if exit works, i guess your fine at the PIC sidecheers, marcel Quote Link to comment Share on other sites More sharing options...
TK. Posted April 24, 2006 Report Share Posted April 24, 2006 I also think that this is a problem with the DIN module - just use MIDIO128 and srio_interconnection_test for debuggingBest Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
