SounDuke Posted May 29, 2006 Posted May 29, 2006 Hi everyone, I was wondering if it is possible to change the channel# of midi events passing by the midibox. In other words, I own a keyboard which is not capable of channel splits, it is programmed to send note on/off on the whole range of the keyboard on only one of the 16 channels. Is it possible to change the channel byte of note on/off event sent out by the keyboard by sending that midi stream into a midibox with the applications currently available? That way I could achieve infinite channel splits on keyboard which are not equipped with this feature using the MB midi out. Thanks for the help
stryd_one Posted May 29, 2006 Posted May 29, 2006 I'm sure that's do-able....http://www.ucapps.de/midifilter.html and the examples at http://www.ucapps.de/mios_c.html would be examples....
Davo Posted May 30, 2006 Posted May 30, 2006 This sounds like something that could easily be included in the midi router project... which I'm very interested in. Hey, TK, any chance of a formal writeup on that soon?
audiocommander Posted May 30, 2006 Posted May 30, 2006 There is already some information and the PIC16 Firmware available!
TK. Posted June 3, 2006 Posted June 3, 2006 Yes, and it works fine since more than 8 weeks under "real world conditions" :)-> http://www.ucapps.de/midi_router.htmlBest Regards, Thorsten.
Davo Posted June 3, 2006 Posted June 3, 2006 I'm fantasizing about a midi router with 32 ports (two for each of 16 channels). I'm pretty sure those will all fit on the back of a 1U chassis. What front panel controls would one want for a midi router?
TK. Posted June 3, 2006 Posted June 3, 2006 I'm not sure if my finalized project will get a 2x40 LCD, a rotary encoder, 6 buttons and a lot of Rx/Tx LEDs, or just only 8 buttons, 8 LEDs and 5 Rx, 5 Tx LEDsMost important feature for myself is, that I can quickly switch between different routings, and that I can change parameters of the routing (e.g. MIDI channel of a splitted keyboard zone or transpose value).One thing on which this depends is the 1U case I already have, but for which I haven't found a solution yet to mount a LCD properly (mechanical problem).Another point is, that I haven't found the time yet to continue with the USB routing, this will propably change the concept at all (e.g. more Rx/Tx LEDs, or just virtual nodes?)Best Regards, Thorsten.,
audiocommander Posted June 3, 2006 Posted June 3, 2006 If I will ever find the time to build a router, I'd customize it in need for a patch manager. The router-project is ideal to observe incoming PRG-CH for each MIDI Line. By storing these values as a "super-patch", it would be possible to send out all stored PRG-CH with one touch :DBest regards, Michael
