napierzaza Posted December 21, 2006 Posted December 21, 2006 I've seen a few people on these forums who have built their own PSU. They said that they just harvested a bunch of PSUs so I'm very interested in that myself. However, I sort of need a schematic. I get the path of the electricity:AC120 -> Transformer -> Rectifier -> Capactior field(s) -> Voltage regulator -> etcBut I don't know how many capactiors (or the total uF to store) or how to split the lines into different voltage organizations. Does anyone have a tutorial or a layout?
audiocommander Posted December 21, 2006 Posted December 21, 2006 The main question is: for what?The main answer will be: please search the forums. Here are dozens of PSU schematics, esp. for SID and FM PSU's that require negative and/or higher voltages than 12V.For everything else (between +5 and +12V): get an universal PSU, with about 800 mA. They are so cheap that it will be more expensive to solder your own.And if you build yourself a PSU: be careful! 120V/220V may be deadly. This is definitely not a recommended project for electronic newbies! Michael
Jidis Posted December 21, 2006 Posted December 21, 2006 Can't believe I'm saying this, but Radio Shack actually has a decent small book called "Building Power Supplies", which goes from really simple ones up to some nicer switching designs with filtration,etc. (been a while since I've seen mine). If you have RS in your area, or can eBay one, you might want to check it out. It was only a few bucks.Take Care,George<edit> Mine was right beside me. ;DIt's this thing:http://tinyurl.com/ydqybgand another auction (more money):http://tinyurl.com/y9w6umIt's got Archer, Radio Shack, David Lines and Master Publishing on the front, and is catalog# 276-5025I see it's also on Amazon for under a dollar. :o
napierzaza Posted December 21, 2006 Author Posted December 21, 2006 Thanks for the responses, I will search google for "Building Power Supplies."I'm not really much of a noob, I've just never built a PSU.
audiocommander Posted December 22, 2006 Posted December 22, 2006 I will search google for "Building Power Supplies."Ok, don't want to hold back anyone from searching -...but I wonder why you don't want to search here: -> "PSU": 14 pages(!) of topics about PSUs-> "PSU Schematic": 4 pagesA quick test and I found about three different schematics for various purposes.A look at your post-history revealed that you're interested in a SID and/or FM. As I've written before, it makes a big difference if you just need +9V (best is about +7.5V for the Core) or -/+12V as required for the FM for example. There are really lots of postings about SID PSU's - ...and on the OPL3 page (module for MB FM) is a PDF schematic and even a PCB layout for an FM optimized PSU.I know that the informations are a bit widespread on these three pages ucApps/forum/wiki, but it definitely does not hurt reading the MBHP module pages on ucApps for the modules you want to build.I thought you already got my hint on your LCD-question :-\Regards,Michael
napierzaza Posted December 22, 2006 Author Posted December 22, 2006 Fair enough, I'm still having problems searching the site to be honest. It's rather mixed up in my opinion. there's actually a few times now where I try to find something I already read about here and can't :PBut for sure the LCD question was a little of a quick-draw, sorry about that one, I found that page about 15 minutes after I asked. Thanks very much, you're all very helpful.
audiocommander Posted December 22, 2006 Posted December 22, 2006 there's actually a few times now where I try to find something I already read about here and can'tahh, that may be if you're searching the forum while you're in a sub-thread. Best is to click on "Home" here before searching or using the advanced Search... I forgot to mention this, but I remember I had these troubles in the beginning, too :)no bad feelings from my side, you're welcome ;)Cheers,Michael
