Optimised PSU Success, But Possibly Broken my Core Board :-(
I've finally managed to knock together a working PSU from the Optimised PSU diagram, and using the original C64 power socket and switch. I did it on stripboard, and it looks terrible, and I'm sure the layout is incredibly inefficient, space-wise, but the voltages check out
5.13V and
13.88V
It's a minor right of passage for me, as it's the 1st actual circuit I've created from a circuit diagram. I'm surprised it works!
The only problem is, I fell at the first hurdle when it came to connecting the PSU to the MB Core. Desoldering the voltage regulator from my Smash TV PCB, the pad nearest the big cap came away from the board. I tried putting a jumper across the holes where pins 1 and 3 of the 7805 had been, but I don't think there was enough pad there to make a connection.
Two questions:
1. Am I jumpering across the right holes anyway where the 7805 used to be?
2. Where should the 5V output from the PSU be connected to the Smash TV Core board. The Optimised PSU diagram says J2, but J1 on the Smash TV board is the 5V OUTPUT. Should I just connect the PSU to the J1 power input pins on the Smash TV board?
I know this is incredibly basic stuff, but any help would be much appreciated.
Cheers
Alex
http://www.toneburst.net
you should be jumpering accross the outside pins of where the 7805 use to be, the center pin is ground.  The reason for this is that way you keep the caps in the circuit (the rectifier can go though) which help smooth out the DC voltage.  If you pulled the pad out, scrape away some of the soldermask from the trace right next to the where the pad was and solder to that.  Check continuity with a volt meter if your not sure its connected.
Either one if the rectifier is still there. If you take it off, then J2
Hello toneburst! I have recently completed my Optimized(not sure if I spelled that correctly) PSU board too and as you were, I was pretty excited to see it working as well!
As for the correct jumper to connect to, If you look at the page dedicated to the Core board, http://ucapps.de/mbhp_core.html here you will find a section describing the functions of all the jumpers on the Core module. It explains everything you will need to know about using J1 or J2 as the 5v input just as altitude explained. It helped me a lot and maybe it can give you some insight as well?
Hope that helps!
-tel3
Hi tel3 and Altitude,
thanks both of you for getting back to me. I missed that bit at http://ucapps.de/mbhp_core.html
I was a bit confused as to whether J1 and J2 on the Core boards on this site actually matched the ones on the SmashTV boards, since they look quite different.
I'll try soldering to the trace and test it to see if that works. It's gonna look messy, but hopefully it will work.
I'll post a pic of the PSU board when I've finished it (just need to add some SIL headers and the resistor for the LED).
Alex
Hey Carsten, I took a few pics of my PSU board for you to check out. These pics were taken with my motorola RAZR mobile phone so don't expect too much from them...
Some of you may notice that there are quite a few more jumper pins on my board than the original schematic drawing has. :) I'll explain...
In the top pic there is a row of 4 SIL pins on the bottom left(kinda difficult to see) of the board. This is where my 7pin DIN plug for the C64 PSU and the on/off switch connect to by means of a female connector w/crimp pins. The 8pin DIL jumper on the bottom right is where the Core and SID boards will get their 5v from individually(not chained from board to board as on the original schematic). The next 3pin SIL jumper up from that one is for the C64 power indicator LED. And the last 4pin SIL jumper in the top right is where I will send out the 14v to the SID modules individually as described before. ;)
I'm not sure if any of this will help you or not Carsten, but I dunno?
Let me know what you guys think of my PSU board too... ;D
-tel3
Oh crap!  :(  I just noticed after reading over my last post that I made a mistake on my board. Grrrrr!  >:(
On this part:
I would have needed to use a 16pin DIL pin header to send 5v to the Core and SID boards individually! Oh well, I guess I can still fix it...
By the way, Does anyone see a problem in not chaining them as in the Optimized PSU schematic and sending each one out separately anyway? It seemed like a good idea to me.
-tel3
You are supposed to put a cap on the end of the chain to cut down on the digital noise
Yeah, I was planning on putting it in later on when I make up all of my wires with their connectors and such. I didn't give that part enough thought It seems.  :( I guess it might not work the same with the 5v going out separately to each board huh?
-tel3
-tel3
it would work, but you'd have to place a cap at the end of each length of wire. if you have enough caps i guess that might be ok. the only possible problem i can see with doing it that way, is that each cap has to 'fill up' with charge when you turn it on, and the resulting current draw may be too high for the 7805.
hope this helps.
Hi Mr.modnaR!
Yeah, I thought that might be what I would have to do...
I guess the only thing I can do is to try it? ;) I would think the worst that could happen is the 7805 would get very hot and possibly fry? Or, It just won't work? ;D
If it comes down to it, I'll just do it the way TK designed it! I'm just not sure how to chain the modules together while using the crimp pin type connectors I like so much that will only fit one wire in them?? How do some of you guys do it?
Thanks for your help peeps! And sorry for jack'n your thread toneburst!!! (edit:Oops not carsten!)
-tel3
Hi toneburst!
Incidentally, the hardest thing about making the PSU was actually desoldering the original C64 power socket and switch.
Have you tried desoldering with some desoldering braid? It works pretty good for me. The only thing is you have to be careful about how hot the parts you are trying to desolder get while letting the copper braid "suck up" all of the solder. Definitley worth a try if you haven't already.
-tel3
Hi tel3,
I keep meaning to buy some soldering braid, but keep forgetting to order some.
Having screwed up one of the pads on my Core board, mind you, I'm a bit scared of getting things too hot again. It might be a good solution when it comes to desoldering C64 bits from the board though.
Cheer,
Alex
Talking of crimp pin connectors- what tool would I use to fit these? Newbie question, I'm afraid, but without knowing the correct terminology, I'm having great difficulty tracking down the right tools (and parts, for that matter).
Alex
Hi modnaR,
I'm in the UK. I thought maybe some sort of crimping too would be the way to go, but the only ones I could find were for cat5/RJ45-type cables.
I've been spending so much money buying the wrong things recently- just because I don't know what things are called. Mind you, I was in Maplins (UK electronics supplier) the other day, and the man behind the counter clearly didn't even know what solder was... seriously. He tried to engage me in conversation about his speaker crossovers, and it gradually became apparent that, while I don't know much myself, his knowledge of electronics rated on the minus scale.
Scary....
Alex
cool, yeah maplins sell some ok stuff, but the staff really should get transferred back to McDonald's.
i was looking for the same this as you, and after looking around, found that rswww.com are freakin' expensive. they sell these tools for £60 upwards to like £150!! craazy. one of the traders that comes into the garage where i work said that he could only get the insulated crimp connector tool, and then separately by the dies for using the tool for non-insulated crimp connectors. the tool was £30 and the dies were £50!!! can't figure that one out myself.
aaaaanyway, i found the best deal was www.kustompcs.co.uk, where i bought a nice pair of ratcheting crimpers for £24.50 not including shipping. and it's pretty good actually.
here's the link to the tools:
http://www.kustompcs.co.uk/acatalog/info_1993.html
hope this helps.
Hey Alex,
There are some really nice colour-coded wires I can scavenge from the C64s, so I should be able to keep track of what's going to where.
I used the wires from the C64 keyboard too! Depending on when you 64 was built, it may have a connector with the crimp pins already on the connector side. You can push the little metal tab in through the little openings on the C64's keyboard connector, pull out the wire with the pins attached and re-use the wires. ;) That's what I did at least!! Just an idea...
-tel3
