Sasha Posted December 4, 2006 Report Posted December 4, 2006 This is Logitech Marble Mouse Optical Trackball planed for the MIDI controller, me and my friend building for Ableton Live.It is perfect for mounting compared to the regular trackball because it has separated PCB and plastick ball supporting element containing optics.This is how it all will be mounted to the frontpanel. The Ball support should be angled a bit so ball could stick out from the pannel enough. Everything is going to be made of laser cut acrylic.
stryd_one Posted December 4, 2006 Report Posted December 4, 2006 That is a handy design :) Thanks Sasa!Are you going to leave it USB (I assume it's not PS/2 :( ), or interface it with MBHP?
Sasha Posted December 4, 2006 Author Report Posted December 4, 2006 The Trackball is USB, and box will probably contain USB soundcard, so both card and trackball will be connected to the USB HUB. The controler should have only power and USB plugs on the rear panel. I supose the USB have enough power to suply the MB, but controller will probably have pannel illuminated with superbright LEDs so this option is out.
doc Posted December 5, 2006 Report Posted December 5, 2006 Hi,I supose the USB have enough power to suply the MB... be careful with this option! I once killed a mainboard with a controller that was USB powered. A single short sometimes is enough ...But as you mentioned, with panel ilumination this option isn't a option anymore.The Ball support should be angled a bit so ball could stick out from the pannel enoughHow does the ball "stick" in the panel ? I mean, can you take the ball out of the panel or even loose it?How did you fix the ball in its hole?greetsDoc
Mr modnaR Posted December 5, 2006 Report Posted December 5, 2006 How does the ball "stick" in the panel ? I mean, can you take the ball out of the panel or even loose it?How did you fix the ball in its hole?greetsDocmake it look like a grandma, and the track ball can be her glass eye, which you can pop out to show the grandkids.
Sasha Posted December 6, 2006 Author Report Posted December 6, 2006 How does the ball "stick" in the panel ?The hole will probably be smaller than ball, so ball couldn`t pop out from the controller. As trackball is optical there is no need to take it out often for cleaning, and when it`s needed there will be 8 screws to unscrew (4 from case and 4 from trackball)
Screaming_Rabbit Posted December 6, 2006 Report Posted December 6, 2006 This is funny... I hate those flat built in trackballs on large digital consoles (have you ever configured some 40-60 channels on a routing matrix being under time pressure?), so I bought one like you just ripped :'( apart and I am totaly happy with it :DWhat is funny about that? Well... taste seems to be very flexible :PGreets, Roger
Sasha Posted December 7, 2006 Author Report Posted December 7, 2006 What is funny about that? Well... taste seems to be very flexible Tongue ;D Yeah, you are right. I found my taste flexibile too. But you don`t belive it till it happends. It is mostly about women ;)
PeDr0 Posted October 1, 2008 Report Posted October 1, 2008 Out of interest, how did this go? I knew I left that space for a reason http://www.midibox.org/midibox_gallery/peter_a1.jpgHahaha, I think I must be the slowest Midibox builder in the universe.Peace out..
