HELP!
antonybest
This is a very simple question and I am probably doing something wrong, I'm trying to open MIOS studio 7.4 and I cant!!  I downloaded the zip file and the Java recommended, then I unpacked the zip file and according to the website you should just be able to click on the file and it will open, with no success it just goes into the folder.
I have tried to open it in MS-DOS also by doing:
java -jar MIOSStudio_beta7_4
and an error message appears in dos saying:
Unable to open jar file: MIOSStudio_beta7_4
Sorry if its a simple answer but can someone help?
Thanks
Antony Best
Link to comment
Share on other sites
Antony,
On the PC, after you've got that JRE bundle installed, there should be a java "JAR" file type associated with Java. From that point, you can just double click the MS7.4.jar file and it will run (exactly as it came in).
I think that type often associates itself with Winzip/Winrar, but it should be opening with Java "as is".
hope that helps,
George
Link to comment
Guest
Reply to this topic...
