dcer10 Posted November 15, 2006 Posted November 15, 2006 Hi TK,In regard to your last post on this topic I did just what you said and built a box with 8 buttons, one encoder and a 2x16 LCD and uploaded the midibox 64e application to it. I am having a lot of trouble getting it to do anything for two reasons:1) I havent used the application before so Im not sure what to assign to the buttons for best usage2) I have not been able to customise the asm code as the layout is not familiar to me. I have used the applications for the sequencer and sid to customise, but for this application I dont understand how to define the pin as in other applications it is SR, pin and in this one it mostly talks about just the pin?Would it be possible for you or anybody else to help by suggesting the best layout of the minimal surface (photo and fpd files attached) and to suggest how to modify the asm to suit that layout?Here is the SR/pin info for the design if it helps:First 4 buttons l->r (under screen starting with the red one)SR0, D2SR0, D3SR0, D4SR0, D5Rotary encoder SR0 D0/D1Bottom row of buttons L->RSR0, D6SR0, D7SR1, D0SR1, D1Im happy to write the modification myself if someone can explain where I need to make the changes, and why as I would like to make a bigger one in the future.I had posted this info some time ago in another post, but no reply came from anyone.Thanks in advance!JohnMidibox TC.zip
TK. Posted November 15, 2006 Posted November 15, 2006 Could somebody who built a MB64E please answer the questions?Best Regards, Thorsten.
dcer10 Posted November 20, 2006 Author Posted November 20, 2006 Hi All,Im still stuck on this one if anyone can help. Just to avoid confusion, this is the same as:http://www.midibox.org/forum/index.php?topic=7918.0Should one of these be removed?? Thanks,John
stryd_one Posted November 20, 2006 Posted November 20, 2006 Yeh I think you can delete threads that you start?
dcer10 Posted November 22, 2006 Author Posted November 22, 2006 OK, this is the only thread left :) I still need help, anyone??? Thanks,John
Jidis Posted November 23, 2006 Posted November 23, 2006 John,Sorry you're not getting much action on this. I'd gladly help if I could, but I typically avoid encoder posts as I haven't been lucky enough to use any yet (I'm strictly "regular" MB64 so far).Hopefully, this thread is just waiting for the right person to read it.Good Luck,George
