dj_statikfire Posted July 24, 2006 Posted July 24, 2006 Has anyone experienced this message when communicating with the CORE?Taken from the MIOS HEX FILE UPLOADER-----------------------------------------Received error code 0B: MIDI IN Overrun ErrorSending block 00005500-000055FFError: Received unexpected Upload RequestSending block 00005500-000055FFReceived error code 0B: MIDI IN Overrun ErrorAborting after 3 errorsSince my 1st CORE programmed normally, this was quite unexpected. I'll poke around the board a little more and see if there's more information.THX,JD
TK. Posted July 24, 2006 Posted July 24, 2006 Try to upload with the 1st level bootloader (within 2 seconds after power-on) if this happensBest Regards, Thorsten.
dj_statikfire Posted July 25, 2006 Author Posted July 25, 2006 TK, Attempted to program within 2 seconds of power-on. Several attempts, consistant results as noted above.Swapped my 2nd CORE_R4 processor to my #1 CORE_R4 (known good), and had the exact same issue.Also noted more current draw from the voltage regulator... a little warmer than usual.Looks like a partially dead processor.THX,JD
moogah Posted August 29, 2006 Posted August 29, 2006 What were you trying to upload? Is it possible you were trying to upload an application before uploading MIOS? Which version of MIOS did you upload? Like TK says it does look like you were sending an upload without the PIC requesting it. Have you tried using MIOS Studio with "Wait for upload request" checked off? You have to press start before you power on the core, but doing this has always worked for me. I've never been able to kill a PIC. And I've tried ;D
