Hello puddingbrumsel,
This would be a great addition to the seqencer.
It could also be done in the form of a step mode.
Then you would have:
Mute, skip, first step, last step, accent, glide etc.... as available step modes.
This way you wouldn't need the extra encoders.
Regards,
Pascal
In MBSEQ V3 you can set the loop start point with a GP encoder, the track end with a second GP encoder... in addition, you can rotate the pattern within the loop in the shift menu. Skip Steps are possible as well, and not to forget: the progression parameters. The possibilities are already endless :)
Here some snapshots:
