alogic Posted August 23, 2006 Posted August 23, 2006 me he estado fijando en diseños de otros y ponen un controlador para los platos de tracktor no se si solo es un encoder que en una direccion pulsa el boton de acelerar el tema y en la otra el de frenarlo o si realmente se pudiese poner en modo absoluto (por llamarlo de alguna forma)y que resalmente se pueda escratchear con el encoderpor que no me importaria conectarle un par de encoders a los platos , con una ruedecita almoadillada que roce con el disco y marque la velod¡cidad, alguien lo ha usado saludos y todosamidi ;D
dj3nk Posted November 8, 2006 Posted November 8, 2006 sry, i dont understand spanish.do you speak about a abbility to build a controller like the finalscratch?if yes, whas your idea behind it?
dj3nk Posted November 8, 2006 Posted November 8, 2006 very intresting .... http://home.germany.net/101-81660/LTC.htmits about the timecode used for video. It's just a usual audio-track with highs and lows.sorry, but its german
dj3nk Posted November 8, 2006 Posted November 8, 2006 After some deeper reading into it I don't think it's very heavy to realize for us (and the great MB-community).There would be 2 informations our vinyl would need: - The actual tempo - The actual positionYou see timecode is an audiolike signal, either a high frequency (1) or a low frequency (0). Lets say high is at 2kHz, low at 1kHz. At reading I recognized a low is the half frequency of a high. So the actual frequency doesn't matter, because you know the lows are the half freq.This way it wouldnt be a problem to read that "binary" code in this audio signal which tells us the actual position of the track.The actual tempo of the vinyl could be found out, depending what frequencies the highs and lows are. A slower played vinyl causes lower frequencies than a faster played.Right way, ain't it ??
dj3nk Posted November 8, 2006 Posted November 8, 2006 sorry, my browser fucked up and i cant edit my postings, so i have to write a new :(And why just synchronizing traktor with it?With a midi timecode it would be possible to sync every sequencer !!!!!Think about mixing your songs live from sequencer for testing it in the mix. ^^ wooohahaha!!!!!!! THAT WOULD BE MORE AWESOME THAN FINALSCRATCH ALREADY IS !!!!!!!!
alogic Posted January 22, 2007 Author Posted January 22, 2007 mare mia si aqui ahi miga pa rato yo hablaba de 1 ó 0 y que marque de la velocidad entre entre uno y otro , en sentido del reloj el encoder marca 1 128 veces por vuelta en la contraria 0 128 veces y un contador que marca la velocidad entre pulso y pulso a 1 gira en un sentido y a cero en el otro . asi se le dan estos datos al pic de un midibox 64 este todavia nose si puede actuar como maestro del ordenador con el tiempo midi o si hay que usar un secuenciador y manejar a este gracias mil todosamidi
alogic Posted January 22, 2007 Author Posted January 22, 2007 siento no poder escribir bien ingles y menos aleman. utilizo un traductor de google y puedo ir leyendo poco apoco, perdona antes no lo pase por el traductor I feel not to be able to write well English and less German. I use a translator of google and I can be reading little I diminish, pardons before does not pass it through the translator mother mine if bread for short while I spoke there here of 1 or 0 and that she marks of the speed between between both, in sense of the clock encoder mark 1-128 times by return in opposite 0-128 times and an accountant who marks to the speed between pulse and pulse 1 in a sense and zero in the other. thus these 64 occur him data to pic of midibox this still nose if midi can act with time like teacher of the computer or if there is to use a secuenciador and to handle to this thousands thanks todosamidi
alogic Posted January 22, 2007 Author Posted January 22, 2007 I was talking about 1 or 0 and making it show the speed between them. In the clock´s sense the encoder "pulses" 1 128 times per round, , in the other direction , it pulses 0 128 times per round; and a counter showing the speed between the pulses with 1 in one direction and 0 in the other one.Tha t ´s the way of giving this data to the midibox 64 pic.
alogic Posted March 3, 2007 Author Posted March 3, 2007 alguien puede decirme que envia un secuenciador midi para controlar el bpm de otro aparato. En si conozco que el midi envia buses de 8 bits , asi para mandar el cambio de un pote envia primero un bus de 4 bits para indicar el canal midi en que va ese pote 1-16 ,otro de 4 para indicar el tipo de dato que es, pote,tecla,pulsador,etd, otro de 8 con el numero de potenciometro 0-127 y otros 8 con el valor del potenciometro 0-127 , o mas o menos eso pone en un libro de por aqui pero no encuentro como funciona el bpm , alguna idea de donde encontrar esa info Regracias
alogic Posted March 3, 2007 Author Posted March 3, 2007 aqui hice con agujeritos en un disco, un codigo binario para que el dac0801 variase la tension con multiplos de 8 que no utilizan los ultimos 3 bits pero por muy justos que ponga los taladritos siempre hay un punto en el que todos los receptores d infrarrojo se quedan a cero, y da errores . esto es para controlar una de los potes con un giradiscos convertidor dig-analogic dac0801.JPG
alogic Posted March 3, 2007 Author Posted March 3, 2007 asà pense en un 9º receptor de infrarrojos que le dijese a la core cuando debia leer las entradas y con 8 receptores podemos determiar 256 posiciones en una vuelta, solo que yo no tengo ni idea de como progarmar una core para que en funcion de loque lea ,de un dato u otro a la salida midiesto tambien se puede hacer con un encoder digital de 8 bits , pero los que pueden aguantar mucho tiempo son muy caros. y ande conecto ese otro receptor el que indica cuando se puede leer el dato podria hacerlo a cualquiera que no este ocupada ,supongo,pues sera en el programa donde haya que indicarlo,que se ha conectado . el iniciarse a programar algo asà habria que empezar por pensar en alguna interrupcion de reset que volviera al punto de inicio y otra que empezase a contar desde el punto donde se le programa me imagino fijandome en los secuenciadores que tengo , todos ellos pueden secuenciar 256 frases de 256 divisiones cada una .el codigo de bpm deben ser trenes de 8 bits ,el primero indica la posicion dentro de la frase y el segundo a cual frase se refiere . esto es una suposicion pues no encuentro nada referente asà pues os dejo aqui el dibujo del circuito y si sabe alguien como funciona toy muy interesado ;Dgracias con core.JPG
dj3nk Posted March 4, 2007 Posted March 4, 2007 much more complicate than a timecode vinyl. Why do you build this one ? you just need 2 timecode vinyls and a asio soundcard with 2 inputs and outputs. And a phono to line preamp. Thats all you need.No finalscratch hardware.
alogic Posted March 4, 2007 Author Posted March 4, 2007 reloj midi timming clock es un byte que se repite constantemente segun el bpm F8=11111000 (me falta saber cuantas veces ha de enviar este pulso por segundo )start - FA=11111010cue - FB=11111011stop - FC=11111100active sensing - este se envia cada tercio de segundo para comprobar fallos de conexion FE=11111110
alogic Posted March 6, 2007 Author Posted March 6, 2007 el programa deberia ser relativamente "sencillo" , cuando el motor arranca , hace girar el disco con los agujeritos, de forma que los receptores de infrarrojo envian a la core el codigo binario ascendente , ademas de un noveno bite que manda al pic la orden de cuando debe o no leer el dato mientras entran de forma ascendente.Asi cada vez que el pic reconozca que se ha cambiado de posicion , envia el byte f8=11111000 por la salida midi. hasta aqui tenemos un interruptor que le dice al pic que mueva el motor y que ademas saque por el midi la orden start fa=11111010 al mismo tiempo, se piensa en otro de stop ,que para el motor y a su vez que saca por el midi FC=11111100.(stop) y ha de dejar de mandar ordenes de timming. Despues de esto el motor hace girar el codificado que el pic lo interpreta como datos ascendentes y cada vez que un dato es mayor que el anterior el pic envia por el midi F8=11111000 la señal de timming(para esto necesitaria saber cuantos datos envia por segundo a una velocidad x en bpm.ej:4 a 129 bpm) asà el play va a la velocidad que valla el motor Se presenta el problema de que tiene que reconocer el dato mas alto de la tabla para que sepa que el siguiente que es 0 y continue adelante aun introduciendo un valor menor Ahora el problema es que yo no he puesto el disco codificado sobre un eje de motor, si no que esta "casi" loco sobre otra polea que si que va fijada por una correa al eje del motor ,como serÃa un disco sobre la alfombrilla lo que da la posibildad de pararlo ,adelantarlo ... pero y los reyes del escratch que paran por casa, cualquiera que pase le va a querer dar marcha atras ??? ??? ??? ??? en la regla midi1.0 no hablan de poder programar puntos de cue seria tan sencillo como que saltase tantos puntos hacia atras segun los pasos que se le haya dado al binario enviandole esta orden ,cue-FB=11111011 ,el secuenciador comienza en la ultima posicion donde se pulso play Ahora sabiendo como deberia de funcionar falta programarlo .........alguien sabe como continuar o alguna otra pagina web o libro donde expliquen mas sobre midi +datos+datos+datos+datos+datos+datos+datos+datos+datos+datos+datosregracias a cualquier ayuda o idea que siempre se agradecen
dj3nk Posted March 7, 2007 Posted March 7, 2007 could you pls tell me how the mechanical´parts will work. Do you want to use a lighting vinyl or just build a "scratch station" without a motor?
alogic Posted March 8, 2007 Author Posted March 8, 2007 aqui tenes un bosquejo de lo que estoy haciendo , con un motor excuse me for my english it´s babelfish.
alogic Posted March 8, 2007 Author Posted March 8, 2007 parece que empieza a tener forma aunque ,algun alma caritativa me podria ayudar con el pcb , a ver si se me va a pasar algo por alto. le he puesto entradas para potes por si acaso y el convertir de digital a analógico y de analógico a digital es porque el 0800 tiene entrada de clock ,la patilla 11 ,asà éste cambiará de dato cada vez que se ilumine el fotorreceptor numero 9.estoy usando un motor cc de 7.5v a unos 2 amperios , para accionar el motor hay que hacer que se encienda el led que esta conectado al regulador pwm , asà el multivibrador 74c221 hace encender y apagar al irf830 y el motor varÃa la velocidad segun el condensador y el pote , que seguramente sea un deslizante para emular los de un giradisco supongo que el conectar el adc0800 al las entradas del din no influirá en su funcionamiento aunque sà en la programación deberÃa ser mas fácil de programar si se conecta directamente a la puerta a del pic y no se ponen potenciómetros ,aunque le darÃa mucho más juegoacepto todo tipo de crÃticas constructivas y más todavÃa ayuda para programar gracias y todos a midi a ver en jpg si se ve algocambiar el .rar por .brd para abrir con eaglecon ain din dout core.rar
MTE Posted March 8, 2007 Posted March 8, 2007 must I rename the file to .brd ??? this dosnt work :(Im very interested in your work, cant you post some description about in english ?RegardsMTE
alogic Posted March 8, 2007 Author Posted March 8, 2007 ya estan otros , no olvideis cambiar el rar por .brd gracias por el aviso
dj3nk Posted March 9, 2007 Posted March 9, 2007 i think that wont work very good. imagine a vinyl when you scracth it. it slides over the slipmat.show me photos when it works ;)
dj3nk Posted March 9, 2007 Posted March 9, 2007 Do you have bought eagle pro ? because of your big board. If you have a cracked that could be the problem why mte cant open your file.
amando Posted March 9, 2007 Posted March 9, 2007 Hola, creo recordar haber leido que el "Midi Time Code" envia una señal de tempo, como si de un metronomo se tratase, aparte de una señal de "start" y "stop", pero me parece que algunas cajas de ritmo y secuenciadores tambien pueden enviar un dato, sobre el "beat" actual, pero desconozco con que precision, si es sobre una nota o un compas, y si puede ir adelante/atras e imagino que utilizan el formato sysex y no un controlador continuo.
MTE Posted March 9, 2007 Posted March 9, 2007 lol thats quite funny, all questions in english, answers in spanish :D :Dnow im searching for an good spain translator ;D
